| » Cycle Stops |
Model Number: LSR6332KQO Brand: Whirlpool Age: 5 - 10 years
The washer fills up and agitates fine ( I think). Then it just stops, doesn't drain, doesn't spin etc. If i turn the dail back to agitate it turns on again and agitates again but only until it hits the spin section of the dial. It also will not turn on at all if I advance the dial past the spin cycle.
I am assuming this is a timer problem but am not 100% positive. I've read a few posts that make me believe it might be the door switch? Before I order a new timer how do I check if the door switch is the problem? Please help. Ads By Google Related Models |
Most likely the problem is a bad lid switch (#11 on the diagram).
You can bypass the switch after you open the control panel to make sure the problem is there. - The lid switch Part number: AP3100003 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSR6332KQ0 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Dryer stops mid cycle, restarts, then stops | RayD | Dryer Repair | 4 | 06-07-2012 07:08 AM |
| washing machine stops after agitating cycle, doesn't drain or proceed to next cycle | jjd2009 | Washer Repair | 2 | 11-13-2009 06:31 AM |
| Maytag SE 1000 washer stops mid cycle or won't start wash cycle | katyat | Washer Repair | 1 | 09-11-2009 04:15 PM |
| Dishwasher skips the wash cycle and stops at the rinse cycle | jasporo | Dishwasher Repair | 6 | 06-08-2009 04:11 PM |
| Stops mid cycle | kcicero | Washer Repair | 2 | 11-16-2008 09:26 AM |
