Discuss
kenmore won't spin and makes grinding noise
 in
Washer Repair
I have a ten year old Kenmore 80 series washer (model #11020802990) that started making a grinding noise while spinning.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore won't spin and makes grinding noise
  #1 (permalink)
Old 05-20-2013, 03:00 PM
Junior Member
jims is on a distinguished road
Default kenmore won't spin and makes grinding noise
Model Number: 11020802990   Brand: Kenmore   Age: 5 - 10 years
I have a ten year old Kenmore 80 series washer (model #11020802990) that started making a grinding noise while spinning. Water drained, but clothes were coming out still soaked at the end of the cycle. Now it is only making the grinding noise and will not spin.
I have no problem replacing parts, just not sure where to start.
I initially checked the drain pump for blockage and found none. Not sure if I should replace the clutch, motor coupling or something else next. Is there a way to determine if those parts are worn/damaged?
Thanks for any help
Jim
Related Models
Kenmore 11020802990 AUTOMATIC WASHER
Kenmore 11020802991 WASHER
Kenmore 11020832990 AUTOMATIC WASHER
Kenmore 11020832991 WASHER
Kenmore 11020842990 AUTOMATIC WASHER
Kenmore 11020842991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020852990 AUTOMATIC WASHER
Kenmore 11020852991 WASHER
Kenmore 11020854990 AUTOMATIC WASHER
Kenmore 11020854991 WASHER
Kenmore 11020857990 AUTOMATIC WASHER
Kenmore 11020862990 AUTOMATIC WASHER
Kenmore 11020862991 WASHER
Kenmore 11020872990 AUTOMATIC WASHER
Kenmore 11020872991 WASHER
Kenmore 11020882990 AUTOMATIC WASHER
Kenmore 11020882991 WASHER
Kenmore 11020892990 AUTOMATIC WASHER
Kenmore 11020892991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020894990 AUTOMATIC WASHER
Kenmore 11020894991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020897990 AUTOMATIC WASHER
Kenmore 11020901990 AUTOMATIC WASHER
Kenmore 11020901991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020902990 AUTOMATIC WASHER
Kenmore 11020902991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020904990 AUTOMATIC WASHER
Kenmore 11020904991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020907990 AUTOMATIC WASHER
Kenmore 11020907991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020912990 AUTOMATIC WASHER
Kenmore 11020912991 WASHER
Kenmore 11020922990 AUTOMATIC WASHER
Kenmore 11020922991 WASHER
Kenmore 11020924990 AUTOMATIC WASHER
Kenmore 11020924991 WASHER
Kenmore 11020927990 AUTOMATIC WASHER
Kenmore 11020932990 AUTOMATIC WASHER
Kenmore 11020932991 AUTOMATIC WASHER
Kenmore 11020932992 AUTOMATIC WASHER
Kenmore 11020932993 WASHER
Kenmore 11020932994 WASHER
Kenmore 11020936990 AUTOMATIC WASHER
Kenmore 11020936991 AUTOMATIC WASHER
Kenmore 11020936992 AUTOMATIC WASHER
Kenmore 11020936993 WASHER
Kenmore 11020936994 WASHER
Kenmore 11020942990 AUTOMATIC WASHER
Kenmore 11020942991 AUTOMATIC WASHER
Kenmore 11020942992 AUTOMATIC WASHER
Kenmore 11020942993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020942994 WASHER
Kenmore 11020952990 AUTOMATIC WASHER
Kenmore 11020952991 AUTOMATIC WASHER
Kenmore 11020952992 AUTOMATIC WASHER
Kenmore 11020952993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020952994 WASHER
Kenmore 11020954992 AUTOMATIC WASHER
Kenmore 11020954993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020954994 WASHER
Kenmore 11020956990 AUTOMATIC WASHER
Kenmore 11020956991 AUTOMATIC WASHER
Kenmore 11020956992 AUTOMATIC WASHER
Kenmore 11020956993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020956994 WASHER
