Discuss
Intermitent start and stop on Washer
 in
Washer Repair
Our washer has been intermittently stopping during cycles. At times for 10 minutes or more. First time a burnt electrical
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Intermitent start and stop on Washer
  #1 (permalink)
Old 05-06-2013, 06:05 PM
Junior Member
grolson is on a distinguished road
Default Intermitent start and stop on Washer
Model Number: LSQ9659LW0   Brand: Whirlpool   Age: 5 - 10 years
Our washer has been intermittently stopping during cycles. At times for 10 minutes or more. First time a burnt electrical smell. I took the bottom end apart and all is good with the coupler, clutch, etc. I wondered because first time I couldn't get it to spin on any of the cycles. Then I realized it wasn't doing anything. finally it started working, so I checked all functions, spin, agitate, fill, all work, but only for a while, then nothing again. I wondering, Timer, starter switch, or possibly capacitor heating up then cooling down and working again??? What's my best bet??
Ultimate Care II
Gary
Related Models
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
Whirlpool LSQ9659PG3 AUTOMATIC WASHER
Whirlpool LSQ9659PG4 AUTOMATIC WASHER
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
Whirlpool LSQ9660PW3 AUTOMATIC WASHER
Whirlpool LSQ9660PW4 AUTOMATIC WASHER
Whirlpool LSQ9665JQ0 WASHER
Whirlpool LSQ9665JQ1 WASHER
Whirlpool LSQ9665JQ2 WASHER
Whirlpool LSQ9665JQ3 WASHER
Whirlpool LSQ9665JQ4 WASHER
Whirlpool LSQ9665JT0 WASHER
Whirlpool LSQ9665JT1 WASHER
Whirlpool LSQ9665JT2 WASHER
Whirlpool LSQ9665JT3 WASHER
Whirlpool LSQ9665JT4 WASHER
Whirlpool LSR4100HQ0 AUTOMATIC WASHER
Whirlpool LSR4311DQ0 WASHER
Whirlpool LSR5100HQ0 AUTOMATIC WASHER
Whirlpool LSR5100KQ0 RESIDENTIAL WASHER
Whirlpool LSR5100LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ1 AUTOMATIC WASHER
Whirlpool LSR5102LQ1 AUTOMATIC WASHER
Whirlpool LSR5121HQ0 AUTOMATIC WASHER
Whirlpool LSR5121JQ0 AUTOMATIC WASHER,
Whirlpool LSR5132AG0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AN0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AW0 DIRECT-DRIVE WASHER
Whirlpool LSR5132HQ0 AUTOMATIC WASHER
Whirlpool LSR5132HQ1 AUTOMATIC WASHER
Whirlpool LSR5132JQ0 COMPACT WASHER
Whirlpool LSR5132JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR5132JQ2 WASHER - DIRECT DRIVE
Whirlpool LSR5132PQ0 AUTOMATIC WASHER
Whirlpool LSR5132PQ1 AUTOMATIC WASHER
Whirlpool LSR5132PQ3 AUTOMATIC WASHER
Whirlpool LSR5132PQ4 AUTOMATIC WASHER
Whirlpool LSR5232DW0 AUTOMATIC WASHER
Whirlpool LSR5232LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5232LQ1 AUTOMATIC WASHER
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
Whirlpool LSR5233AW0 Washers*
Whirlpool LSR5233EQ0 AUTOMATIC WASHER
Whirlpool LSR5233EQ1 DIRECT-DRIVE WASHER
Whirlpool LSR5233EQ2 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132BN0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW1 AUTOMATIC WASHER
Whirlpool LSR6132DQ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132DZ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132EQ0 AUTOMATIC WASHER
Whirlpool LSR6132EQ1 AUTOMATIC WASHER
Whirlpool LSR6132EZ0 AUTOMATIC WASHER
Whirlpool LSR6132EZ1 AUTOMATIC WASHER
Whirlpool LSR6132HQ0 AUTOMATIC WASHER
Whirlpool LSR6132HQ1 AUTOMATIC WASHER
Whirlpool LSR6132HZ0 AUTOMATIC WASHER
Whirlpool LSR6232JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR6232JQ1 WASHER - DIRECT DRIVE
Whirlpool LSR6232JQ2 AUTOMATIC WASHER
Whirlpool LSR6233BG0 AUTOMATIC WASHER
Whirlpool LSR6233BN0 AUTOMATIC WASHER
Whirlpool LSR6233BN1 WASHER
Whirlpool LSR6233BW0 AUTOMATIC WASHER
Whirlpool LSR6233BW1 WASHER
Whirlpool LSR6233DN0 AUTOMATIC WASHER
Whirlpool LSR6233DW0 AUTOMATIC WASHER
Whirlpool LSR6244AW0 Washers*
Whirlpool LSR6332KQ0 WASHER
Whirlpool LSR6332KQ1 AUTOMATIC WASHER
Whirlpool LSR6334LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR6334LQ1 AUTOMATIC WASHER
Whirlpool LSR6335LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR7010PQ0 AUTOMATIC WASHER
Whirlpool LSR7010PQ1 AUTOMATIC WASHER
Whirlpool LSR7010PQ2 AUTOMATIC WASHER
Whirlpool LSR7133KQ0 WASHER
Whirlpool LSR7133KQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ0 AUTOMATIC WASHER
Whirlpool LSR7133PQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ2 AUTOMATIC WASHER
Whirlpool LSR7200EQ0 AUTOMATIC WASHER
Whirlpool LSR7200EZ0 AUTOMATIC WASHER
Whirlpool LSR7233BG0
Whirlpool LSR7233BG1
Whirlpool LSR7233BG2
Whirlpool LSR7233BGO WASHER
Whirlpool LSR7233BN0
Whirlpool LSR7233BN1
Whirlpool LSR7233BN2
