a14711b
#1 Posted : Tuesday, June 4, 2013 3:20:28 PM(UTC)
a14711b
I wrote earlier about this machine and this error shows up almost every time after 12 or so minutes into the cycle. I cleaned the inlet hose filters and tested output on both hot and cold. There doesn't appear to be any restrictions. I replaced the inlet valve. The washer still errors around the same time. If I place in manual mode this correlates to cycle 03. If I run past C03 to C05, I can get the load washed and afterwards, I run a rinse cycle completely. I know this is not how it should be, but desparate time...
How can I tell if it is the pressure switch or a control board without buying each part? I am on limited income and can't afford a tech visit and parts.
HF error code (Washer Repair)
by Golfing dawn 8/28/2013 6:39:08 PM(UTC)
Whirlpool Duet Washer HF Error Code (Washer Repair)
by the7things 6/10/2013 6:57:14 AM(UTC)
Whirlpool HF error (Washer Repair)
by sneiss 7/2/2010 12:29:03 PM(UTC)
