Discuss
mayatg brovos top load hce
 in
Washer Repair
Drain stopped up with big towel. Can't pull out drain hole. need to remove drum. Remaved agitator but can't remove
Appliance Repair Forum > Appliance Repair Help > Washer Repair » mayatg brovos top load hce
  #1 (permalink)
Old 05-16-2013, 02:53 PM
Junior Member
allengiddens is on a distinguished road
Default mayatg brovos top load hce
Model Number: mvwb750wq1   Brand: Maytag   Age: 1 - 5 years
Drain stopped up with big towel. Can't pull out drain hole. need to remove drum. Remaved agitator but can't remove drum. Took off plastic mount over drum that had 6 screws but still can't remove.
Related Models
Maytag MVWB750WQ1 AUTOMATIC WASHER
Maytag MVWB750WR0 AUTOMATIC WASHER
Maytag MVWB750WR1 AUTOMATIC WASHER
Maytag MVWB800VB0 AUTOMATIC WASHER
Maytag MVWB800VQ0 AUTOMATIC WASHER
Maytag MVWB800VU0 AUTOMATIC WASHER
Maytag MVWB850WB0 AUTOMATIC WASHER
Maytag MVWB850WB1 AUTOMATIC WASHER
Maytag MVWB850WL0 AUTOMATIC WASHER
Maytag MVWB850WL1 AUTOMATIC WASHER
Maytag MVWB850WQ0 AUTOMATIC WASHER
Maytag MVWB850WQ1 AUTOMATIC WASHER
Maytag MVWB850WR0 AUTOMATIC WASHER
Maytag MVWB850WR1 AUTOMATIC WASHER
Maytag MVWC300VW0 AUTOMATIC WASHER
Maytag MVWC300VW1 AUTOMATIC WASHER
Maytag MVWC400VW0 AUTOMATIC WASHER
Maytag MVWC400VW1 AUTOMATIC WASHER
Maytag MVWC450WW0 AUTOMATIC WASHER
Maytag MVWC500VW0 AUTOMATIC WASHER
Maytag MVWC500VW1 AUTOMATIC WASHER
Maytag MVWC5ESXW0 AUTOMATIC WASHER
Maytag MVWC6ESWW0 AUTOMATIC WASHER
Maytag MVWC6ESWW1 AUTOMATIC WASHER
Maytag MVWC700VJ0 AUTOMATIC WASHER
Maytag MVWC700VJ1 AUTOMATIC WASHER
Maytag MVWC700VW0 AUTOMATIC WASHER
Maytag MVWC700VW1 AUTOMATIC WASHER
Maytag MVWC7ESWW0 AUTOMATIC WASHER
Maytag MVWX500XL0 AUTOMATIC WASHER
Maytag MVWX500XW0 AUTOMATIC WASHER
Maytag MVWX550XW0 AUTOMATIC WASHER
Maytag MVWX600XW0 AUTOMATIC WASHER
Maytag MVWX700XL0 AUTOMATIC WASHER
Maytag MVWX700XW0 AUTOMATIC WASHER
Whirlpool MW1000XP0 Microwaves*
Whirlpool MW1000XP1 Microwaves*
Whirlpool MW1000XS0 MICROWAVE
Whirlpool MW1000XS1 Microwaves*
Whirlpool MW1000XW0 Microwaves*
 MW1030BA MWAVE- CNTRTP / STAND ALONE
 MW1030SB MWAVE- CNTRTP / STAND ALONE
 MW1030SB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1030WA MWAVE- CNTRTP / STAND ALONE
 MW1040BC MWAVE- CNTRTP / STAND ALONE
 MW1040BC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1040WC MWAVE- CNTRTP / STAND ALONE
 MW1040WC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1080STA MWAVE- CNTRTP / STAND ALONE
 MW1135WB MWAVE- CNTRTP / STAND ALONE
 MW1135WB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1150WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1200XP0 Microwaves*
Whirlpool MW1200XP1 Microwaves*
Whirlpool MW1200XS0 Microwaves*
Whirlpool MW1200XS1 MICROWAVE
Whirlpool MW1200XW0 Microwaves*
Whirlpool MW120EXP0 Microwaves*
 MW1245BB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1500XP0 Microwaves*
Whirlpool MW1500XP1 Microwaves*
Whirlpool MW1500XS0 Microwaves*
Whirlpool MW1500XS1 Microwaves*
Whirlpool MW1500XW0 Microwaves*
Whirlpool MW1501XS1 Microwaves*
Whirlpool MW1501XW0 Microwaves*
Roper MW157 Microwave
Maytag MW29000TB0 LAUNDRY WORKSURFACE
Maytag MW29000TU0 LAUNDRY WORKSURFACE
Maytag MW29000TW0 LAUNDRY WORKSURFACE
Whirlpool MW3000XM0 Microwaves*
