Discuss
Kenmore 800 Series Washer Issues
 in
Washer Repair
In starting my washer, my wife said it was only filling with hot water even when set on cold. I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 800 Series Washer Issues
  #1 (permalink)
Old 05-19-2013, 05:03 PM
Junior Member
mattcherbrown is on a distinguished road
Default Kenmore 800 Series Washer Issues
Brand: Kenmore   Age: 1 - 5 years
In starting my washer, my wife said it was only filling with hot water even when set on cold. I turned off the hot water and the cold water would run for a bit and then shut off. I would turn off the washer and turn it back on. The cold water would then run for a bit and stop again. I did this until the washer was full. Once filled up, it ran the wash cycle but seems to stop at the first rinse cycle. I can turn the knob to spin and it does fine.
I have tried this on all settings and got the same results. Not really sure where to start with diagnosing the problem here. I haven't seen any posts with the same type issues I am having. Any help would be greatly appreciated.
  #2 (permalink)
Old 05-20-2013, 06:53 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
We need the model number of your washer.
Eric
  #3 (permalink)
Old 05-20-2013, 06:53 PM
Junior Member
Default
model - 27831600
Serial - CU2740308
  #4 (permalink)
Old 05-20-2013, 08:59 PM
Expert
APP Volunteer
Default
Could be the ATC (smart auto temp control switch) which regulates the water solenoid valves but that wouldn't affect the timer. This washer also has a timer delay board. I'm not familiar with this model nor do I have the wiring diagram and timer chart for it. Could also be a problem with the water inlet valve (clogged valves, faulty thermistor).
Eric
  #5 (permalink)
Old 05-21-2013, 05:33 AM
Junior Member
Default
Thanks Eric. If it were you, which would you replace first or is there a way to check these with a meter to see if they are working properly?
  #6 (permalink)
Old 05-21-2013, 06:37 AM
Expert
APP Volunteer
Default
I would first check the voltages at the water inlet valve solenoids. When set for cold water and filling, you should have 120vac across the cold water solenoid connector. The ATC will cycle these solenoids on/off to turn the hot/cold water valves on/off depending on temp settings. You should be able to determine if the problem is the ATC or the valves. I can help further if you post a clear photo of the wiring diagram and timer chart that should be on the upper left side of the inside of the back panel near the top. You will need to remove the cabinet to get to the water inlet valves anyway.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer Issues MIKEFINK Washer Repair 1 02-02-2012 07:11 PM
Kenmore Model 80 washer coupler/tranny issues Ken More Washer Repair 1 01-08-2012 06:21 PM
Kenmore series 90 water filling issues brian97 Washer Repair 3 05-21-2011 08:23 PM
Kenmore washer timer issues? Help please. ffspiel Washer Repair 2 06-06-2010 06:10 PM
Kenmore Washer issues- starts by itself sainadh Washer Repair 4 09-01-2009 06:09 AM
