Discuss
Un-responsive Maytag
 in
Washer Repair
Got an un-responsive / dead Maytag MAH-8700AWW, checked all of the test points from the manual. Door switch 60 ohms
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Un-responsive Maytag
  #1 (permalink)
Old 05-17-2013, 02:46 PM
Junior Member
trcim4pu is on a distinguished road
Default Un-responsive Maytag
Model Number: MAH-8700AWW   Brand: Maytag   Age: 5 - 10 years
Got an un-responsive / dead Maytag MAH-8700AWW, checked all of the test points from the manual. Door switch 60 ohms (2x), Motor coils all 3 ohms, Thermistor 13.4K Ohms, water valves all 1100 Ohms, AC power at 120V, reactor less that 1 ohm. The open door switch has the incorrect voltage when open (supposed to be 5 V, at 2.5 V). The thermistor voltage is also incorrect (at 1.4V, supposed to be at 2.5V). Assuming this is likely the control board that is the problem. Anything else to check before I try to order the control board? Everywhere I check, this control board is out of stock. Any idea how long it would really take to get this board if ordered? Thanks for the help.
Related Models
Maytag MAH14PDAAL MANUAL, PARTS (WASHER)
Maytag MAH14PDAAQ MANUAL, PARTS (WASHER)
Maytag MAH14PDAAW MANUAL, PARTS (WASHER)
Maytag MAH14PDABL MANUAL, PARTS (WASHER)
Maytag MAH14PDABW MANUAL, PARTS (WASHER)
Maytag MAH14PDAEW MANUAL, PARTS (WASHER)
Maytag MAH14PDAGW MANUAL, PARTS (WASHER)
Maytag MAH14PDBAW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDBEW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDBGW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDCBQ MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDCBW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDDWW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDSAW MANUAL, PARTS (WASHER)
Maytag MAH14PNAEW MANUAL, PARTS (WASHER)
Maytag MAH14PNAGW MANUAL, PARTS (WASHER)
Maytag MAH14PNAWW MANUAL, PARTS (WASHER)
Maytag MAH14PNBAW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PNBEW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PNBGW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PNSAW MANUAL, PARTS (WASHER)
Maytag MAH14PRAWW MANUAL, PARTS (WASHER)
Maytag MAH14PSAAW MANUAL, PARTS (WASHER)
Maytag MAH20PDA3W MAYTAG LAUNDRY (WASHER)
Maytag MAH20PDAWQ MAYTAG LAUNDRY (WASHER)
Maytag MAH20PDAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PDCXQ MAYTAG LAUNDRY (WASHER)
Maytag MAH20PDCXW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PNAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PRAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PRDWW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PSAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDA3W MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDAGW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDAWQ MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDCXQ MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDCXW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDD3W LAUNDRY PRODUCT (WASHER)
Maytag MAH21PDDGW LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PDDWQ LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PDDWW LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PDDXW LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PNAGW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PNAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PNDGW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PNDWW LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PRAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PRDWW LAUNDRY PRODUCT (WASHER)
Maytag MAH21PSAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PSDWW LAUNDRY PRODUCT (WASHER)
