Register | FAQ's | New Posts | Today's Posts | Extras |
» Whirlpool washer agitator starts as soon as washer is turned on. |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() I would check to make sure the tube to the water level pressure switch is clear.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
![]() Yes, that's the model number and this washer has the load sense switch that is a high failure item and causes symptoms such as you are having. I would first check the air hose as suggested by removing it from the switch and blowing forcefully into it to see that it is not clogged. Also unplug the wire harness from the switch and plug it back in as well as the hose and try the wash cycle again. If you still have problems, replace the switch. You need to check the full model number, there should be another number after the ESVW. There's a version 0 and a version 1. Different switch for each version. For version 0, you would need this switch and for version 1, you would need this one.
Eric Last edited by fairbank56 : 05-05-2013 at 11:54 AM. |
![]() I agree with fairbanks.
May also be worth unplugging the switch and plugging it back in. It's worked more then once for me.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Whirlpool washer starts to agitate before it fills | thomasmoore | Washer Repair | 2 | 11-09-2011 07:43 AM |
Whirlpool washer starts, fills with water and nothing. | whatspoppin | Washer Repair | 1 | 10-10-2011 06:19 PM |
Whirlpool Washer Starts Stops And Hums | beverlyjean | Washer Repair | 1 | 06-02-2009 06:09 PM |
Whirlpool Washer Starts Stops And Hums | beverlyjean | Washer Repair | 1 | 06-02-2009 02:35 PM |
Whirlpool Washer Agitator | randym | Washer Repair | 1 | 09-20-2008 06:42 AM |
