Discuss
Kenmore Elite 70 will agitate, not always spin
 in
Washer Repair
The washing machine performs all functions properly, but will not always spin. It had been making quite a bit of
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Elite 70 will agitate, not always spin
  #1 (permalink)
Old 05-06-2013, 10:06 AM
Junior Member
Farmout is on a distinguished road
Default Kenmore Elite 70 will agitate, not always spin
Model Number: 11022702100   Brand: Kenmore   Age: 5 - 10 years
The washing machine performs all functions properly, but will not always spin. It had been making quite a bit of noise and "clunking" when transitioning between cycles and leaving clothes wet, so the motor coupling and clutch assembly have been replaced. Amazing how quietly it agitates now, but it still "clunks" before spinning. It will sometimes spin on its own after wash and rinse cycles, but not always. If I open the lid while the water is draining (start of the spin) it will begin spin and be fine for rest of cycle, although noisy. Any help in pin-pointing the problem would be appreciated!
Related Models
Kenmore 11022702100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022702101 AUTOMATIC WASHER
Kenmore 11022712100 WASHER
Kenmore 11022722100 WASHER
Kenmore 11022722101 WASHER
Kenmore 11022802100 WASHER
Kenmore 11022802101 AUTOMATIC WASHER
Kenmore 11022832100 WASHER
Kenmore 11022832101 AUTOMATIC WASHER
Kenmore 11022832102 AUTOMATIC WASHER
Kenmore 11022842100 WASHER
Kenmore 11022842101 AUTOMATIC WASHER
Kenmore 11022842102 AUTOMATIC WASHER
Kenmore 11022852100 WASHER
Kenmore 11022852101 AUTOMATIC WASHER
Kenmore 11022852102 AUTOMATIC WASHER
Kenmore 11022854100 WASHER
Kenmore 11022854101 AUTOMATIC WASHER
Kenmore 11022854102 AUTOMATIC WASHER
Kenmore 11022862100 WASHER
Kenmore 11022862101 AUTOMATIC WASHER
Kenmore 11022872100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022872101 AUTOMATIC WASHER
Kenmore 11022872102 AUTOMATIC WASHER
Kenmore 11022882100 WASHER
Kenmore 11022882101 AUTOMATIC WASHER
Kenmore 11022882102 AUTOMATIC WASHER
Kenmore 11022892100 WASHER
Kenmore 11022892101 AUTOMATIC WASHER
Kenmore 11022892102 AUTOMATIC WASHER
Kenmore 11022894100 WASHER
Kenmore 11022894101 AUTOMATIC WASHER
Kenmore 11022894102 AUTOMATIC WASHER
Kenmore 11022902100 WASHER
Kenmore 11022902101 AUTOMATIC WASHER
Kenmore 11022904100 WASHER
Kenmore 11022904101 AUTOMATIC WASHER
Kenmore 11022912100 WASHER
Kenmore 11022912101 AUTOMATIC WASHER
Kenmore 11022922100 WASHER
Kenmore 11022922101 AUTOMATIC WASHER
Kenmore 11022922102 AUTOMATIC WASHER
Kenmore 11022924100 WASHER
Kenmore 11022924101 AUTOMATIC WASHER
Kenmore 11022924102 AUTOMATIC WASHER
Kenmore 11022932100 WASHER
Kenmore 11022932101 AUTOMATIC WASHER
Kenmore 11022932102 AUTOMATIC WASHER
Kenmore 11022936100 WASHER
Kenmore 11022936101 AUTOMATIC WASHER
Kenmore 11022936102 AUTOMATIC WASHER
Kenmore 11022942100 WASHER
Kenmore 11022942101 AUTOMATIC WASHER
Kenmore 11022942102 AUTOMATIC WASHER
Kenmore 11022952100 WASHER
Kenmore 11022952101 AUTOMATIC WASHER
Kenmore 11022952102 AUTOMATIC WASHER
Kenmore 11022954100 WASHER
Kenmore 11022954101 AUTOMATIC WASHER
Kenmore 11022954102 AUTOMATIC WASHER
Kenmore 11022956100 WASHER
Kenmore 11022956101 RESIDENTIAL WASHER
Kenmore 11022956102 AUTOMATIC WASHER
Kenmore 11022972100 WASHER
Kenmore 11022972101 WASHER
Kenmore 11022972102 WASHER
Kenmore 11022972103 AUTOMATIC WASHER
Kenmore 11022974100 WASHER
Kenmore 11022974101 WASHER
Kenmore 11022974102 WASHER
Kenmore 11022974103 AUTOMATIC WASHER
Kenmore 11022982100 WASHER
Kenmore 11022982101 WASHER
Kenmore 11022982102 WASHER
Kenmore 11022982103 AUTOMATIC WASHER
Kenmore 11022992100 WASHER
