220v 60hz drain pump
Washer Repair
Hi I moved from The Netherlands to Montreal Canada and brought my washer machine from The Netherlands. To run it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » 220v 60hz drain pump
  #1 (permalink)
Old 07-01-2013, 08:51 AM
Junior Member
ianbrouwer is on a distinguished road
Default 220v 60hz drain pump
Model Number: WAA28161FN/29   Brand: Bosch   Age: 1 - 5 years
I moved from The Netherlands to Montreal Canada and brought my washer machine from The Netherlands. To run it here in Canada I've bought a step up transformator to convert the voltage from 110v to 220v.
The washer is running fine, but the drain pump slips sometimes and causes errors in the program, leaving the washing machine in error mode. I can usually drain the washing machine a while later by running the drain program manually.
I guess due to the change in cycles 50hz to 60hz the drain pump is slipping and has a hard time to start.
I am looking to replace the drain pump to the correct cycle, 60hz. But since the washing machine is running on 220v I need a 220v 60hz drain pump.
Is such pump available in North America? I cannot find them.
Ian Brouwer
Related Models
Frigidaire WAB057P7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB067F7B1 Wwh(v0) / Room Air Conditioner
Frigidaire WAB067F7B2 Wwh(v0) / Room Air Conditioner
Frigidaire WAB067P7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB067T7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB067W7B1 Wwh(v0) / Air Conditioner
Frigidaire WAB077F7B1 Wwh(v0) / Room Air Conditioner
Frigidaire WAB077F7B3 Wwh(v0) / Room Air Conditioner
Frigidaire WAB077S7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB077Y7B1 Wwh(v0) / Room Air Conditioner
Frigidaire WAC051P7Z1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC051P7Z2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC051T7Z1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC051T7Z2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC051T7Z2A Wwh(v0) / Room Air Conditioner
Frigidaire WAC051T7Z2B Wwh(v0) / Room Air Conditioner
Frigidaire WAC051T7Z5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC052G7A1 Wwh(v0) / Room Air Conditioner
Frigidaire WAC052G7A2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC052G7A3 Wwh(v0) / Room Air Conditioner
White Westinghouse WAC052K7A1 White Westinghouse/air Conditioner
White Westinghouse WAC052K7A2 White Westinghouse/air Conditioner
White Westinghouse WAC052K7A4 White Westinghouse/air Conditioner
White Westinghouse WAC052K7A6 White Westinghouse/air Conditioner
White Westinghouse WAC052K7A7 White Westinghouse/air Conditioner
Frigidaire WAC052P7A1 Wwh(v2) / Room Air Conditioner
Frigidaire WAC052T7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC052T7A2A Wwh(v0) / Room Air Conditioner
Frigidaire WAC052T7A2B Wwh(v0) / Room Air Conditioner
Frigidaire WAC052T7A3 Wwh(v2) / Room Air Conditioner
Frigidaire WAC052T7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC052T7A6 Wwh(v0) / Air Conditioner
White Westinghouse WAC053K7A1 White Westinghouse/air Conditioner
White Westinghouse WAC053L7A1 White Westinghouse/air Conditioner
Frigidaire WAC053S7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053S7A4 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053T7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053T7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053T7A2A Wwh(v0) / Room Air Conditioner
Frigidaire WAC053T7A3 Wwh(v2) / Room Air Conditioner
Frigidaire WAC053T7A4 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053T7A5 Wwh(v2) / Room Air Conditioner
Frigidaire WAC053T7A6 Wwh(v2) / Room Air Conditioner
Frigidaire WAC056F7A2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC056P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC056P7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC056T7A1 Wwh(v3) / Room Air Conditioner
Frigidaire WAC056W7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC056W7A5A Wwh(v0) / Room Air Conditioner
White Westinghouse WAC060K7A1 White Westinghouse/air Conditioner
Frigidaire WAC060K7A2
White Westinghouse WAC061L7A1 White Westinghouse/air Conditioner
Frigidaire WAC062P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC063S7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC063S7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC063T7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC063T7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC063T7A5A Wwh(v0) / Room Air Conditioner
Frigidaire WAC066F7A2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC066F7A3 Wwh(v0) / Room Air Conditioner
Frigidaire WAC067P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC067P7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC067T7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC067W7A1 Wwh(v0) / Room Air Conditioner
Frigidaire WAC067W7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC067W7A5A Wwh(v0) / Room Air Conditioner
