jarhead217
#1 Posted : Sunday, May 5, 2013 8:04:35 AM(UTC)
jarhead217
Washer will not drain, pressure switch OK, will drain when I lower drain hose.
Washer will not drain, pressure switch OK, will drain when I lower drain hose manually w/machine shur off.
washer will not drain-prressure switch OK. Will drainj w/machine shut opff and drain hose lowered into bucket.
sidfink43
#2 Posted : Monday, May 6, 2013 4:10:04 PM(UTC)
sidfink43
This could be a faulty drain pump.
I can no longer link you to a service manual for this model, but you should be able to find one on the net. You want the service manual for the Neptune 3000, and your model is discussed in the back (even though it is not listed in the table of contents)
Samsung activewash WA52M8650AV No drain (Washer Repair)
by Friscowasher 10/23/2021 2:03:00 PM(UTC)
Jenn-Air DW871UQW timer question - no draining properly (Dishwasher Repair)
by aspenpup 5/13/2020 10:02:16 PM(UTC)
Maytag Centennial Agitate But No Drain (Washer Repair)
by ralphj 5/8/2017 6:33:14 AM(UTC)
kenmore elite no drain (Washer Repair)
by notbob 12/11/2016 11:33:42 AM(UTC)
Kenmore/Whirlpool - No Drain (Dishwasher Repair)
by NickA55 10/16/2014 8:35:32 AM(UTC)
Kenmore 110: Won't Agitate. And no drain (Washer Repair)
by jmrec100 9/21/2014 10:32:05 AM(UTC)
Washer starts fine, always stops at end of wash, no drain, no refil, no spin, no noth (Washer Repair)
by mdempster1@yahoo.com 6/16/2014 8:29:11 PM(UTC)
No Drain no Spin issue with Kenmore Stack-able washer (Washer Repair)
by 2MD 6/5/2014 5:57:40 AM(UTC)
Whirlpool Duet front loader help needed-no drain/pump comes on in wash cycle (Washer Repair)
by rdcleeann 10/1/2013 5:42:30 AM(UTC)
No spin, No drain (Washer Repair)
by JEANETTE W. 4/7/2013 4:07:10 PM(UTC)
No spin and no drain (Washer Repair)
by bbjdives 4/30/2012 2:38:09 PM(UTC)
Whirlpool Quiet Partner I - no drain (Dishwasher Repair)
by Maxbumpo 3/3/2012 1:27:28 PM(UTC)
LG Tromm code OE, no drain (Washer Repair)
by DAC68 2/17/2012 5:15:19 AM(UTC)
NO Drain Washer Whirlpool (Washer Repair)
by neutcybott 12/26/2011 12:06:21 PM(UTC)
NO DRain of water after wash (Washer Repair)
by neutcybott 12/23/2011 12:49:02 PM(UTC)
