Discuss
Kenmore 90 clicking on agitate
 in
Washer Repair
I have a kenmore 90 series (whirlpool) which makes clicking noises on agitate. The lid switch works. The timer seems
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 90 clicking on agitate
  #1 (permalink)
Old 05-20-2013, 07:13 AM
Junior Member
brockt is on a distinguished road
Default Kenmore 90 clicking on agitate
Model Number: 11020902991   Brand: Kenmore   Age: More than 10 years
The lid switch works. The timer seems to work OK. It spins OK and advances to the next cycle OK. When the clicking sound on agitate happens the lights dim. It does seem to agitate, but not fully. The cycle speed switch doesn't seem to make any difference in what position you put it other than gentle which waits before clicking and repeat. I'm guessing this is something like a motor switch (between start and run), but I'm not sure how to diagnose this. Also, if this were a run/start issue, then I would not expect the spin cycle to work....I guess I could remove the motor and see if it still makes the sound with just the motor. Also, the washer is older than 10 years. Does is just make more sense to replace it before other things go wrong? Thanks.
Related Models
Kenmore 11020902991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020904990 AUTOMATIC WASHER
Kenmore 11020904991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020907990 AUTOMATIC WASHER
Kenmore 11020907991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020912990 AUTOMATIC WASHER
Kenmore 11020912991 WASHER
Kenmore 11020922990 AUTOMATIC WASHER
Kenmore 11020922991 WASHER
Kenmore 11020924990 AUTOMATIC WASHER
Kenmore 11020924991 WASHER
Kenmore 11020927990 AUTOMATIC WASHER
Kenmore 11020932990 AUTOMATIC WASHER
Kenmore 11020932991 AUTOMATIC WASHER
Kenmore 11020932992 AUTOMATIC WASHER
Kenmore 11020932993 WASHER
Kenmore 11020932994 WASHER
Kenmore 11020936990 AUTOMATIC WASHER
Kenmore 11020936991 AUTOMATIC WASHER
Kenmore 11020936992 AUTOMATIC WASHER
Kenmore 11020936993 WASHER
Kenmore 11020936994 WASHER
Kenmore 11020942990 AUTOMATIC WASHER
Kenmore 11020942991 AUTOMATIC WASHER
Kenmore 11020942992 AUTOMATIC WASHER
Kenmore 11020942993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020942994 WASHER
Kenmore 11020952990 AUTOMATIC WASHER
Kenmore 11020952991 AUTOMATIC WASHER
Kenmore 11020952992 AUTOMATIC WASHER
Kenmore 11020952993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020952994 WASHER
Kenmore 11020954992 AUTOMATIC WASHER
Kenmore 11020954993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020954994 WASHER
Kenmore 11020956990 AUTOMATIC WASHER
Kenmore 11020956991 AUTOMATIC WASHER
Kenmore 11020956992 AUTOMATIC WASHER
Kenmore 11020956993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020956994 WASHER
Kenmore 11020957990 AUTOMATIC WASHER
Kenmore 11020957991 AUTOMATIC WASHER
Kenmore 11020957992 AUTOMATIC WASHER
Kenmore 11020972990 WASHER
Kenmore 11020972991 WASHER
Kenmore 11020972992 WASHER
Kenmore 11020972993 WASHER
Kenmore 11020982990 WASHER
Kenmore 11020982991 WASHER
Kenmore 11020982992 WASHER
Kenmore 11020982993 WASHER
Kenmore 11020992990 WASHER
Kenmore 11020992991 WASHER
Kenmore 11020992992 WASHER
Kenmore 11020992993 WASHER
Kenmore 11020994991 WASHER
Kenmore 11020994992 WASHER
Kenmore 11020994993 WASHER
Kenmore 11020996991 WASHER
Kenmore 11020996992 WASHER
Kenmore 11020996993 WASHER
Kenmore 11020997990 WASHER
Kenmore 11020997991 WASHER
Kenmore 11020997992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021102010 AUTOMATIC WASHER
Kenmore 11021102011 AUTOMATIC WASHER
Kenmore 11021112010 AUTOMATIC WASHER
Kenmore 11021112011 AUTOMATIC WASHER
Kenmore 11021182010 AUTOMATIC WASHER
Kenmore 11021182011 AUTOMATIC WASHER
Kenmore 11021202010 AUTOMATIC WASHER
Kenmore 11021202011 AUTOMATIC WASHER
Kenmore 11021252110 AUTOMATIC WASHER
Kenmore 11021292010 AUTOMATIC WASHER
Kenmore 11021292011 AUTOMATIC WASHER
Kenmore 11021302010 AUTOMATIC WASHER
Kenmore 11021302011 AUTOMATIC WASHER
Kenmore 11021352110 AUTOMATIC WASHER
Kenmore 11021392010 AUTOMATIC WASHER
Kenmore 11021392011 AUTOMATIC WASHER
Kenmore 11021392012 AUTOMATIC WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
Kenmore 11022042102 AUTOMATIC
Kenmore 11022052100 WASHER
Kenmore 11022052101 WASHER
Kenmore 11022052102 AUTOMATIC WASHER
Kenmore 11022054100 WASHER
Kenmore 11022054101 WASHER
Kenmore 11022054102 AUTOMATIC WASHER
Kenmore 11022056100 WASHER
Kenmore 11022056101 WASHER
Kenmore 11022056102 AUTOMATIC WASHER
Kenmore 11022062100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022062101 WASHER
Kenmore 11022062102 AUTOMATIC WASHER
  #2 (permalink)
Old 05-20-2013, 11:48 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Most likely the problem is with the Speed selector switch. The best way to diagnose this is to check the amps draw. If the current draw is more then rated (9.8 amps max) the switch is bad , if less then most likely it's the motor.
Before replacing parts check the motor plug connections.
The switch Part number: 3953144
The motor Part number: 3352287
Thank you. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 05-21-2013, 01:58 PM
Junior Member
Default Possible cause may be partially jamming coupler?
I took the machine apart last night and found a pile of soft black dust under the front of the motor. This sure looks like a motor coupling issue to me. I was also thinking this would probably account for the lights dimming issue if the agitator turned a small amount and then jammed (motor stall would pull a good deal of current - i.e. lights dim). The coupler can't be completely broken or the spin cycle would not work. I tried the spin cycle again, and it does have a bit of a hitch when it first starts which I'm guessing is getting past the jam in the coupler. Once it gets past that it spins fine....I'm going to try to remove the coupler tonight and see if the problem goes away. If it's a purely electrical problem, then the problem will still be there. If it is caused by a mechanical partial jam (coupler), then I won't see any problem other than I won't get any agitation or spin. If you have any other ideas, let me know. I'll try to update once I do the next test.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tub doesn't spin or agitate, makes clicking noise KTitcomb Washer Repair 0 10-24-2011 02:47 PM
timer makes clicking noise washer won't agitate or spin gman4psu Washer Repair 0 11-27-2009 06:40 AM
Top load kenmore, getting a clicking noise kahne905 Washer Repair 1 04-16-2009 05:03 PM
Kenmore Gas Range Not Clicking elee Oven Repair (including Ranges and Cooktops) 3 12-09-2008 02:27 PM
kenmore clicking joel95ex Refrigerator & Freezer Repair 0 07-08-2008 09:27 AM
