My washer still works great but, now the drum don't sit centered and spill water when it refills. I have to push the drum under the water inlet to avoid the water from spilling. All other functions are fine. Thanks !
Groups: APP Team
Thank you so much Simon !! It sounds like that is exactly what it is.
Originally Posted by: Waltquez My washer still works great but, now the drum don't sit centered and spill water when it refills. I have to push the drum under the water inlet to avoid the water from spilling. All other functions are fine. Thanks ! Thank you so much Simon. It sounds like that is exactly what it is. Thanks !!
Groups: APP Team