Whirlpool LSR7233BNO WASHER
Whirlpool LSR7233BQ0
Whirlpool LSR7233BQ1
Whirlpool LSR7233BQ2
Whirlpool LSR7233BQO WASHER
Whirlpool LSR7233BW0
Whirlpool LSR7233BW1
Whirlpool LSR7233BW2
Whirlpool LSR7233BWO WASHER
Whirlpool LSR7233BZ0
Whirlpool LSR7233BZ2
Whirlpool LSR7233DQ0 WASHER
  #2 (permalink)
Old 05-07-2013, 07:44 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Could be the thermal overload in the motor tripping. I would remove the cabinet, jump out the lid switch and see if that cures the problem first. If not pull the pump off of the motor and run it in spin cycle to see if it completes without cutting off. Could be something in the pump jamming it causing excessive load on the motor. If it cuts out in the middle of running normally, I would not suspect the capacitor as it is not in circuit once the motor is up to speed unless the motor switch is defective. To check the motor start contacts in the motor switch, unplug the wiring harness connector from the motor. Check continuity between the motor black wire terminal and the terminal where the red wire of the harness connector connects on the motor switch. This should read zero ohms (dead short). Now remove the screw holding the start switch to the motor and pull the switch away from the motor so that the lever arm is free. It should now read open circuit. Other possibilities include a defective speed select switch at the control panel.
Eric
  #3 (permalink)
Old 05-07-2013, 09:29 AM
Junior Member
Default
Thanks, I give it a try tonight and see where it leads me.
  #4 (permalink)
Old 05-07-2013, 01:51 PM
Junior Member
Default
Well, Lid switch checks OK, Motor contact checks correctly, but boy, the motor is hot. The pump seems free spinning enough, and the transmission is not warm at all. I'm trying to figure a reason for the heat. Is the motor thermally protected inside?? Is there a way to check that circuit when its hot and when its cold??
  #5 (permalink)
Old 05-07-2013, 03:30 PM
Expert
APP Volunteer
Default
Yes, there is a thermal switch in the motor. When the motor kicks off, disconnect the connector from the motor and check continuity on the motor between where the white wire and the white/black wire connect. If it's open, the switch has tripped. After it cools it will reset and you will have continuity. It is normal though for these motors to get quite hot while in use but if it's tripping the overload, there's a problem.
Eric
  #6 (permalink)
Old 05-07-2013, 05:43 PM
Junior Member
Default
Thanks for that tip, that is definitely the problem. It trips for sure.
Now, what's causing it?? Could it be low gear oil in the transmission, I think its 10w90, there was a smattering of it on the walls of the cabinet among other places.
How much should be in the case, I can open it and refill it.
  #7 (permalink)
Old 05-07-2013, 06:30 PM
Expert
APP Volunteer
Default
Pull the motor and run it with it sitting on the floor. Place your foot on it before starting it as it will want to jump when starting. If it still trips, it's not the gearcase. There may be a problem with the speed select switch.
Eric
  #8 (permalink)
Old 05-07-2013, 07:47 PM
Junior Member
Default
I pulled the motor and sure enough it trips even when running on the floor. I tried changing the speed and it does change between high and low.
I used a compressor and cooled it down until the continuity came back.
Then I ran it on low speed but it still tripped. So, I assume the thermal protection is not changeable. So I would be looking at a motor, correct??
  #9 (permalink)
Old 05-07-2013, 09:51 PM
Expert
APP Volunteer
Default
Not yet. This is a 3 speed motor. Sometimes a faulty speed switch (fabric selector) will try to select more than one winding at the same time causing an overload. I need to see a clear photo of your wiring diagram, can't find the one for your model. With the diagram, I can tell you how to bypass the switch.
Eric
  #10 (permalink)
Old 05-08-2013, 07:01 AM
Junior Member
Default
They enclosed one, How do I get it to you?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Intermitent compressor start msantell Heating, Ventilation, and Air Conditioning (HVAC) 2 09-25-2011 09:37 AM
my washer start fill and then stop alecks Washer Repair 23 07-03-2010 06:55 PM
maytag d-washer start/stop/start mike kennedy Dishwasher Repair 0 01-11-2010 09:51 PM
washer will start to fill then stop kevin Kirchoff Washer Repair 2 10-06-2009 05:11 AM
Washer start spin then stop pepo Washer Repair 0 04-16-2009 02:17 PM
