Discuss
Bosch Washing Machine Diagnostic / Test Mode
 in
Washer Repair
Hello, my 3 year old bosch washing machine will not finish its cycle. When it gets to the end spin
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Bosch Washing Machine Diagnostic / Test Mode
  #1 (permalink)
Old 05-02-2013, 05:31 PM
Junior Member
kengilbert3 is on a distinguished road
Default Bosch Washing Machine Diagnostic / Test Mode
Model Number: WFVC3300UC/24   Brand: Bosch   Age: 1 - 5 years
Hello, my 3 year old bosch washing machine will not finish its cycle. When it gets to the end spin of the program it flashes an "E:12" code. It does this on all cycles. Once in a while it will run all the way through. Also, all three compartments in the draw are filled with water. Is this normal? The last symptom is that the timer display jumps to different values, one second it reads 50 minutes then it jump to 1 hour and 15 minutes. I do not believe it is one of the valves because I can set it to Drain and Spin and it finishes the cycle. Also I have the same problem on all the cycles so all the valves work at the front end of each program. Next I cleaned out the drain and made certain the drain pump is working and it is. Last I checked the feed hose for kinks and clogs and found nothing, I also cleaned the inlet strainer still getting the same error code. I took the top off of the machine and found a piece of paper from the factory with a diagnostic / test mode procedure and I ran this for my error code. This produced two sets of numbers a 63 and 88. Does anyone know what this means and how to use them to fix my machine?
Related Models
Whirlpool WFW8200TW00 AUTOMATIC WASHER
Whirlpool WFW8200TW01 AUTOMATIC WASHER
Whirlpool WFW8300SW0 AUTOMATIC WASHER
Whirlpool WFW8300SW00 RESIDENTIAL WASHER
Whirlpool WFW8300SW01 RESIDENTIAL WASHER
Whirlpool WFW8300SW02 AUTOMATIC WASHER
Whirlpool WFW8300SW03 AUTOMATIC WASHER
Whirlpool WFW8300SW04 AUTOMATIC WASHER
Whirlpool WFW8300SW05 AUTOMATIC WASHER
Whirlpool WFW8300SW1 AUTOMATIC WASHER
Whirlpool WFW8400TB00 AUTOMATIC WASHER
Whirlpool WFW8400TB01 AUTOMATIC WASHER
Whirlpool WFW8400TB02 AUTOMATIC WASHER
Whirlpool WFW8400TE00 AUTOMATIC WASHER
Whirlpool WFW8400TE01 AUTOMATIC WASHER
Whirlpool WFW8400TW00 AUTOMATIC WASHER
Whirlpool WFW8400TW01 AUTOMATIC WASHER
Whirlpool WFW8400TW02 AUTOMATIC WASHER
Whirlpool WFW8400TW03 AUTOMATIC WASHER
Whirlpool WFW8410SW0 AUTOMATIC WASHER
Whirlpool WFW8410SW01 AUTOMATIC WASHER
Whirlpool WFW8410SW02 AUTOMATIC WASHER
Whirlpool WFW8410SW03 AUTOMATIC WASHER
Whirlpool WFW8500SR0 AUTOMATIC WASHER
Whirlpool WFW8500SR01 AUTOMATIC WASHER
Whirlpool WFW8500SR02 AUTOMATIC WASHER
Whirlpool WFW8500SR03 AUTOMATIC WASHER
Whirlpool WFW8500SR04 AUTOMATIC WASHER
Whirlpool WFW9050XW00 AUTOMATIC WASHER
Whirlpool WFW9050XW01 AUTOMATIC WASHER
Whirlpool WFW9050XW02 AUTOMATIC WASHER
Whirlpool WFW9050XW03 AUTOMATIC WASHER
Whirlpool WFW9150WW00 AUTOMATIC WASHER
Whirlpool WFW9150WW01 AUTOMATIC WASHER
Whirlpool WFW9150WW02 AUTOMATIC WASHER
Whirlpool WFW9151YW00 WASHER
Whirlpool WFW9200SQ00 AUTOMATIC WASHER
Whirlpool WFW9200SQ01 AUTOMATIC WASHER
Whirlpool WFW9200SQ02 AUTOMATIC WASHER
Whirlpool WFW9200SQ03 AUTOMATIC WASHER
Whirlpool WFW9200SQ04 AUTOMATIC WASHER
Whirlpool WFW9200SQ10 AUTOMATIC WASHER
Whirlpool WFW9200SQA10 AUTOMATIC WASHER
Whirlpool WFW9200SQA11 AUTOMATIC WASHER
Whirlpool WFW9200SQA12 AUTOMATIC WASHER
Whirlpool WFW9250WL00 AUTOMATIC WASHER
Whirlpool WFW9250WL01 AUTOMATIC WASHER
Whirlpool WFW9250WL02 AUTOMATIC WASHER
