AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag washer spins, won't drain: new pump, belts
I have an old Maytag (A482 model, 2-belt, top-load) washer that won't drain. It will spin, seems to go through all its cycles fine. NOTE: one weird thing is that it doesn't seem to always 'stop' at the end, it wants to go onto the next wash cycle after it does it's final spin...
I have replaced the pump & belts, checked the hoses & tub for clogs, checked the siphon break (doesn't look plugged) and it will drain just a bit of water out, but not much...
Any ideas? Could it be the timer or some control unit? Motor? There aren't many parts in this thing, it's pretty simple...
Thanks!!
Washer Repair
