Discuss
Intermitent start and stop on Washer
 in
Washer Repair
Take a clear picture of it and post it here. Eric
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Intermitent start and stop on Washer
  #11 (permalink)
Old 05-08-2013, 07:53 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Eric
  #12 (permalink)
Old 05-08-2013, 08:38 AM
Junior Member
grolson is on a distinguished road
Default
OK, Thanks, When I get home. I appreciate all the help!
  #13 (permalink)
Old 05-08-2013, 03:14 PM
Junior Member
Default
Here are the diagrams and pic of the back of the switch
  #14 (permalink)
Old 05-08-2013, 05:43 PM
Expert
APP Volunteer
Default
Unplug all three connectors from the switch. You will need to make a jumper and jump the white/blue wire on the lower connector to the blue wire on the upper connector. Now try normal cycle spin mode.
Eric
  #15 (permalink)
Old 05-09-2013, 06:03 AM
Junior Member
Default
Hi Eric,
So, I'm going to bypass the switch all together and just connect the jumper wire between the plugs, then run the machine and see if the thermal -protection trips, correct?
  #16 (permalink)
Old 05-09-2013, 06:10 AM
Expert
APP Volunteer
Default
Yes, just the one jumper wire which will allow it to work in spin mode only. Sounds like this may be way over your head. You could just parts swap either the switch or motor to try to figure this out. You could also make a test cable out of an old extension cord to test the motor directly but it's a bit involved and may not be a good idea for you to try. Sorry, difficult to explain to someone with little experience with this kind of stuff.
Eric
  #17 (permalink)
Old 05-09-2013, 07:01 AM
Junior Member
Default
Actually, its not too difficult. I just try to be clear.
I have a motor coming that is returnable so I want to make sure if its the switch before I install the motor. Actually, I was wondering if I could take a voltage reading on the output side of the switch to see if its feeding power from two circuits at the same time, say, the high speed and the low speed and thats what might be tripping the thermal overload, but this seems much simpler. So when this runs and if it doesn't trip the thermal, then it should be the switch?
  #18 (permalink)
Old 05-09-2013, 06:17 PM
Junior Member
Default
OK, I ran the jumper and the spin cycle still kicked out. So I'm assuming its the motor? Am I missing anything?
  #19 (permalink)
Old 05-10-2013, 05:24 AM
Expert
APP Volunteer
Default
The motor has not been completely isolated yet, a faulty timer can also cause selection of two motor windings at the same time. Unplug the motor connector, on the motor, unplug the white/violet and white/orange wires, move them aside making sure they are not touching each other or anything else (tape them if need be), plug motor connector back in and try again using the jumper across the speed switch connectors. If you still have the problem, one other possibility is that the contacts in the motor centrifugal switch for the start winding are not opening when the motor gets up to speed. I know you checked that switch before and also confirmed the motor would operate in a lower speed so it appears the switch is working properly but there is a way to check it for sure.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Intermitent compressor start msantell Heating, Ventilation, and Air Conditioning (HVAC) 2 09-25-2011 09:37 AM
my washer start fill and then stop alecks Washer Repair 23 07-03-2010 06:55 PM
maytag d-washer start/stop/start mike kennedy Dishwasher Repair 0 01-11-2010 09:51 PM
washer will start to fill then stop kevin Kirchoff Washer Repair 2 10-06-2009 05:11 AM
Washer start spin then stop pepo Washer Repair 0 04-16-2009 02:17 PM