Whirlpool WFW9250WR00 AUTOMATIC WASHER
Whirlpool WFW9250WR01 AUTOMATIC WASHER
Whirlpool WFW9250WR02 AUTOMATIC WASHER
Whirlpool WFW9250WW00 AUTOMATIC WASHER
Whirlpool WFW9250WW01 AUTOMATIC WASHER
Whirlpool WFW9250WW02 WASHER
Whirlpool WFW9300VU02 AUTOMATIC WASHER
Whirlpool WFW9300VU03 AUTOMATIC WASHER
Whirlpool WFW9300VU04 AUTOMATIC WASHER
Whirlpool WFW9351YL00 AUTOMATIC WASHER
Whirlpool WFW9351YW00 AUTOMATIC WASHER
Whirlpool WFW9400SB00 AUTOMATIC WASHER
Whirlpool WFW9400SB01 AUTOMATIC WASHER
Whirlpool WFW9400SB02 AUTOMATIC WASHER
Whirlpool WFW9400SBA10 AUTOMATIC WASHER
Whirlpool WFW9400ST00 AUTOMATIC WASHER
Whirlpool WFW9400ST01 AUTOMATIC WASHER
Whirlpool WFW9400ST02 AUTOMATIC WASHER
Whirlpool WFW9400STA10 AUTOMATIC WASHER
Whirlpool WFW9400SU00 AUTOMATIC WASHER
Whirlpool WFW9400SU01 AUTOMATIC WASHER
Whirlpool WFW9400SU02 AUTOMATIC WASHER
Whirlpool WFW9400SW00 AUTOMATIC WASHER
Whirlpool WFW9400SW01 AUTOMATIC WASHER
Whirlpool WFW9400SW02 AUTOMATIC WASHER
Whirlpool WFW9400SW03 AUTOMATIC WASHER
Whirlpool WFW9400SW04 AUTOMATIC WASHER
Whirlpool WFW9400SWA10 AUTOMATIC WASHER
Whirlpool WFW9400SZ00 AUTOMATIC WASHER
Whirlpool WFW9400SZ01 AUTOMATIC WASHER
Whirlpool WFW9400SZ02 AUTOMATIC WASHER
Whirlpool WFW9400SZ03 AUTOMATIC WASHER
Whirlpool WFW9400SZ04 AUTOMATIC WASHER
Whirlpool WFW9400SZA10 AUTOMATIC WASHER
Whirlpool WFW9400VE01 AUTOMATIC WASHER
Whirlpool WFW9400VE02 AUTOMATIC WASHER
Whirlpool WFW9400VE03 AUTOMATIC WASHER
Whirlpool WFW9410XW00 WASHER
Whirlpool WFW9450WL00 AUTOMATIC WASHER
Whirlpool WFW9450WR00 AUTOMATIC WASHER
Whirlpool WFW9450WW00 AUTOMATIC WASHER
Whirlpool WFW9451XW00 AUTOMATIC WASHER
Whirlpool WFW9470WL00 AUTOMATIC WASHER
Whirlpool WFW9470WL01 AUTOMATIC WASHER
Whirlpool WFW9470WR00 AUTOMATIC WASHER
Whirlpool WFW9470WR01 AUTOMATIC WASHER
Whirlpool WFW9470WW00 AUTOMATIC WASHER
Whirlpool WFW9470WW01 AUTOMATIC WASHER
Whirlpool WFW94HEXL0 WASHER
Whirlpool WFW94HEXL1 AUTOMATIC WASHER
Whirlpool WFW94HEXL2 AUTOMATIC WASHER
Whirlpool WFW94HEXR0 WASHER
Whirlpool WFW94HEXR1 AUTOMATIC WASHER
Whirlpool WFW94HEXR2 AUTOMATIC WASHER
Whirlpool WFW94HEXW0 WASHER
Whirlpool WFW94HEXW1 AUTOMATIC WASHER
Whirlpool WFW94HEXW2 AUTOMATIC WASHER
Whirlpool WFW9500TC00 AUTOMATIC WASHER
Whirlpool WFW9500TC01 AUTOMATIC WASHER
Whirlpool WFW9500TC02 AUTOMATIC WASHER
Whirlpool WFW9500TC03 AUTOMATIC WASHER
Whirlpool WFW9500TW00 AUTOMATIC WASHER
Whirlpool WFW9500TW01 AUTOMATIC WASHER
Whirlpool WFW9500TW02 AUTOMATIC WASHER
Whirlpool WFW9500TW03 AUTOMATIC WASHER
Whirlpool WFW9550WL00 AUTOMATIC WASHER
Whirlpool WFW9550WL01 AUTOMATIC WASHER
Whirlpool WFW9550WL10 AUTOMATIC WASHER
Whirlpool WFW9550WR00 AUTOMATIC WASHER
Whirlpool WFW9550WR01 AUTOMATIC WASHER
Whirlpool WFW9550WW00 AUTOMATIC WASHER
Whirlpool WFW9550WW01 AUTOMATIC WASHER
  #2 (permalink)
Old 05-04-2013, 07:42 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Should say what the codes mean on the tech sheet you found. If not I could try and find out.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
BOSCH Axxis Diagnostic / Test Mode? joeyd1 Washer Repair 4 04-10-2017 01:57 PM
Washing machine does not SPIN during RINSE mode. Fastmhz Washer Repair 5 02-20-2013 08:20 AM
Bosch Dishwasher - lights flashing, wont go into diagnostic mode kodiakdawg Dishwasher Repair 0 07-18-2012 09:44 AM
Washing Machine doesn't advance to spin in Ultra Clean mode but does OK in Perm Press ashlynhall Washer Repair 0 03-01-2012 03:22 PM
diagnostic test mode? Bob Watts Washer Repair 8 05-22-2009 07:49 PM
