Discuss
Washer won't fill on rinse cycle unless between 2 settings
 in
Washer Repair
Hello all, I have a very similar problem to a thread already answered on this forum... but with a bit
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't fill on rinse cycle unless between 2 settings
  #1 (permalink)
Old 06-02-2013, 12:11 PM
Junior Member
jkaszer is on a distinguished road
Default Washer won't fill on rinse cycle unless between 2 settings
Model Number: 11024952300   Brand: Kenmore   Age: 1 - 5 years
Hello all, I have a very similar problem to a thread already answered on this forum... but with a bit more info. Here is the previous thread:
No rinse cycle
HOWEVER, I do want to note that:
1) The washer WILL NOT fill for regular washing on cold/cold
2) The rinse cycle WILL fill if I manually hold the temperature control switch between 2 settings on the Automatic temperature control side. The water that comes out is very HOT (On the NON- automatic temperature control....it will partially fill for rinse if the temperature is set to warm/warm, but will shut off partway through. It does not fill at all for rinse if on cold/cold... warm/cold ... or any setting inbetween
During rinse, once the water level has filled to the correct level (I have to hold the switch in this in-between position the whole time)... the filling stops, the agitator moves, and the machine continues its cycle through to completion.
3) I have jumped the lid switch to no avail.
4) there is no evidence of arcing like in the referenced thread
5) Reading wiring diagrams is Greek to me
Is it the timer, or a problem with the cold water supply/valve? If it was a water valve problem, shouldn't the machine still complete the rinse cycle if the temperature was set to warm/warm?
Looking at the price of a timer online ($150 + shipping/handling)... if it is the timer, is it even worth replacing considering I can grab another used washer off of Craigslist for $200... (The price I paid for this one 1 year ago)
I thank you for help this appliance repair noob.
Related Models
Kenmore 11024952300 AUTOMATIC WASHER
Kenmore 11024952301 RESIDENTIAL WASHER
Kenmore 11024954300 AUTOMATIC WASHER
Kenmore 11024954301 RESIDENTIAL WASHER
Kenmore 11024956300 AUTOMATIC WASHER
Kenmore 11024956301 RESIDENTIAL WASHER
Kenmore 11024962300 AUTOMATIC WASHER
Kenmore 11024962301 RESIDENTIAL WASHER
Kenmore 11024964300 AUTOMATIC WASHER
Kenmore 11024964301 RESIDENTIAL WASHER
Kenmore 11024966300 AUTOMATIC WASHER
Kenmore 11024966301 RESIDENTIAL WASHER
Kenmore 11024972300 AUTOMATIC WASHER
Kenmore 11024974300 AUTOMATIC WASHER
Kenmore 11024982300 AUTOMATIC WASHER
Kenmore 11024992300 AUTOMATIC WASHER
Kenmore 11024994300 AUTOMATIC WASHER
Kenmore 11024996300 AUTOMATIC WASHER
Kenmore 11025062500 WASHER
Kenmore 11025064500 WASHER
Kenmore 11025066500 WASHER
Kenmore 11025292500 WASHER
Kenmore 11025292501 WASHER
Kenmore 11025292502 RESIDENTIAL WASHER
Kenmore 11025292503 RESIDENTIAL WASHER
Kenmore 11025294500 WASHER
Kenmore 11025294501 WASHER
Kenmore 11025294502 RESIDENTIAL WASHER
Kenmore 11025294503 RESIDENTIAL WASHER
Kenmore 11025832400 RESIDENTIAL WASHER
Kenmore 11025842400 AUTOMATIC WASHER
Kenmore 11025844400 AUTOMATIC WASHER
Kenmore 11025852400 AUTOMATIC WASHER
Kenmore 11025854400 AUTOMATIC WASHER
Kenmore 11025862400 AUTOMATIC WASHER
Kenmore 11025864400 AUTOMATIC WASHER
Kenmore 11026002010 AUTOMATIC WASHER
Kenmore 11026002011 AUTOMATIC WASHER
Kenmore 11026012010 AUTOMATIC WASHER
Kenmore 11026012011 AUTOMATIC WASHER
Kenmore 11026051690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026058690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026071690 COMMERCIAL WASHER
Kenmore 11026071691 COMMERCIAL WASHER
Kenmore 11026152500 WASHER COMMERCIAL
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026322500 WASHER
Kenmore 11026322501 WASHER
Kenmore 11026322502 RESIDENTIAL WASHER
Kenmore 11026322503 RESIDENTIAL WASHER
Kenmore 11026332500 RESIDENTIAL WASHER
Kenmore 11026332501 WASHER
Kenmore 11026332502 RESIDENTIAL WASHER
Kenmore 11026332503 RESIDENTIAL WASHER
Kenmore 11026342500 RESIDENTIAL WASHER
Kenmore 11026342501 WASHER
Kenmore 11026342502 RESIDENTIAL WASHER
Kenmore 11026342503 RESIDENTIAL WASHER
Kenmore 11026422500 RESIDENTIAL WASHER
Kenmore 11026422501 WASHER
Kenmore 11026422502 RESIDENTIAL WASHER
Kenmore 11026422503 RESIDENTIAL WASHER
Kenmore 11026432500 WASHER
Kenmore 11026432501 WASHER
Kenmore 11026432502 RESIDENTIAL WASHER
Kenmore 11026432503 RESIDENTIAL WASHER
Kenmore 1102644182 RESIDENTIAL WASHER
Kenmore 11026442500 WASHER
Kenmore 11026442501 WASHER
Kenmore 11026442502 RESIDENTIAL WASHER
Kenmore 11026442503 RESIDENTIAL WASHER
Kenmore 1102644722 RESIDENTIAL WASHER
Kenmore 11026622690 WASHER
