Discuss
Washer will not drain
 in
Washer Repair
Washer is in a coin op facility. The machine will run through all cycles appropriately, but will not drain. During
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not drain
  #1 (permalink)
Old 05-16-2013, 09:36 AM
Junior Member
PepperVal is on a distinguished road
Default Washer will not drain
Model Number: MAT23PCAAL   Brand: Maytag   Age: More than 10 years
Washer is in a coin op facility. The machine will run through all cycles appropriately, but will not drain. During the drain cycle; the drum spins, pump and hoses are not clogged, belt is good, no funny smells.
In addition: What is the process behind the drain cycle? The pump is not operated electronically, so does it have something to do with the brake?
Related Models
Maytag MAT23PCAAL MANUAL, PARTS (WASHER)
Maytag MAT23PCAAW MANUAL, PARTS (WASHER)
Maytag MAT23PCABG MANUAL, PARTS (WASHER)
Maytag MAT23PCABL MANUAL, PARTS (WASHER)
Maytag MAT23PCABW MANUAL, PARTS (WASHER)
Maytag MAT25CSAAG MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAAL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAAW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAGG MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSAGL MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSAGW MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSBIL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSCAG MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSCAL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSCAW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSEGG MAYTAG COMMERCIAL (EXPORT) (WASHER)
Maytag MAT25CSEGL MAYTAG COMMERCIAL (EXPORT) (WASHER)
Maytag MAT25CSEGW MAYTAG COMMERCIAL (EXPORT) (WASHER)
Maytag MAT25CTAAG MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CTAAL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CTAAW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25DAAAL MANUAL, PARTS (WASHER)
Maytag MAT25DAAAM MANUAL, PARTS (WASHER)
Maytag MAT25DAAAW MANUAL, PARTS (WASHER)
Maytag MAT25DAABL MANUAL, PARTS (WASHER)
Maytag MAT25DAABW MANUAL, PARTS (WASHER)
Maytag MAT25MNAAG MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25MNAAL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25MNAAW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25MNAGW MAYTAG COMMERCIAL (EXPORT) (WASHER)
Maytag MAT26MNAAG MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT26MNAAL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT26MNAAW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT26PCAAG MANUAL, PARTS (WASHER)
Maytag MAT26PCAAL MANUAL, PARTS (WASHER)
Maytag MAT26PCAAW MANUAL, PARTS (WASHER)
Maytag MAT26PCABG MANUAL, PARTS (WASHER)
Maytag MAT26PCABL MANUAL, PARTS (WASHER)
Maytag MAT26PCABW MANUAL, PARTS (WASHER)
Maytag MAV1655AWW WASHER-TOP LOADING
Maytag MAV1755AWW WASHER-TOP LOADING
Maytag MAV208DAWW WASHER-TOP LOADING
Admiral MAV2200AJW WASHER-TOP LOADING
Maytag MAV2755AJW WASHER-TOP LOADING
Maytag MAV2755AWW WASHER-TOP LOADING
Maytag MAV2757AWW WASHER-TOP LOADING
Maytag MAV275SAWW WASHER-TOP LOADING
Maytag MAV308DAWW WASHER-TOP LOADING
Admiral MAV3350AGW WASHER-TOP LOADING
Maytag MAV3757AWW WASHER-TOP LOADING
Maytag MAV3758AWW WASHER-TOP LOADING
Maytag MAV3855AGW WASHER-TOP LOADING
Maytag MAV3855AKW WASHER-TOP LOADING
