Discuss
Noisy Spin cycle
 in
Washer Repair
When the machine goes into the spin cycle it creates a noise that sounds kind of like a bearing going
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Noisy Spin cycle
  #1 (permalink)
Old 05-04-2013, 03:29 PM
Junior Member
JamesO is on a distinguished road
Default Noisy Spin cycle
Model Number: lsq9610lw0   Brand: Whirlpool   Age: More than 10 years
When the machine goes into the spin cycle it creates a noise that sounds kind of like a bearing going out. Not knowing exactly where the noise is coming from, I started diagnostics by removing the agitator, turned it on and still had noise. I then removed the motor, turned it on and no noise. I then removed the clutch & gear-case, reattached the motor to the clutch & gear-case and turned in on and still no noise. the only thing left is the brake and drive tube.
Your thoughts please.
JamesO
Related Models
Whirlpool LSQ9610LW0 AUTOMATIC WASHER
Whirlpool LSQ9620LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LG1 AUTOMATIC WASHER
Whirlpool LSQ9620LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LW1 AUTOMATIC WASHER
Whirlpool LSQ9645KQ0 WASHER
Whirlpool LSQ9645KQ1 WASHER
Whirlpool LSQ9645KT0 WASHER
Whirlpool LSQ9645KT1 WASHER
Whirlpool LSQ9650PG0 AUTOMATIC WASHER
Whirlpool LSQ9650PG1 AUTOMATIC WASHER
Whirlpool LSQ9650PG2 AUTOMATIC WASHER
Whirlpool LSQ9650PG3 AUTOMATIC WASHER
Whirlpool LSQ9650PG4 AUTOMATIC WASHER
Whirlpool LSQ9650PW0 AUTOMATIC WASHER
Whirlpool LSQ9650PW1 AUTOMATIC WASHER
Whirlpool LSQ9650PW2 AUTOMATIC WASHER
Whirlpool LSQ9650PW3 AUTOMATIC WASHER
Whirlpool LSQ9650PW4 AUTOMATIC WASHER
Whirlpool LSQ9659LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LG1 AUTOMATIC WASHER
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
Whirlpool LSQ9659PG3 AUTOMATIC WASHER
Whirlpool LSQ9659PG4 AUTOMATIC WASHER
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
Whirlpool LSQ9660PW3 AUTOMATIC WASHER
Whirlpool LSQ9660PW4 AUTOMATIC WASHER
Whirlpool LSQ9665JQ0 WASHER
Whirlpool LSQ9665JQ1 WASHER
Whirlpool LSQ9665JQ2 WASHER
Whirlpool LSQ9665JQ3 WASHER
Whirlpool LSQ9665JQ4 WASHER
Whirlpool LSQ9665JT0 WASHER
Whirlpool LSQ9665JT1 WASHER
Whirlpool LSQ9665JT2 WASHER
Whirlpool LSQ9665JT3 WASHER
Whirlpool LSQ9665JT4 WASHER
Whirlpool LSR4100HQ0 AUTOMATIC WASHER
Whirlpool LSR4311DQ0 WASHER
Whirlpool LSR5100HQ0 AUTOMATIC WASHER
Whirlpool LSR5100KQ0 RESIDENTIAL WASHER
Whirlpool LSR5100LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ1 AUTOMATIC WASHER
Whirlpool LSR5102LQ1 AUTOMATIC WASHER
Whirlpool LSR5121HQ0 AUTOMATIC WASHER
Whirlpool LSR5121JQ0 AUTOMATIC WASHER,
Whirlpool LSR5132AG0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AN0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AW0 DIRECT-DRIVE WASHER
Whirlpool LSR5132HQ0 AUTOMATIC WASHER
Whirlpool LSR5132HQ1 AUTOMATIC WASHER
Whirlpool LSR5132JQ0 COMPACT WASHER
Whirlpool LSR5132JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR5132JQ2 WASHER - DIRECT DRIVE
Whirlpool LSR5132PQ0 AUTOMATIC WASHER
Whirlpool LSR5132PQ1 AUTOMATIC WASHER
Whirlpool LSR5132PQ3 AUTOMATIC WASHER
Whirlpool LSR5132PQ4 AUTOMATIC WASHER
Whirlpool LSR5232DW0 AUTOMATIC WASHER
Whirlpool LSR5232LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5232LQ1 AUTOMATIC WASHER
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
Whirlpool LSR5233AW0 Washers*
Whirlpool LSR5233EQ0 AUTOMATIC WASHER
Whirlpool LSR5233EQ1 DIRECT-DRIVE WASHER
Whirlpool LSR5233EQ2 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132BN0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW1 AUTOMATIC WASHER
Whirlpool LSR6132DQ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132DZ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132EQ0 AUTOMATIC WASHER
Whirlpool LSR6132EQ1 AUTOMATIC WASHER
Whirlpool LSR6132EZ0 AUTOMATIC WASHER
Whirlpool LSR6132EZ1 AUTOMATIC WASHER
Whirlpool LSR6132HQ0 AUTOMATIC WASHER
Whirlpool LSR6132HQ1 AUTOMATIC WASHER
