df_3
#1 Posted : Tuesday, May 7, 2013 4:07:16 PM(UTC)
df_3
My kenmore washer is at it again. You guys helped me with mcu and ccu changeout in the past, hoping you can rescue me again. This time my inner tub is loose from outer tub. Makes a loud clanking sound when trying to spin. I removed belt and tried rotating the sheave. Def a prob somewhere in there (shaft, bearing, etc.) What do I need to replace, bearing, other? SN is hlt0210454. Are these parts under warranty? I know some tub parts have a longer warranty than other non tub parts.
Joe / APP Team
#2 Posted : Wednesday, May 8, 2013 1:15:40 PM(UTC)
Joe / APP Team
DF_3, based on your description, you most likely have a cracked or broken spin basket support arm(s)
Part number: AP3868479
Worn or damaged tub bearings will usually make some type of rumbling, grumbling noise when they wallow out. That would require a rear tub assembly to repair
Part number: AP3970398
For warranty information, you'll need to review your owners manual or contact Sears Customer Service so they can inform you of the specifics of your washer warranty.