Kenmore 11020957990 AUTOMATIC WASHER
Kenmore 11020957991 AUTOMATIC WASHER
Kenmore 11020957992 AUTOMATIC WASHER
Kenmore 11020972990 WASHER
Kenmore 11020972991 WASHER
Kenmore 11020972992 WASHER
Kenmore 11020972993 WASHER
Kenmore 11020982990 WASHER
Kenmore 11020982991 WASHER
Kenmore 11020982992 WASHER
Kenmore 11020982993 WASHER
Kenmore 11020992990 WASHER
Kenmore 11020992991 WASHER
Kenmore 11020992992 WASHER
Kenmore 11020992993 WASHER
Kenmore 11020994991 WASHER
Kenmore 11020994992 WASHER
Kenmore 11020994993 WASHER
Kenmore 11020996991 WASHER
Kenmore 11020996992 WASHER
Kenmore 11020996993 WASHER
Kenmore 11020997990 WASHER
Kenmore 11020997991 WASHER
Kenmore 11020997992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021102010 AUTOMATIC WASHER
Kenmore 11021102011 AUTOMATIC WASHER
Kenmore 11021112010 AUTOMATIC WASHER
Kenmore 11021112011 AUTOMATIC WASHER
Kenmore 11021182010 AUTOMATIC WASHER
Kenmore 11021182011 AUTOMATIC WASHER
Kenmore 11021202010 AUTOMATIC WASHER
Kenmore 11021202011 AUTOMATIC WASHER
Kenmore 11021252110 AUTOMATIC WASHER
Kenmore 11021292010 AUTOMATIC WASHER
Kenmore 11021292011 AUTOMATIC WASHER
Kenmore 11021302010 AUTOMATIC WASHER
Kenmore 11021302011 AUTOMATIC WASHER
Kenmore 11021352110 AUTOMATIC WASHER
Kenmore 11021392010 AUTOMATIC WASHER
Kenmore 11021392011 AUTOMATIC WASHER
Kenmore 11021392012 AUTOMATIC WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
  #2 (permalink)
Old 05-20-2013, 05:33 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
There are a couple of things you need to check. First would be the drive block, check if the grooves are in tacked and the spin tube is engaging the drive block. Removal of the agitator is required.
The drive block Part number: 389140
Part number: 389140
Next drop down the transmission and check the clutch and drive basket for broken parts.
The clutch Part number: 285785
Part number: 285785
The drive basket Part number: 285792
Part number: 285792
If all of this checks OK it may be a bad transmission itself.
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 05-21-2013, 06:53 AM
Junior Member
Default
Simon,
The drive block looks good. I have the clutch off and don't see anything broken, but is there a way to tell if it is bad?
  #4 (permalink)
Old 05-21-2013, 09:55 AM
Expert
Default
Hi.
Look for worn out break pads in the clutch and basket drive, also check the bottom portion of the basket drive. Put the clutch and transmissiion back, bypass the lid switch and turn the washer to spin.
Check if the silver color cup (clutch portion mounted on the top of the transmission) is rotating.
If it is - the clutch is bad.
If not - the transmission is, part number Part number: 3360629
Simon.
__________________
  #5 (permalink)
Old 05-21-2013, 12:22 PM
Junior Member
Default
Clutch is not rotating, so I guess it is the transmission. Not sure it is worth fixing. Tanks for the help
  #6 (permalink)
Old 05-21-2013, 12:27 PM
Expert
Default
You are welcome.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper Makes Grinding Noise During Spin PeggyMontreal Washer Repair 0 12-31-2012 07:59 AM
my kenmore washer makes a grinding noise during spin cycle and does not spin bronco48 Washer Repair 2 10-28-2012 02:42 AM
Kenmore makes grinding noise ACSPLACE Washer Repair 3 11-14-2010 02:37 PM
Washer makes grinding noise during spin vmart Dishwasher Repair 0 10-21-2009 07:11 PM
Kenmore Washer Series 80. Won't spin, agitate and makes a grinding noise Scottmcc Washer Repair 6 01-05-2008 07:24 AM
