Leigh Egbert
#1 Posted : Thursday, June 27, 2013 8:11:30 AM(UTC)
Leigh Egbert
The drain pump on my whirlpool washer model 588-10 won't stop running. Havent Opened the controls yet. Don't know if I need to look at a relay or a circuit board. Any ideas what to look for?
fairbank56
#2 Posted : Thursday, June 27, 2013 8:54:13 AM(UTC)
fairbank56
Groups: Expert
Need the correct model number.
Leigh Egbert
#3 Posted : Thursday, June 27, 2013 10:24:46 AM(UTC)
Leigh Egbert
model number is WTW4950XW2
fairbank56
#4 Posted : Thursday, June 27, 2013 11:33:37 AM(UTC)
fairbank56
Groups: Expert
Tilt the machine back to gain access underneath and remove the drain pump to check for an obstruction. If it's clear, check the air dome and hose on the lower right rear of the tub. Remove the hose and check for obstruction in the hose and/or air dome. Clean as needed. If ok, get the manual from the inside of the cabinet and place washer in service mode to check for error codes. If no error codes, you likely have a faulty control board.
Whirlpool W10480261 Cntrl-Elec - AppliancePartsPros.com
Eric