Maytag MAH22PDAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PDAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PDAWW1 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PDAXW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PDAXW1 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PDBWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PDBXW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PNAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PRAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PRAWW1 COMMERCIAL AUTOMATIC WASHER
Maytag MAH22PRBWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAH2400AWW WASHER- HORIZONTAL AXIS
Maytag MAH2440AGW WASHER- HORIZONTAL AXIS
Maytag MAH2440BGW WASHER- HORIZONTAL AXIS
Maytag MAH3000AAW WASHER- HORIZONTAL AXIS
Maytag MAH3000AEW WASHER- HORIZONTAL AXIS
Admiral MAH3000AGW WASHER- HORIZONTAL AXIS
Admiral MAH3000AKW WASHER- HORIZONTAL AXIS
Maytag MAH3000AWA WASHER- HORIZONTAL AXIS
Maytag MAH3000AWQ WASHER- HORIZONTAL AXIS
Maytag MAH3000AWW WASHER- HORIZONTAL AXIS
Admiral MAH3000BGW WASHER- HORIZONTAL AXIS
Maytag MAH4000AWQ WASHER- HORIZONTAL AXIS
Maytag MAH4000AWW WASHER- HORIZONTAL AXIS
Maytag MAH4000BWQ WASHER- HORIZONTAL AXIS
Maytag MAH4000BWW WASHER- HORIZONTAL AXIS
Maytag MAH5500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH5500AWW WASHER- HORIZONTAL AXIS
Maytag MAH5500BWQ WASHER- HORIZONTAL AXIS
Maytag MAH5500BWW WASHER- HORIZONTAL AXIS
Maytag MAH55FLBWQ WASHER- HORIZONTAL AXIS
Maytag MAH55FLBWW WASHER- HORIZONTAL AXIS
Maytag MAH6500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH6500AWW WASHER- HORIZONTAL AXIS
Maytag MAH6700AWM WASHER- HORIZONTAL AXIS
Maytag MAH6700AWW WASHER- HORIZONTAL AXIS
Maytag MAH7500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH7500AWW WASHER- HORIZONTAL AXIS
Admiral MAH7550AAW WASHER- HORIZONTAL AXIS
Admiral MAH7550AGW WASHER- HORIZONTAL AXIS
Maytag MAH8700AWM WASHER- HORIZONTAL AXIS
Maytag MAH8700AWW WASHER- HORIZONTAL AXIS
Maytag MAH9700AWM WASHER- HORIZONTAL AXIS
Maytag MAH9700AWQ WASHER- HORIZONTAL AXIS
Maytag MAH9700AWW WASHER- HORIZONTAL AXIS
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM MISC / ACCESSORY
Maytag MAL1800AXQ MISC / ACCESSORY
Maytag MAL1800AXW MISC / ACCESSORY
Maytag MAL2000AXQ MISC / ACCESSORY
Maytag MAL2000AXW MISC / ACCESSORY
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL MANUAL, PARTS (WASHER)
Maytag MAT10CSAAW MANUAL, PARTS (WASHER)
Maytag MAT10CSAGL MANUAL, PARTS (WASHER)
Maytag MAT10CSAGW MANUAL, PARTS (WASHER)
Maytag MAT10CSEGL MANUAL, PARTS (WASHER)
Maytag MAT10CSEGW MANUAL, PARTS (WASHER)
Maytag MAT10DAAAL MANUAL, PARTS (WASHER)
Maytag MAT10DAAAW MANUAL, PARTS (WASHER)
Maytag MAT10DAABL MANUAL, PARTS (WASHER)
Maytag MAT10DAABW MANUAL, PARTS (WASHER)
Maytag MAT10PDAAL MANUAL, PARTS (WASHER)
Maytag MAT10PDAAW MANUAL, PARTS (WASHER)
Maytag MAT10PDABL MANUAL, PARTS (WASHER)
Maytag MAT10PDABW MANUAL, PARTS (WASHER)
Maytag MAT10PDEGW MAYTAG LAUNDRY (COMM.EXPORT) (WASHER)
Maytag MAT10PSAAL MANUAL, PARTS (WASHER)
Maytag MAT10PSAAW MANUAL, PARTS (WASHER)
  #2 (permalink)
Old 05-17-2013, 04:55 PM
Senior Member
scott5495 is on a distinguished road
Default maytag
the original part no. has changed. go online to cashwells.com enter no. and sub no. will come up. available
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Non responsive control panel ebhahn Dishwasher Repair 0 03-02-2013 01:51 PM
Frigidaire Refrigerator Console Non-Responsive siliconghost Refrigerator & Freezer Repair 1 11-23-2012 11:04 AM
Control Pad Not Responsive ASaxena Dishwasher Repair 8 12-19-2011 04:01 AM
Bake button non-responsive clarkdo Oven Repair (including Ranges and Cooktops) 0 01-01-2011 10:34 AM
freezer temp not responsive to controls pbode Refrigerator & Freezer Repair 0 05-26-2010 06:02 AM