Whirlpool MW3000XM1 Microwaves*
Whirlpool MW3000XP0 Microwaves*
Whirlpool MW3000XP1 Microwaves*
Whirlpool MW3000XP2 Microwaves*
Whirlpool MW3200XM0 Microwave
Whirlpool MW3200XM1 Microwave
Whirlpool MW3200XP0 Microwave
Whirlpool MW3200XP1 Microwave
Whirlpool MW3200XP2 Microwave
Whirlpool MW3200XS0 Microwave
Whirlpool MW3200XW0 Microwave
Whirlpool MW3500XM0 Microwaves*
Whirlpool MW3500XM1 Microwaves*
Whirlpool MW3500XP1 Microwaves*
Whirlpool MW3500XP2 Microwaves*
Whirlpool MW3500XP3 Microwaves*
Whirlpool MW3500XS0 Microwaves*
Whirlpool MW3500XW0 Microwaves*
Whirlpool MW3520XP1 Microwaves*
Whirlpool MW3520XP2 Microwaves*
Whirlpool MW3520XP3 Microwaves*
Whirlpool MW352EXP1 Microwaves*
Whirlpool MW3600XS0 Microwaves*
Whirlpool MW3600XW0 Microwaves*
Whirlpool MW3600XW1 Microwaves*
Whirlpool MW3601XS0 Microwaves*
Whirlpool MW3601XW0 Microwaves*
Whirlpool MW3601XW1 Microwaves*
Amana MW41 MWAVE- CNTRTP / STAND ALONE
Amana MW42 MWAVE- CNTRTP / STAND ALONE
Amana MW43 MWAVE- CNTRTP / STAND ALONE
Amana MW500.000 COMMERCIAL MICROWAVES
 MW5380W MWAVE- CNTRTP / STAND ALONE
Roper MW557 Microwave
Roper MW5571 Microwaves
 MW5592W MWAVE- CNTRTP / STAND ALONE
 MW5592W/XAA MWAVE- CNTRTP / STAND ALONE
Amana MW56 MWAVE- CNTRTP / STAND ALONE
Amana MW57 MWAVE- CNTRTP / STAND ALONE
Amana MW58 MWAVE- CNTRTP / STAND ALONE
Amana MW600.000 COMMERCIAL MICROWAVES
 MW640BA MWAVE- CNTRTP / STAND ALONE
 MW640WA MWAVE- CNTRTP / STAND ALONE
  #2 (permalink)
Old 05-17-2013, 01:06 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Allen, Apparently you've also damaged the hub drive assembly
Part number: AP3892170
You may want to slide a long strap, belt or rope, under the tub, center it as best possible and use that to lift up on the tub to break it loose from the shaft drive hub.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 05-17-2013, 01:15 PM
Junior Member
Default Removed hub
I removed the hub after the agitator. It is ok but cannot get out inner tub to get to towel stopping up drain. You are saying once hub off tub should lift up over shaft
  #4 (permalink)
Old 05-17-2013, 01:51 PM
Senior Expert
Default
Allen, Correct
"to remove the basket
a) Loosen the clamp and pull the recirculation hose off the tub ring.
b) Pry out and unsnap the tub ring tabs from the tub and remove the tub ring.
c) Insert the blade of a small screwdriver into the slot in the impeller cap, then pry the cap up, and remove it.
d) Remove the 7/16˝ hex-head bolt from
the impeller, then lift and remove the
impeller from the basket. NOTE: Lifting
the basket will assist in removing
the impeller.
e) Lift the basket out of the washer.
4. To remove the basket hub, remove the
six screws, and lift the hub assembly from the basket."
The tub can be awkward and a little difficult to remove, but not like you're describing it. Unless the hub gears have seized together.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
matag brovos anthony rizzolo Washer Repair 1 02-16-2011 10:08 AM
Mayatg repair washer arms clogged bobp0626 Dishwasher Repair 1 07-23-2010 07:31 AM
Load Thumping Noise & Unbalanced Condition On GE front load washer Luke Vincent Washer Repair 2 08-06-2009 05:43 PM
Maytag Brovos motor won't start bucklake Washer Repair 1 01-11-2009 05:29 AM