Kenmore 11022992101 WASHER
Kenmore 11022992102 AUTOMATIC WASHER
Kenmore 11022992103 AUTOMATIC WASHER
Kenmore 11022994100 WASHER
Kenmore 11022994101 WASHER
Kenmore 11022994102 AUTOMATIC WASHER
Kenmore 11022994103 AUTOMATIC WASHER
Kenmore 11022996100 WASHER
Kenmore 11022996101 WASHER
Kenmore 11022996102 AUTOMATIC WASHER
Kenmore 11022996103 AUTOMATIC WASHER
Kenmore 11023012100 AUTOMATIC WASHER
Kenmore 11023012101 AUTOMATIC WASHER
Kenmore 11023012102 AUTOMATIC WASHER
Kenmore 11023014100 AUTOMATIC WASHER
Kenmore 11023014101 AUTOMATIC WASHER
Kenmore 11023014102 AUTOMATIC WASHER
Kenmore 11023022100 AUTOMATIC WASHER
Kenmore 11023022101 AUTOMATIC WASHER
Kenmore 11023022102 AUTOMATIC WASHER
Kenmore 11023024100 AUTOMATIC WASHER
Kenmore 11023024101 AUTOMATIC WASHER
Kenmore 11023024102 AUTOMATIC WASHER
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
Kenmore 11023822100 AUTOMATIC WASHER
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
  #2 (permalink)
Old 05-06-2013, 01:03 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
The washer has a neutral drain gearcase. It's supposed to drain without spinning. After drain, the motor should pause for a few seconds which releases the neutral drain mechanism and when it starts again, it will continue to drain and spin. When you open/close the lid, you are pausing the motor. These Whirlpool direct drive washers normally produce a clunk sound when going into spin mode however without hearing yours, can't say for sure if what you are experiencing is normal. Is there an additional noise in spin mode after it gets going? Maybe post a video on youtube.
Eric
  #3 (permalink)
Old 05-14-2013, 06:42 AM
Junior Member
Default
I have spent the last several days trying to video the washer doing its thing and of course it has turned shy! The only thing I know to do is explain a little better. If the washer is going to spin the clothes at the end of the wash or rinse cycles, it will begin draining and within a couple seconds do its "clunk" and begin spinning (with a full tub of water). When it spins on its own this way, sometimes it stops with a slam after the water has been spun out, pauses, then begins again normally as it dispenses the water on the spinning clothes. It will continue to fill and agitate for the rinse cycle normally, but the same thing happens at the end of the cycle ... if I do not lift the lid when the machine drains, the spin would not begin. Do I need to take the shell off and watch the clutch as in some of the other recommendations even though we have replaced the clutch or could it be the timer or ...?
  #4 (permalink)
Old 05-14-2013, 07:06 AM
Expert
APP Volunteer
Default
It should not spin with the tub full of water. It should drain for a minute or two before going into spin. If it's starting to spin a few seconds after it starts to drain, there's a problem with the gearcase or the timer is causing the motor to pause when it shouldn't. Need to see and hear it for myself.
Eric
  #5 (permalink)
Old 05-14-2013, 08:21 AM
Junior Member
Default
I will see if I can coax the washer out of its 'stage fright' and post a video, the laundry is piling up, anyway! Thank you for your patience.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Oasis Washer.Error# OL but won't Agitate weslee Washer Repair 1 03-21-2013 05:36 PM
Kenmore Elite HE 3+ Won't Spin bselff Washer Repair 4 11-17-2011 06:17 PM
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Kenmore no spin OR spin & agitate simultaneously Badtiming Washer Repair 0 10-12-2010 11:01 PM
kenmore elite 90 series won't agitate or spin compton Washer Repair 4 12-15-2008 06:00 PM