Kenmore 11026622691 AUTOMATIC WASHER
Kenmore 11026632500 WASHER
Kenmore 11026632501 WASHER
Kenmore 11026632502 WASHER
Kenmore 11026632503 RESIDENTIAL WASHER
Kenmore 11026642500 WASHER
Kenmore 11026642501 washer
Kenmore 11026642502 WASHER
Kenmore 11026642503 RESIDENTIAL WASHER
Kenmore 11026652500 WASHER
Kenmore 11026652501 WASHER
Kenmore 11026652502 WASHER
Kenmore 11026652503 RESIDENTIAL WASHER
Kenmore 11026682503 RESIDENTIAL WASHER
Kenmore 11026692503 RESIDENTIAL WASHER
Kenmore 11026702690 AUTOMATIC WASHER
Kenmore 11026702691 AUTOMATIC WASHER
Kenmore 11026702692 AUTOMATIC WASHER
Kenmore 11026702693 AUTOMATIC WASHER
Kenmore 11026702694 AUTOMATIC WASHER
Kenmore 11026712690 WASHER
Kenmore 11026712691 AUTOMATIC WASHER
Kenmore 11026712692 AUTOMATIC WASHER
Kenmore 11026712693 AUTOMATIC WASHER
Kenmore 11026722690 WASHER
Kenmore 11026722691 AUTOMATIC WASHER
Kenmore 11026722692 AUTOMATIC WASHER
Kenmore 11026722693 AUTOMATIC WASHER
Kenmore 11026732500 WASHER
Kenmore 11026732501 WASHER
Kenmore 11026732502 WASHER
Kenmore 11026732503 RESIDENTIAL WASHER
Kenmore 11026742500 WASHER
Kenmore 11026742501 WASHER
Kenmore 11026742502 WASHER
Kenmore 11026742503 RESIDENTIAL WASHER
  #2 (permalink)
Old 06-02-2013, 01:11 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Sounds like the cold water inlet valve is faulty. Have you checked the inlet screen for clogging? Checked that you have good cold water pressure? If ok, swap the power connections at the water inlet solenoids. This video will show you how to remove the cabinet. Swap wiring connections between hot and cold and try cold/cold setting again. Do you now get hot water? Can you provide a clear high resolution photo of the wiring diagram and another of the timer chart? they should be on the inside of the back panel when you take the cabinet off.
Eric
  #3 (permalink)
Old 06-02-2013, 07:52 PM
Junior Member
Default next step
Thanks Eric.
I did everything you said and switched the wiring connections. Hot water did come out when it was set to cold/cold. It must be the water inlet valve. I will attach images you requested.
Should I order part Whirlpool 285805 Water Inlet Valve - AppliancePartsPros.com
thank you for your help,
jamie
  #4 (permalink)
Old 06-03-2013, 05:27 AM
Expert
APP Volunteer
Default
Yes, looks like you need a new water inlet valve assembly. Thanks for the photo's. Let us know how it works out.
Eric
  #5 (permalink)
Old 06-05-2013, 09:04 PM
Junior Member
Default Did I order the wrong part?
Part got here today! Great shipping time appliancepartspros!
I ordered the item I had posted earlier:
When I went to install it.... dismay! The old valve I needed to remove had 2 wires attached to the bottom of it and a different structure. I could not figure out how to remove the section the the wires attached to.... the interface with the water valve almost seemed glued. Even if I pried it apart I don't think that portion would just slip on over the new valve. I'm assuming i ordered the wrong part.
#1) what are those two wires
#2) What do I need to do?
thank you for the help,
  #6 (permalink)
Old 06-06-2013, 05:27 AM
Expert
APP Volunteer
Default
Yes, you ordered the wrong part. The two wires attach to the thermistor which is an integral part of the valve assembly. The auto temp control uses the thermistor to determine what the water temperature is. Here is the correct part you need.
Whirlpool 3979346 Water Inlet Valve Assembly - AppliancePartsPros.com
Eric
  #7 (permalink)
Old 06-06-2013, 08:30 AM
Junior Member
Default Can I use the part I have
Thank you Eric. I disconnected the old valve today. Is it possible to just cap/electrical tape the ends of the two thermistor wires and just use teh part I ordered? I never use the automatic temperature control. Or would not having the wires connected create some kind of short in teh entire system?
This would save me $20 and more importantly I could finally do some laundry tonight.
  #8 (permalink)
Old 06-06-2013, 09:31 AM
Expert
APP Volunteer
Default
You could do that however, the warm/warm setting on the non-atc portion of the temp control actually uses the atc for the warm rinse. There is no danger in leaving the wires disconnected.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't fill on rinse cycle tmwalker3 Washer Repair 5 08-25-2017 08:02 PM
Washer won't fill on wash cycle but will during rinse march_33 Washer Repair 4 12-07-2011 06:48 PM
maytag washer wont fill on rinse cycle bubniak Washer Repair 1 04-04-2011 06:41 AM
Washer won't drain, fill or agitate for the rinse cycle Joyous Washer Repair 12 08-27-2010 03:38 PM
Only on rinse cycle washer won't fill up with water, goes right to the drain hose pmmcadams Washer Repair 1 08-10-2009 03:33 PM