Whirlpool LSR6132HZ0 AUTOMATIC WASHER
Whirlpool LSR6232JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR6232JQ1 WASHER - DIRECT DRIVE
Whirlpool LSR6232JQ2 AUTOMATIC WASHER
Whirlpool LSR6233BG0 AUTOMATIC WASHER
Whirlpool LSR6233BN0 AUTOMATIC WASHER
Whirlpool LSR6233BN1 WASHER
Whirlpool LSR6233BW0 AUTOMATIC WASHER
Whirlpool LSR6233BW1 WASHER
Whirlpool LSR6233DN0 AUTOMATIC WASHER
Whirlpool LSR6233DW0 AUTOMATIC WASHER
Whirlpool LSR6244AW0 Washers*
Whirlpool LSR6332KQ0 WASHER
Whirlpool LSR6332KQ1 AUTOMATIC WASHER
Whirlpool LSR6334LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR6334LQ1 AUTOMATIC WASHER
Whirlpool LSR6335LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR7010PQ0 AUTOMATIC WASHER
Whirlpool LSR7010PQ1 AUTOMATIC WASHER
Whirlpool LSR7010PQ2 AUTOMATIC WASHER
Whirlpool LSR7133KQ0 WASHER
Whirlpool LSR7133KQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ0 AUTOMATIC WASHER
Whirlpool LSR7133PQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ2 AUTOMATIC WASHER
  #2 (permalink)
Old 05-04-2013, 07:25 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Could have a bad drive block. It's on the end of the spin tube and is used to attach the basket to the spin tube.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 05-05-2013, 07:35 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
You didn't mention the water pump. Does the noise occur regardless if pump is attached to motor or not? If not the pump, check the drive block as suggested. Make sure the grooves in the block and tabs on drive tube are engaged and intact.
Eric
  #4 (permalink)
Old 05-05-2013, 05:05 PM
Junior Member
Default
The drive block appears to be fine as there is no play in it and visually it looks good [see pic 001]; and the noise occurs without the water pump.
I put the gear case and clutch back on. Had some difficulty as the brake and drive tube had slipped out a bit, so I turned the drum and machine base upside down and it went in fine. I made sure the clutch spring was on the opposite the side of the tab on the brake cam driver. However, when I slipped the clutch assembly into the drive tube a couple of pins fell out [see pic 002] from where I do not know and have no clue as to where they go. I then reattached the motor and turned it on. In the spin cycle the drum, drive tube and shaft on the gear case all spin but then intermittently the shaft will hesitate and that is when and only when the noise occurs. Is the clutch bad?
P.S. I was going to attach a short mp4 video file (30-60 seconds) but did not know how.
  #5 (permalink)
Old 05-05-2013, 06:00 PM
Expert
APP Volunteer
Default
Those are shipping pins, just toss them out. Can you post a video on youtube? If I could hear the noise and see the agitator it would help. If the tub and agitator are spinning and then the agitator seems to quickly slow or stop with the noise at the same time you may have a bad agitator cam in the gearcase that may not present itself when you have the gearcase removed.
Eric
  #6 (permalink)
Old 05-05-2013, 07:20 PM
Junior Member
Default
Posted the video on youtube: Spin cycle - YouTube
If the drum seems to wobble a bit it is because I have it standing alone on the base without the cabinet.
  #7 (permalink)
Old 05-05-2013, 08:22 PM
Expert
APP Volunteer
Default
Yep, that sounds like a faulty agitate cam in the gearcase. It is not lifting the agitate gear completely off the drive splines on the agitator shaft. You can replace the gearcase or tear the gearcase down and replace the cam and cam follower.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Noisy Spin Cycle Dolly1 Washer Repair 2 01-13-2012 06:35 PM
Noisy Spin Cycle Danrepair Washer Repair 2 12-02-2011 07:04 PM
noisy spin cycle bgdadd Washer Repair 1 04-03-2011 08:22 AM
Spin cycle noisy bosco14 Washer Repair 9 12-28-2010 07:48 PM
Noisy spin cycle ezonana1 Washer Repair 5 02-02-2008 09:00 AM
