Hello All,
I've been having trouble finding an issue with a GE stackable Model #WSM2700HEWWW.
The washer will fill with water, but it will not agitate. It will spin on the spin cycle, but the water will not pump out. The pump will work, because it runs when I bypass the lid switch. I have voltage going to the lid switch, but it is not getting to the pump. I've checked the wiring from the lid switch to the pump and I have continuity.
To this point, I have changed the timer and the lid switch. I even thought I may have gotten defective parts, so I ordered a new batch of timers and lid switches (I work at a complex, so I normally stock these items), and it still has not fixed my problem. I've checked the woring harness for broken connections and I have not found any yet.
I am about to beat my head off the wall with this one. Does anyone have any ideas?
Thanks in advance.
ETA: It will agaitate in other cycles, just not the regular cycle.
check the water pressure switch. the contacts may not be closing after it fills. check schematic and cross the wires. it is unusual, but i have seen this happen.
OK, the pressure switch did not take care of it.
Check the schematic and cross the wires? The wires to the fill valve or somewhere else?
