Discuss
Inner basket frozen to centerpost
 in
Washer Repair
I am trying to replace the washer centerpost gasket on an older Whirlpool washer. I am using the video, Washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Inner basket frozen to centerpost
  #1 (permalink)
Old 05-07-2013, 11:56 AM
Junior Member
conradm is on a distinguished road
Default Inner basket frozen to centerpost
Brand: Whirlpool   Age: More than 10 years
I am trying to replace the washer centerpost gasket on an older Whirlpool washer. I am using the video, Washer Centerpost Gasket (part #383727) - How To Replace, as a guide and everything is exactly as described except the inner basket will not come off the centerpost after I removed the spanner nut. Seems frozen to the centerpost. I have tried lifting on it and tapping on the shaft at the same time. I am now using PB Blaster to try and break the rust or crud that has it frozen, but still no luck 24 hours later.
Or is there something else that I have not removed that is holding this on?
If not, any other ideas? What happens if I use an acetylene torch to heat the inner basket tube? I assume that will damage the enamel, right?
  #2 (permalink)
Old 05-07-2013, 02:54 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Conrad, Yes, using an acetylene torch could damage the spin basket enamel.
There are a couple of things you could try. First try pushing down on one side of the tub and pulling up on the opposite side. it's going to take quite a bit of weight/force, and pushing. The spin tub is stuck to the drive block, and the drive block is seated on the spin tube. You could try slipping a large screw driver or chisel into the open slot of the drive block and spread the opening, this may release the block from the spin tube, and you can lift the tub and block from the tube. If no success then try the torch, but be careful, use the torch in the top 1 or 2 inches of the tub tube.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
leaky centerpost gasket Mike_Brokenwasher Washer Repair 2 01-03-2013 07:31 PM
lower basket frozen products Antonion Refrigerator & Freezer Repair 1 04-23-2011 02:48 AM
Centerpost bearing removal/installer tools tranvh Washer Repair 0 02-15-2010 06:46 PM
Stackable Frigidaire washer is leaking from underneath centerpost/transmission gregrao Washer Repair 1 09-26-2008 02:08 PM
Which centerpost seal? GeorgeG Washer Repair 4 04-17-2008 08:51 AM
