Discuss
Washer wont drain
 in
Washer Repair
I have a Maytag MAH8700AWW front loading washer that will not drain. I have done the following steps to troubleshoot
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer wont drain
  #1 (permalink)
Old 05-05-2013, 11:04 AM
Junior Member
picklesdaisy is on a distinguished road
Default Washer wont drain
Model Number: Mah8700AWW   Brand: Maytag   Age: 5 - 10 years
I have a Maytag MAH8700AWW front loading washer that will not drain. I have done the following steps to troubleshoot the issue.
1)I removed drain pump and checked for obstructions. none found
2)I tested drain pump with 110 volts and worked fine.
3)I ran washer through quick wash with a voltage tester connected to the input to the drain pump. voltage was between 24-25 Volts the whole time. Never got the 110 volts that is necessary to run it.
4)I ran the output control board test in service mode and still got the same 24-26volts on the drain pump.
5) I connected a separate 110 volt supply with a switch to the pump and ran the washer through a full wash cycle and manually activated the drain pump when necessary. Washer finished full cycle with no problems so that means the water level switch is okay.
I inspected the control board and could not find any frayed wires or damage. My question is do I need a new control board or am I missing something?
Thank you in advance for all your help,
Robert
Related Models
Maytag MAH8700AWW WASHER- HORIZONTAL AXIS
Maytag MAH9700AWM WASHER- HORIZONTAL AXIS
Maytag MAH9700AWQ WASHER- HORIZONTAL AXIS
Maytag MAH9700AWW WASHER- HORIZONTAL AXIS
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM MISC / ACCESSORY
Maytag MAL1800AXQ MISC / ACCESSORY
Maytag MAL1800AXW MISC / ACCESSORY
Maytag MAL2000AXQ MISC / ACCESSORY
Maytag MAL2000AXW MISC / ACCESSORY
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL MANUAL, PARTS (WASHER)
Maytag MAT10CSAAW MANUAL, PARTS (WASHER)
Maytag MAT10CSAGL MANUAL, PARTS (WASHER)
Maytag MAT10CSAGW MANUAL, PARTS (WASHER)
Maytag MAT10CSEGL MANUAL, PARTS (WASHER)
Maytag MAT10CSEGW MANUAL, PARTS (WASHER)
Maytag MAT10DAAAL MANUAL, PARTS (WASHER)
Maytag MAT10DAAAW MANUAL, PARTS (WASHER)
Maytag MAT10DAABL MANUAL, PARTS (WASHER)
Maytag MAT10DAABW MANUAL, PARTS (WASHER)
Maytag MAT10PDAAL MANUAL, PARTS (WASHER)
Maytag MAT10PDAAW MANUAL, PARTS (WASHER)
Maytag MAT10PDABL MANUAL, PARTS (WASHER)
Maytag MAT10PDABW MANUAL, PARTS (WASHER)
Maytag MAT10PDEGW MAYTAG LAUNDRY (COMM.EXPORT) (WASHER)
Maytag MAT10PSAAL MANUAL, PARTS (WASHER)
Maytag MAT10PSAAW MANUAL, PARTS (WASHER)
Maytag MAT10PSAGL MANUAL, PARTS (WASHER)
Maytag MAT10PSAGW MANUAL, PARTS (WASHER)
Maytag MAT11CSBKL MANUAL, PARTS (WASHER)
Maytag MAT11MNAAW MANUAL, PARTS (WASHER)
Maytag MAT11MNAGW MANUAL, PARTS (WASHER)
Maytag MAT11MNEGW MANUAL, PARTS (WASHER)
Maytag MAT11PDAAL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDAAW MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABW MAYTAG LAUNDRY (WASHER)
Maytag MAT12CSAAL MANUAL, PARTS (WASHER)
Maytag MAT12CSAAQ MANUAL, PARTS (WASHER)
Maytag MAT12CSAAW MANUAL, PARTS (WASHER)
Maytag MAT12CSAGW MANUAL, PARTS (WASHER)
Maytag MAT12CSAKL MANUAL, PARTS (WASHER)
Maytag MAT12CSAKQ MANUAL, PARTS (WASHER)
Maytag MAT12CSDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSEGW MANUAL, PARTS (WASHER)
Maytag MAT12CSFWQ COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSFWW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLGW MAYTAG COMMERCIAL WASHER (WASHER)
Maytag MAT12CSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDAAL MANUAL, PARTS (WASHER)
Maytag MAT12PDAAW MANUAL, PARTS (WASHER)
Maytag MAT12PDABL MANUAL, PARTS (WASHER)
Maytag MAT12PDABW MANUAL, PARTS (WASHER)
Maytag MAT12PDAGW MANUAL, PARTS (WASHER)
Maytag MAT12PDBAL MANUAL, PARTS (WASHER)
Maytag MAT12PDBAQ MANUAL, PARTS (WASHER)
Maytag MAT12PDBAW MANUAL, PARTS (WASHER)
Maytag MAT12PDBBL MANUAL, PARTS (WASHER)
Maytag MAT12PDBBQ WASHER-TOP LOADING
Maytag MAT12PDBBW MANUAL, PARTS (WASHER)
Maytag MAT12PDCBL MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDBW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDEGW MANUAL, PARTS (WASHER)
Maytag MAT12PDLAQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLAW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLGW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDSAW MANUAL,PARTS (WASHER)
Maytag MAT12PRAAW MANUAL, PARTS (WASHER)
Maytag MAT12PRAEW MANUAL, PARTS (WASHER)
Maytag MAT12PRBAW MANUAL, PARTS (WASHER)
Maytag MAT12PRDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PRSAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAGW MANUAL, PARTS (WASHER)
Maytag MAT12PSBAW MANUAL, PARTS (WASHER)
Maytag MAT12PSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT13MNAAW MANUAL, PARTS (WASHER)
Maytag MAT13MNAGW MANUAL, PARTS (WASHER)
Maytag MAT13MNDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNEGW MANUAL, PARTS (WASHER)
Maytag MAT13PDAAW MANUAL, PARTS (WASHER)
Maytag MAT13PDBAW MANUAL, PARTS (WASHER)
Maytag MAT13PNAEW MAYTAG LAUNDRY (WASHER)
Maytag MAT13PNDEW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13PRBWW MAYTAG LAUNDRY (WASHER)
Maytag MAT14CSAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSBGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14PDAWW0 COMMERCIAL AUTOMATIC WASHER
Whirlpool MAT14PDAXW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14PRAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNBGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT23PCAAG MANUAL, PARTS (WASHER)
Maytag MAT23PCAAL MANUAL, PARTS (WASHER)
Maytag MAT23PCAAW MANUAL, PARTS (WASHER)
Maytag MAT23PCABG MANUAL, PARTS (WASHER)
Maytag MAT23PCABL MANUAL, PARTS (WASHER)
Maytag MAT23PCABW MANUAL, PARTS (WASHER)
Maytag MAT25CSAAG MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAAL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAAW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAGG MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSAGL MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSAGW MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSBIL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSCAG MAYTAG COMMERCIAL LAUNDRY (WASHER)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG washer wont drain hondakubota Washer Repair 2 08-05-2011 08:07 PM
washer wont drain sword88 Washer Repair 1 04-13-2011 08:10 AM
washer wont drain vfargosa2 Washer Repair 1 01-20-2011 05:03 AM
Washer wont drain or run bclarkston Washer Repair 1 10-30-2009 11:16 AM
washer wont drain jhadz Washer Repair 3 10-05-2009 07:32 AM
