I have a Frigidaire front load washer, model LTF2940ESO. The machine runs a few seconds and shuts off. No error code. Replaced main control unit. Didn't fix. Removed back access panel. Noticed the 5-wire connector was loose on the Motor Control Unit. Harness fell off as I touched it. What's the easiest way to reconnect? How is the Motor Control unit most easily accessed? HISTORY: When new, Lowes had unit repaired. Suspect harness was never connected properly. Thanks!
Rank:: Advanced Member
Originally Posted by: sidfink43 Yep, reconnection worked. Very helpful, thanks. I've noticed some mistakes in the wiring harness notes. Now, what to do with the main control unit I purchased.
If you purchased from this site you can return it, if you did not then you have a spare part on your shelf.
