Discuss
Why does this Electrolux dryer vibrate?
 in
Washer Repair
This dryer vibrates (sounds like the element and its shroud is where it originates) after it has heated to its
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Why does this Electrolux dryer vibrate?
  #1 (permalink)
Old 05-15-2013, 12:19 PM
Member
jamie_pancake@yahoo.com is on a distinguished road
Default Why does this Electrolux dryer vibrate?
Model Number: GLER341AS2   Brand: Electrolux   Age: 5 - 10 years
This dryer vibrates (sounds like the element and its shroud is where it originates) after it has heated to its maximum temp.( about 174F from inside the drum read with an electronic tester.) at the very point where the regulating thermostat cuts off the motor amps raises .2 amps and a very noticable vibration begins. The motor amps stays within normal and the vent and lint duct are ok. T he element is not grounded. Any Ideas?
Related Models
Frigidaire GLER341AS2 Frigidaire/electric Dryer
Frigidaire GLER341CC0 Frigidaire/dryer
Frigidaire GLER341CDC0 Frigidaire/dryer
Frigidaire GLER341CES0 Frigidaire/dryer
Whirlpool GLER5434BN0 ELECTRIC DRYER
Whirlpool GLER5434BN1 ELECTRIC DRYER
Whirlpool GLER5434BQ1 ELECTRIC DRYER
Whirlpool GLER5434BW0 ELECTRIC DRYER
Whirlpool GLER5434BW1 ELECTRIC DRYER
Frigidaire GLER642AS0 Dryer - Frigidaire Gallery
Frigidaire GLER642AS1 Dryer - Frigidaire Gallery
Frigidaire GLER642AS2 Dryer - Frig Gallery
Frigidaire GLER642AS3 Frigidaire/dryer
Frigidaire GLES388ASA Frigidaire/electric Range
Frigidaire GLES388ASB Frigidaire/electric Range
Frigidaire GLES388ASC Frigidaire/electric Range
Frigidaire GLES388ASD Frigidaire/electric Range
Frigidaire GLES388ASE Frigidaire/electric Range
Frigidaire GLES388CSA Frigidaire/electric Range
Frigidaire GLES388CSB Frigidaire/electric Range
Frigidaire GLES388DBA Frigidaire/electric Range
Frigidaire GLES388DBB Frigidaire/electric Range
Frigidaire GLES388DQA Frigidaire/electric Range
Frigidaire GLES388DQB Frigidaire/electric Range
Frigidaire GLES388DSA Frigidaire/electric Range
Frigidaire GLES388DSB Frigidaire/electric Range
Frigidaire GLES389EBA Frigidaire/electric Range
Frigidaire GLES389EBB Frigidaire/electric Range
Frigidaire GLES389EBC Frigidaire/electric Range
Frigidaire GLES389EBD Frigidaire/electric Range
Frigidaire GLES389EBE Frigidaire/electric Range
Frigidaire GLES389EQA Frigidaire/electric Range
Frigidaire GLES389EQB Frigidaire/electric Range
Frigidaire GLES389EQC Frigidaire/electric Range
Frigidaire GLES389EQD Frigidaire/electric Range
Frigidaire GLES389EQE Frigidaire/electric Range
Frigidaire GLES389ESA Frigidaire/electric Range
Frigidaire GLES389ESB Frigidaire/electric Range
Frigidaire GLES389ESC Frigidaire/electric Range
Frigidaire GLES389ESD Frigidaire/electric Range
Frigidaire GLES389ESE Frigidaire/electric Range
Frigidaire GLES389FBA Frigidaire/electric Range
Frigidaire GLES389FBB Frigidaire/electric Range
Frigidaire GLES389FBC ELECTRIC RANGE
Frigidaire GLES389FBD ELECTRIC RANGE
Frigidaire GLES389FBE ELECTRIC RANGE
Frigidaire GLES389FBF ELECTRIC RANGE
Frigidaire GLES389FQA Frigidaire/electric Range
Frigidaire GLES389FQB Frigidaire/electric Range
Frigidaire GLES389FSA Frigidaire/electric Range
Frigidaire GLES389FSB Frigidaire/electric Range
Frigidaire GLES389FSC ELECTRIC RANGE
Frigidaire GLES389FSD ELECTRIC RANGE
