Discuss
Frigidaire Error Code 58 and 59
 in
Washer Repair
Hello, I have a Frigidaire Affintiy washer that is just over two years old. Overthe last 6 months (ironically shortly
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire Error Code 58 and 59
  #1 (permalink)
Old 06-14-2013, 11:43 AM
Junior Member
TurtleJock007 is on a distinguished road
Cool Frigidaire Error Code 58 and 59
Model Number: FAFS4473LN0   Brand: Frigidaire   Age: 1 - 5 years
Hello,
I have a Frigidaire Affintiy washer that is just over two years old. Overthe last 6 months (ironically shortly after the warranty went out) I havestarted to receive error codes 58 and 59 with more frequency. It use to be thatwhen I received the error, I could just run the cycle again and it would fixthe problem. However it is happening now on 80% of the loads. I can normallyget through one load a day without an error. I am familiar with the error codesfrom Frigidaire. I have followed the steps but I can't test the OHms on thepins. Knowing that the problem was either the Motor or the Motor Control Board,I took a 50/50 chance and replaced the Motor Control board at the tune of$146....that did not fix the problem. So my next step is to get a motor.However before I shell out aother $140, I wanted to see if anyone has any othertricks that might fix this issue. This is what I have done:
1. Checked the pump. I can hear it running and water does drain. I checkedthe hose and the rubber boot under the tub for any blockage.
2. Checked the wires running to the control board, motor control board andthe motor
3. Checked the tub and it spins freely
4. Checked the belt and it seems fine
5. Replaced the motor control board
6. Checked the door switch. It seems fine.
I find it hard to believe that it could be the motor because it will finishloads every once in a while but what do I know . I have used the diagnosticmode to run tests and on an empty tub, it can run through all the cycles.However it is hit or miss with a load. The tell tale sign is that when itreaches the spin cycle it will rotate 2-3 times and then stop. it will thenrotate the other directions 2-3 times. Then it will just sit there for a fewminutes and try again. After a few times it will error out with 58 or 59 anddrain the tub leaving a pile of wet clothes. So I try and run a rinse and spincycle crossing my fingers it will finish. I did notice that it has a differenttone outside of the error beeps that also seem to indicate it will error out.they are not as high pitched as the end cycle beeps or the error beeps but alower tone kind of like a "bong".
Any information on a trick I can try before I shell out more money would begreatly appreciated...Also a confirmation on the correct motor part would beappreciated as well....
thanks,
Jeff
Related Models
Frigidaire FAFS4473LN0 WASHER
Frigidaire FAFS4473LR0 WASHER
Frigidaire FAFS4473LW0 WASHER
Frigidaire FAFS4474LA0 WASHER
Frigidaire FAFS4474LN0 WASHER
Frigidaire FAFS4474LR0 WASHER
Frigidaire FAFS4474LW0 WASHER
Frigidaire FAFW3511KB0 WASHER
Frigidaire FAFW3511KR0 WASHER
Frigidaire FAFW3511KW0 WASHER
Frigidaire FAFW3511KW1 WASHER
Frigidaire FAFW3514KA0 WASHER
Frigidaire FAFW3514KA1 WASHER
Frigidaire FAFW3514KN0 WASHER
Frigidaire FAFW3514KN1 WASHER
Frigidaire FAFW3517KA1 WASHER
Frigidaire FAFW3517KB0 WASHER
Frigidaire FAFW3517KB1 WASHER
Frigidaire FAFW3517KN0 WASHER
Frigidaire FAFW3517KN1 WASHER
Frigidaire FAFW3517KR0 WASHER
Frigidaire FAFW3517KR1 WASHER
Frigidaire FAFW3517KT1 WASHER
Frigidaire FAFW3517KW0 WASHER
Frigidaire FAFW3517KW1 WASHER
Frigidaire FAFW3574KA0 FRONT LOAD WASHER
Frigidaire FAFW3574KB0 FRONT LOAD WASHER
Frigidaire FAFW3574KN0 FRONT LOAD WASHER
Frigidaire FAFW3574KR0 WASHER
Frigidaire FAFW3574KW0 FRONT LOAD WASHER
Frigidaire FAFW3577KA0 WASHER
Frigidaire FAFW3577KA1 WASHER
Frigidaire FAFW3577KB0 WASHER
Frigidaire FAFW3577KB1 WASHER
Frigidaire FAFW3577KN0 WASHER
Frigidaire FAFW3577KN1 WASHER
Frigidaire FAFW3577KR0 WASHER
Frigidaire FAFW3577KR1 WASHER
Frigidaire FAFW3577KW0 WASHER
Frigidaire FAFW3577KW1 WASHER
Frigidaire FAFW3801LB0 WASHER
