Discuss
whirlpool duet sport error code F33
 in
Washer Repair
How do I manually unlock my washer door, if error code is flashing F33, and it will not complete any
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool duet sport error code F33
  #1 (permalink)
Old 05-17-2013, 09:27 AM
Junior Member
dearie47s is on a distinguished road
Exclamation whirlpool duet sport error code F33
Brand: -brand-   Age: 1 - 5 years
How do I manually unlock my washer door, if error code is flashing F33, and it will not complete any cycles? What is F33?
  #2 (permalink)
Old 05-17-2013, 12:29 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Dearie, The F33 error indicates there's an issue with the drain pump or wiring between the drain pump and the CCU (central control unit). Does the washer drain ? If the washer doesn't drain, the door stays locked and the washer wont spin, either.
Manually Unlocking the Door Lock System 1. Unplug washer or disconnect power. 2. Remove the lower kick panel. 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. Located on the bottom of the door switch/lock unit is a teardrop shaped tab. 5. Gently pull the tab down about a 1/4˝ or until a click is heard. 6. The door may be opened.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Sport washer F-01 error Penypincher Washer Repair 3 01-24-2015 05:09 PM
Whirlpool Duet Sport Error Code F30 rayp11n Washer Repair 15 06-30-2013 10:21 AM
Whirlpool Duet Sport Error Code F30 #2 beachboy90266 Washer Repair 1 11-15-2010 06:11 PM
Whirlpool Duet sport has code P-01 and P-26 rothba Dryer Repair 0 09-04-2010 09:48 AM
Duet Sport F01 error Code vposton Washer Repair 2 09-15-2007 07:20 AM
