Discuss
maytag ,computer mod. overflow on hot only
 in
Washer Repair
maytag stacking laundry team with computer touch pad controls ,mfd feb 1991. washer overflows (doesn't stop filling) only when hot
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag ,computer mod. overflow on hot only
  #1 (permalink)
Old 05-06-2013, 06:50 PM
Junior Member
guy with the mt wallet is on a distinguished road
Default maytag ,computer mod. overflow on hot only
Brand: Maytag   Age: More than 10 years
maytag stacking laundry team with computer touch pad controls ,mfd feb 1991. washer overflows (doesn't stop filling) only when hot is selected. verified signal tubing to drum is clear and intact. swapped out water level switch pt#2-06418 . made no difference . interestingly though I observed that hot water valve is still open even if unit is unplugged and then plugged back in. would suspect water valve , but works consistently ok when warm is selected. any help would be appreciated , thanks in advance ...dave
  #2 (permalink)
Old 05-06-2013, 07:30 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
What is the model number?
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 05-06-2013, 07:41 PM
Junior Member
Default
Quote:
hi there and thanks for your reply . the machine and my computer are miles apart , so i'll have to get the model # tomorrow ,unless you have any ideas that I could check when I get there. thanks dave
  #4 (permalink)
Old 05-06-2013, 07:54 PM
Junior Member
Default
Quote:
PS I did find this # inside the door of the dryer ( stacking combo) LSE9900C serial 300816 , but I thought maybe the washer had a separate id badge? Does it ? thanks again ..dave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Atlantis Leaking - overflow side of tub thechunger Washer Repair 6 06-11-2013 02:58 PM
Maytag Dish Washer water overflow jim34 Dishwasher Repair 4 03-10-2010 09:37 PM
Maytag Computer Board Problem dtakacs1 Washer Repair 1 02-20-2010 06:40 PM
Maytag Neptune TL computer/ display/ input problems john2in3 Washer Repair 7 08-02-2009 03:47 PM
Overflow Gary V Washer Repair 1 01-09-2008 12:27 PM
