Washer goes through the first spin and drains out water, but won't kick into fast spin.
Your machine has an error code generator on the inverter which is on the motor. Take off the front cover by inserting a screw driver carefully in the gap between the top and front near the edges to release clips that hold the front panel on. Use this link HydroWave GE Washer Repair Guideto trouble shoot. The first thing to do is reset things, sometimes that is all that is needed.