Frigidaire FAFW3801LW0 WASHER
Frigidaire FAFW4011LB0 WASHER
Frigidaire FAFW4011LW0 WASHER
Frigidaire FAFW4221LB0 WASHER
Frigidaire FAFW4221LW0 WASHER
Frigidaire FAH085N1T Frigidaire/air Conditioner
Frigidaire FAH085N1T2 Frigidaire/air Conditioner
Frigidaire FAH085P1T1 Frigidaire/air Conditioner
Frigidaire FAH086J1T1 Frg/room Air Conditioner
Frigidaire FAH086J1T2 Frg/room Air Conditioner
Frigidaire FAH086M1T1 Frigidaire/air Conditioner
Frigidaire FAH086N1T1 Frigidaire/air Conditioner
Frigidaire FAH086R1T1 Frigidaire/air Conditioner
Frigidaire FAH086S1TA ROOM AIR CONDITIONER
Frigidaire FAH086S1TA11 ROOM AIR CONDITIONER
Frigidaire FAH086S1TA12 ROOM AIR CONDITIONER
Frigidaire FAH086S1TA13 ROOM AIR CONDITIONER
Frigidaire FAH086S1TB ROOM AIR CONDITIONER
Frigidaire FAH086T1T0 ROOM AIR CONDITIONER
Frigidaire FAH086T1T10 ROOM AIR CONDITIONER
Frigidaire FAH08EJ1T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH08EM1T1 Frigidaire/air Conditioner
Frigidaire FAH08EN1T Frigidaire/air Conditioner
Frigidaire FAH08EN1T2 Frigidaire/air Conditioner
Frigidaire FAH08EN1T3 Frigidaire/air Conditioner
Frigidaire FAH08EP1T1 Frigidaire/air Conditioner
Frigidaire FAH08ER1T1 Frigidaire/air Conditioner
Frigidaire FAH08ES1TA ROOM AIR CONDITIONER
Frigidaire FAH08ES1TA11 ROOM AIR CONDITIONER
Frigidaire FAH08ES1TA12 ROOM AIR CONDITIONER
Frigidaire FAH08ES1TA13 ROOM AIR CONDITIONER
Frigidaire FAH08ES1TB ROOM AIR CONDITIONER
Frigidaire FAH08ET1T0 ROOM AIR CONDITIONER
Frigidaire FAH08ET1T10 ROOM AIR CONDITIONER
Frigidaire FAH096J2T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH096J2T2 Frg(v0) / Room Air Conditioner
Frigidaire FAH096J2T3 Frigidaire/air Conditioner
Frigidaire FAH096M2T1 Frigidaire/air Conditioner
Frigidaire FAH105N1T Frigidaire/air Conditioner
Frigidaire FAH105N1T2 Frigidaire/air Conditioner
Frigidaire FAH105N2T Frigidaire/air Conditioner
Frigidaire FAH105N2T2 Frigidaire/air Conditioner
Frigidaire FAH105P1T1 Frigidaire/air Conditioner
Frigidaire FAH105P2T1 Frigidaire/air Conditioner
Frigidaire FAH106J1T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH106J1T2 Frigidaire/air Conditioner
Frigidaire FAH106J2T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH106J2T2 Frigidaire/air Conditioner
Frigidaire FAH106M1T1 Frigidaire/air Conditioner
Frigidaire FAH106M2T1 Frigidaire/air Conditioner
Frigidaire FAH106N1T1 Frigidaire/air Conditioner
Frigidaire FAH106N2T1 Frigidaire/air Conditioner
Frigidaire FAH106R1T1 Frigidaire/air Conditioner
Frigidaire FAH106R2T1 Frigidaire/air Conditioner
Frigidaire FAH106S1TA ROOM AIR CONDITIONER
Frigidaire FAH106S1TA11 ROOM AIR CONDITIONER
Frigidaire FAH106S1TA12 ROOM AIR CONDITIONER
Frigidaire FAH106S1TA13 ROOM AIR CONDITIONER
Frigidaire FAH106S1TB ROOM AIR CONDITIONER
Frigidaire FAH106S2TA ROOM AIR CONDITIONER
Frigidaire FAH106S2TA11 ROOM AIR CONDITIONER
Frigidaire FAH106S2TA12 ROOM AIR CONDITIONER
Frigidaire FAH106S2TA13 ROOM AIR CONDITIONER
Frigidaire FAH106S2TB ROOM AIR CONDITIONER
Frigidaire FAH106T1T0 ROOM AIR CONDITIONER
Frigidaire FAH106T1T10 ROOM AIR CONDITIONER
Frigidaire FAH106T2T0 ROOM AIR CONDITIONER
Frigidaire FAH106T2T10 ROOM AIR CONDITIONER
Frigidaire FAH10EJ2T2 Frigidaire/air Conditioner
Frigidaire FAH10EM2T1 Frigidaire/air Conditioner
Frigidaire FAH10EN2T Frigidaire/air Conditioner
Frigidaire FAH10EN2T2 Frigidaire/air Conditioner
Frigidaire FAH10EN2T3 Frigidaire/air Conditioner
Frigidaire FAH10EP2T1 Frigidaire/air Conditioner
Frigidaire FAH10ER2T1 Frigidaire/air Conditioner
Frigidaire FAH10ES2TA ROOM AIR CONDITIONER
Frigidaire FAH10ES2TA11 ROOM AIR CONDITIONER
Frigidaire FAH10ES2TA12 ROOM AIR CONDITIONER
Frigidaire FAH10ES2TA13 ROOM AIR CONDITIONER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Error Code - E47 Scotts_Spot Washer Repair 5 04-28-2015 06:40 AM
Frigidaire error code ffrank Refrigerator & Freezer Repair 0 02-04-2012 08:54 AM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
Frigidaire error code e7 Pgillott Oven Repair (including Ranges and Cooktops) 0 09-12-2009 02:37 PM
frigidaire e70 error code didcr1 Washer Repair 1 07-28-2009 06:07 PM
