My cabrio seems to have a bad bearing. On the spin/drain cycle during last 10 minutes of cycle it sounds like a freight train. The video on bearing change on this site says the parts are compatible with 6000 and 7000 series. A local parts supply shop told me the bearing is in the outer tub and I just needed to order the outer tub.... so I did. no bearing in tub. Is the bearing replacable in the 5600 series? if so, what are the correct part numbers, how do I get them.
Thank you
Devon
Groups: APP Team
Hello, Devon. There is no tub bearings in the WTW5600XW0 model. It sounds like noise is made by the gearcase assembly. Part number: W10324649
Thank you Simon. Very helpful.
Groups: APP Team