Maytag MAV3855AWW WASHER-TOP LOADING
Maytag MAV385SAWW WASHER-TOP LOADING
Maytag MAV3905AWW WASHER-TOP LOADING
Maytag MAV3955EWW WASHER-TOP LOADING
Maytag MAV4057AWQ WASHER, ATLANTIS
Maytag MAV4057AWW WASHER, ATLANTIS
Maytag MAV408DAWK WASHER-TOP LOADING
Maytag MAV408DAWW WASHER-TOP LOADING
Maytag MAV4500AWW WASHER, ATLANTIS
Maytag MAV4755AWW WASHER-TOP LOADING
Maytag MAV4757AWW WASHER-TOP LOADING
Maytag MAV4758AWW WASHER-TOP LOADING
Maytag MAV5000AWQ WASHER, ATLANTIS
Maytag MAV5000AWW WASHER, ATLANTIS
Maytag MAV5057AWQ WASHER, ATLANTIS
Maytag MAV5057AWW WASHER, ATLANTIS
Maytag MAV551EEWW WASHER-TOP LOADING
Maytag MAV5758EWW WASHER-TOP LOADING
Maytag MAV5920AGW WASHER-TOP LOADING
Maytag MAV5920EWK WASHER-TOP LOADING
Maytag MAV5920EWW WASHER-TOP LOADING
Maytag MAV5960AWW WASHER, ATLANTIS
Maytag MAV6000AWQ WASHER, ATLANTIS
Maytag MAV6000AWW WASHER, ATLANTIS
Maytag MAV6057AWQ WASHER, ATLANTIS
Maytag MAV6057AWW WASHER, ATLANTIS
Maytag MAV6200AWQ WASHER, ATLANTIS
Maytag MAV6200AWW WASHER, ATLANTIS
Maytag MAV6250AWQ WASHER, ATLANTIS
Maytag MAV6250AWW WASHER, ATLANTIS
Maytag MAV6257AWQ WASHER, ATLANTIS
Maytag MAV6257AWW WASHER, ATLANTIS
Maytag MAV6260AWW WASHER, ATLANTIS
Admiral MAV6300AGW WASHER-TOP LOADING
Maytag MAV6300AWQ WASHER, ATLANTIS
Maytag MAV6300AWW WASHER, ATLANTIS
Admiral MAV6300BGW WASHER-TOP LOADING
Admiral MAV6300CGW WASHER-TOP LOADING
Maytag MAV6357AWW WASHER, ATLANTIS
Maytag MAV6358AWW WASHER, ATLANTIS
Maytag MAV6451AGW WASHER, ATLANTIS
Maytag MAV6451AWQ WASHER, ATLANTIS
Maytag MAV6451AWW WASHER, ATLANTIS
Maytag MAV6457AWW WASHER, ATLANTIS
Maytag MAV6458AWW WASHER, ATLANTIS
Maytag MAV6548AWQ WASHER, ATLANTIS
Maytag MAV6548AWW WASHER, ATLANTIS
Maytag MAV6601AWQ WASHER, ATLANTIS
Maytag MAV6601AWW WASHER, ATLANTIS
Maytag MAV6650AWW WASHER, ATLANTIS
Maytag MAV7000AWQ WASHER, ATLANTIS
Maytag MAV7000AWW WASHER, ATLANTIS
Maytag MAV7057AWQ WASHER, ATLANTIS
Maytag MAV7057AWW WASHER, ATLANTIS
Maytag MAV7200AWQ WASHER, ATLANTIS
Maytag MAV7200AWW WASHER, ATLANTIS
Maytag MAV7257AWQ WASHER, ATLANTIS
Maytag MAV7257AWW WASHER, ATLANTIS
Maytag MAV7258AWQ WASHER, ATLANTIS
Maytag MAV7258AWW WASHER, ATLANTIS
Maytag MAV7260AWW WASHER, ATLANTIS
Maytag MAV7260BWW WASHER, ATLANTIS
Maytag MAV7357AWQ WASHER, ATLANTIS
Maytag MAV7357AWW WASHER, ATLANTIS
Maytag MAV7358AWQ WASHER, ATLANTIS
Maytag MAV7358AWW WASHER, ATLANTIS
Maytag MAV7450AWQ WASHER, ATLANTIS
  #2 (permalink)
Old 05-16-2013, 10:24 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
The motor runs in opposite directions depending whether it's in agitate or spin mode. Only in spin mode, does the pump rotate in a direction that pumps the water out. If it rotates freely and there is no clog in the pump or hoses, either the pump impeller is bad or there is clothing between the tubs at the drain exit.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stacked Washer/Dryer Washer won't drain Uncle Milt Washer Repair 1 10-18-2012 08:58 AM
Washer will only drain if put on "Drain+Spin" cycle. Arieleno Washer Repair 7 11-02-2011 07:03 PM
Washer didn't drain washerfixmyself Washer Repair 1 08-12-2010 05:37 PM
My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? ks_becker Washer Repair 0 08-10-2010 10:25 AM
Calypso Washer Washer Won't Drain SamB Washer Repair 3 11-27-2007 01:41 PM