Frigidaire WAC072P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC073S7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC073T7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC073W7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC073W7A5A Wwh(v0) / Room Air Conditioner
Frigidaire WAC077T7A2 Wwh(v2) / Room Air Conditioner
Frigidaire WAC082G7A2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC082G7A8 Wwh(v0) / Room Air Conditioner
White Westinghouse WAC083K7A1 White Westinghouse/air Conditioner
White Westinghouse WAC083K7A2 White Westinghouse/air Conditioner
White Westinghouse WAC083K7A4 White Westinghouse/air Conditioner
White Westinghouse WAC083K7A5 White Westinghouse/air Conditioner
Frigidaire WAC083S7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC083S7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC083T7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC083W7A Wwh(v0) / Room Air Conditioner
Frigidaire WAC083W7A1 Wwh(v2) / Room Air Conditioner
Frigidaire WAC083W7A1B Wwh(v0) / Room Air Conditioner
Frigidaire WAC083W7A3 Wwh(v0) / Air Conditioner
Frigidaire WAC083W7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC083W7A5A Wwh(v0) / Room Air Conditioner
Frigidaire WAC083W7A8 Wwh(v0) / Room Air Conditioner
Frigidaire WAC086P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC086P7A2 Wwh(v2) / Room Air Conditioner
Frigidaire WAC086P7A3 Wwh(v1) / Room Air Conditioner
Frigidaire WAC086T7A2 Wwh(v2) / Room Air Conditioner
Frigidaire WAC086W7A1 Wwh(v0) / Room Air Conditioner
Frigidaire WAC086W7A1A Wwh(v0) / Room Air Conditioner
White Westinghouse WAC100M1C1 White Westinghouse/air Conditioner
Frigidaire WAC103G1A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC103G1A2 Wwh(v2) / Room Air Conditioner
White Westinghouse WAC103K1A1 White Westinghouse/air Conditioner
Frigidaire WAH074P7T1 Wwh(v1) / Room Air Conditioner
Frigidaire WAH074S7T2 Wwh(v1) / Room Air Conditioner
Frigidaire WAH074Y7T1 Wwh(v0) / Room Air Conditioner
Frigidaire WAH084P2T1 Wwh(v1) / Room Air Conditioner
Frigidaire WAH086H1T1 Wwh(v0) / Air Conditioner
Frigidaire WAH086P1T1 Wwh(v1) / Room Air Conditioner
Frigidaire WAH086P1T2 Wwh(v1) / Room Air Conditioner
Frigidaire WAH094P2T1 Wwh(v1) / Room Air Conditioner
Frigidaire WAH094P2T2 Wwh(v1) / Room Air Conditioner
Frigidaire WAH094S2T2 Wwh(v2) / Room Air Conditioner
Frigidaire WAH094Y2T1 Wwh(v0) / Room Air Conditioner
Frigidaire WAH096H2T1 Wwh(v0) / Air Conditioner
Frigidaire WAH096P2T1 Wwh(v1) / Room Air Conditioner
Frigidaire WAH096P2T2 Wwh(v1) / Room Air Conditioner
Frigidaire WAH09EH2T1 Wwh(v0) / Air Conditioner
Frigidaire WAH09EP2T1 Wwh(v2) / Room Air Conditioner
Frigidaire WAH09EP2T2 Wwh(v1) / Room Air Conditioner
Frigidaire WAH106H1T1 Wwh(v0) / Air Conditioner
Frigidaire WAH106H1T2 Wwh(v0) / Air Conditioner
Frigidaire WAH106H2T1 Wwh(v0) / Air Conditioner
Frigidaire WAH106H2T2 Wwh(v0) / Air Conditioner
Frigidaire WAH106P1T1 Wwh(v1) / Room Air Conditioner
  #2 (permalink)
Old 07-01-2013, 11:51 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
I fear you have asked a question far beyond my competence, but I think it is unlikely you will find a 60hZ 220 volt pump.
It may be that your current pump is rated for 60 Hz and you are just having a pump problem. The thing to do is to contact Bosch and get the specs on your machine and your pump, and see if they have a recommendation for changing out the pump is that is what you need to do.
Good luck.
  #3 (permalink)
Old 07-01-2013, 06:12 PM
Junior Member
Thanks for your reply. What about north american washers running on 240/60hz 2phase? I don't know where to look.
  #4 (permalink)
Old 07-01-2013, 06:34 PM
Senior Expert
APP Volunteer
I can only speak for the U. S. and I don't know of any U. S. machines that operate on 220-240v lines.
As I said, it may be that your pump motor is rated for both 50 and 60 hZ so first of all take a look at it and see if it is labeled as such, and if not try to talk to Bosch.
  #5 (permalink)
Old 07-01-2013, 06:50 PM
Junior Member
Thanks. The pump is a bosch part number 144192, runs on 230v/50hz/30W. I found the electrical information on the pump itself.
  #6 (permalink)
APP Volunteer
fairbank56 is a jewel in the rough
A 50hz motor will run ok on 60hz but will run 20% faster. This may be a problem for the control unit if it monitors pump current as many electronic controlled washers do. I know that Whirlpool has 220 volt 60hz washers for the U.S. market but they are the direct drive version and don't use electric drain pumps, they are driven mechanically by the main drive motor.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE 220v Window Unit won't come on theguy38301 Heating, Ventilation, and Air Conditioning (HVAC) 1 08-15-2012 02:00 PM
Dryer outside the US, wont start (220V) soapbox73 Dryer Repair 0 07-28-2010 09:50 AM
220 50hz vs 220 60hz douglasj Oven Repair (including Ranges and Cooktops) 2 02-13-2010 11:09 AM
bosch shu9925 - drain pump works, won't drain after cycle mjbarr Dishwasher Repair 0 10-16-2009 01:11 PM
will this pump also pump the drain water out Paul Radovsky Dishwasher Repair 5 07-20-2008 01:41 PM