Frigidaire GLES389FSE ELECTRIC RANGE
Frigidaire GLET1031CS0 Frigidaire/laundry Center
Frigidaire GLET1031FS0 Frigidaire/laundry Center
Frigidaire GLET1031FS1 LAUNDRY CENTER
Frigidaire GLET1031FS2 LAUNDRY CENTER
Frigidaire GLET1031FS4 LAUNDRY CENTER
Frigidaire GLET1041AS0 Lc - Frig Gallery
Frigidaire GLET1041AS1 Lc - Frig Gallery
Frigidaire GLET1041AS2 Frigidaire/laundrycenter
Frigidaire GLET1142CS0 Frigidaire/laundry Center
Frigidaire GLET1142FS0 Frigidaire/laundry Center
Frigidaire GLET1142FS1 LAUNDRY CENTER
Frigidaire GLET1142FS2 LAUNDRY CENTER
Frigidaire GLFC1326FW0 Frigidaire/freezer
Frigidaire GLFC1326FW1 Frigidaire/freezer
Frigidaire GLFC1326FW2 FREEZER
Frigidaire GLFC1326FW3 FREEZER
Frigidaire GLFC1526FW0 Frigidaire/freezer
Frigidaire GLFC1526FW1 Frigidaire/freezer
Frigidaire GLFC1526FW2 FREEZER
Frigidaire GLFC1526FW3 FREEZER
Frigidaire GLFC1526FW4 FREEZER
Frigidaire GLFC1526FW5 FREEZER
Frigidaire GLFC1526FW6 FREEZER
Frigidaire GLFC1526FW7 FREEZER
Frigidaire GLFC2027FW0 Frigidaire/freezer
Frigidaire GLFC2027FW1 Frigidaire/freezer
Frigidaire GLFC2027FW2 Frigidaire/freezer
Frigidaire GLFC2027FW3 Frigidaire/freezer
Frigidaire GLFC2027FW4 FREEZER
Frigidaire GLFC2027FW5 FREEZER
Frigidaire GLFC2027FW6 FREEZER
Frigidaire GLFC2528FW0 Frigidaire/freezer
Frigidaire GLFC2528FW1 Frigidaire/freezer
Frigidaire GLFC2528FW10 FREEZER
Frigidaire GLFC2528FW2 Frigidaire/freezer
Frigidaire GLFC2528FW3 Frigidaire/freezer
Frigidaire GLFC2528FW4 FREEZER
Frigidaire GLFC2528FW5 FREEZER
Frigidaire GLFC2528FW6 FREEZER
Frigidaire GLFC2528FW7 FREEZER
Frigidaire GLFC2528FW8 FREEZER
Frigidaire GLFC2528FW9 FREEZER
Frigidaire GLFH1467GW0 FREEZER
Frigidaire GLFH1467GW1 FREEZER
Frigidaire GLFH1767GW1 FREEZER
Frigidaire GLFH1779GW0 FREEZER
Frigidaire GLFH1779GW1 FREEZER
Frigidaire GLFH1779GW2 FREEZER
Frigidaire GLFH17F8HBA FREEZER
Frigidaire GLFH17F8HBB FREEZER
Frigidaire GLFH17F8HBC FREEZER
Frigidaire GLFH17F8HBD FREEZER
Frigidaire GLFH17F8HBF FREEZER
Frigidaire GLFH17F8HBG FREEZER
Frigidaire GLFH17F8HBH FREEZER
Frigidaire GLFH17F8HWA FREEZER
Frigidaire GLFH17F8HWB FREEZER
Frigidaire GLFH17F8HWC FREEZER
Frigidaire GLFH17F8HWD FREEZER
Frigidaire GLFH17F8HWE FREEZER
Frigidaire GLFH17F8HWF FREEZER
Frigidaire GLFH17F8HWG FRIGIDAIRE/FREEZER
Frigidaire GLFH17F8HWH FRIGIDAIRE/FREEZER
Frigidaire GLFH21F8HBA FREEZER
Frigidaire GLFH21F8HBB FREEZER
Frigidaire GLFH21F8HBC FREEZER
  #2 (permalink)
Old 05-17-2013, 07:57 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Your symptoms are a little bit unusual, but almost all problems with these dryers is the rear bearing assembly. It is a steel ball in a plastic socket.
Try changing it out, and maybe changing the belt as well.
Here is the part.
Part number: AP2142648
__________________
  #3 (permalink)
Old 05-17-2013, 03:49 PM
Junior Member
appliance dude is on a distinguished road
Default
Also I would check the blower wheel for cracks or debris. Usually Frigidaire dryers are very quiet.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Vision 500 spin and vibrate woes tangodip Washer Repair 0 01-18-2013 08:34 AM
fridgidaire electrolux dryer Gary Lane Dryer Repair 6 12-06-2012 03:43 PM
Electrolux gas dryer melting clothes lmtuttle Dryer Repair 1 03-19-2012 10:34 AM
Electrolux laundry center (stack washer/dryer) dryer won't start maddy Dryer Repair 0 09-21-2010 05:23 PM
