Discuss
Whirlpool - Won't Spin
 in
Washer Repair
According to my wife (I wasn't home when this happened), our Whirlpool washer made a very loud noise mid-cycle and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool - Won't Spin
  #1 (permalink)
Old 05-02-2013, 08:29 AM
Junior Member
thefishguy is on a distinguished road
Default Whirlpool - Won't Spin
Model Number: LA7780XSWO   Brand: Whirlpool   Age: 5 - 10 years
According to my wife (I wasn't home when this happened), our Whirlpool washer made a very loud noise mid-cycle and stopped, dead.
Since then, it will fill up and agitate, but when it comes to the spin cycle, the timer stops moving, and nothing happens. It just sits. There is no noise, no sounds, nothing.
We're graduate students and living on student loans (which are depleted), so any help anyone can offer would be greatly appreciated!
Thank you!
Related Models
Maytag LA7800 WASHER-TOP LOADING
Whirlpool LA7800XKW2
Whirlpool LA7800XMW0
Whirlpool LA7800XPW0
Whirlpool LA7800XPW1 Washers*
Whirlpool LA7800XSF2 AUTOMATIC WASHER
Whirlpool LA7800XSG2 AUTOMATIC WASHER
Whirlpool LA7800XSM2 AUTOMATIC WASHER
Whirlpool LA7800XSN1 AUTOMATIC WASHER
Whirlpool LA7800XSN2 AUTOMATIC WASHER
Whirlpool LA7800XSW0
Whirlpool LA7800XSW1
Whirlpool LA7800XSW2
Whirlpool LA7800XTF0 AUTOMATIC WASHER
Whirlpool LA7800XTF1 AUTOMATIC WASHER
Whirlpool LA7800XTG0 AUTOMATIC WASHER
Whirlpool LA7800XTG1 AUTOMATIC WASHER
Whirlpool LA7800XTM0 AUTOMATIC WASHER
Whirlpool LA7800XTM1 AUTOMATIC WASHER
Whirlpool LA7800XTN0 AUTOMATIC WASHER
Whirlpool LA7800XTN1 AUTOMATIC WASHER
Whirlpool LA7800XTW0
Whirlpool LA7800XTW1
Whirlpool LA7801XTF0
Whirlpool LA7801XTG0
Whirlpool LA7801XTM0
Whirlpool LA7801XTN0
Whirlpool LA7801XTW0
Whirlpool LA7899XPW3
Whirlpool LA7900XPW1
Whirlpool LA7900XSW0
Whirlpool LA7900XSW1
Whirlpool LA7900XSW2
Whirlpool LA7900XTF0
Whirlpool LA7900XTG0
Whirlpool LA7900XTG1
Whirlpool LA7900XTM0
Whirlpool LA7900XTN0
Whirlpool LA7900XTN1
Whirlpool LA7900XTW0
Whirlpool LA7900XTW1
Whirlpool LA7980XSW0
Frigidaire LA800AXD1 Wwh(v2) / 27 " Washer
Frigidaire LA800AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA800AXW1 Wwh(v1) / 27 " Washer
Frigidaire LA800AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA800JXD4 Wwh(v1) / Washer
Frigidaire LA800JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA800JXF4 Wwh(v2) / Washer
Frigidaire LA800JXH4 Wwh(v3) / Washer
Frigidaire LA800JXH5 Wwh(v2) / Top Load Washer
Frigidaire LA800JXV4 Wwh(v4) / Washer
Frigidaire LA800JXW4 Wwh(v5) / Washer
Frigidaire LA800JXW5 Wwh(v3) / Top Load Washer
Frigidaire LA800MXD1 Wwh(v9) / 27 " Washer
Frigidaire LA800MXD2 Wwh(v9) / 27 " Washer
Frigidaire LA800MXH1 Wwh(v8) / 27 " Washer
Frigidaire LA800MXH2 Wwh(v8) / 27 " Washer
Frigidaire LA800MXW1 Wwh(v7) / 27 " Washer
Frigidaire LA800MXW2 Wwh(v7) / 27 " Washer
Maytag LA806 WASHER-TOP LOADING
Maytag LA806S WASHER-TOP LOADING
Maytag LA810 WASHER-TOP LOADING
Maytag LA8100 WASHER-TOP LOADING
Whirlpool LA8100XWW0
Whirlpool LA8100XWW1
Maytag LA8120 WASHER-TOP LOADING
Maytag LA8140 WASHER-TOP LOADING
Maytag LA8200 WASHER-TOP LOADING
Whirlpool LA8200XWW0
Whirlpool LA8200XWW1
Maytag LA8210 WASHER-TOP LOADING
Maytag LA8240 WASHER-TOP LOADING
Maytag LA8340 WASHER-TOP LOADING
Amana LA83830.A MWAVE - FAMILY SIZE (60 HZ)
Whirlpool LA8400XWF0
Whirlpool LA8400XWF1
Whirlpool LA8400XWG0
Whirlpool LA8400XWG1
Whirlpool LA8400XWM0
Whirlpool LA8400XWM1
Whirlpool LA8400XWN0
Whirlpool LA8400XWN1
Whirlpool LA8400XWW0
Whirlpool LA8400XWW1
Maytag LA8420 WASHER-TOP LOADING
Maytag LA8440 WASHER-TOP LOADING
Maytag LA8500 WASHER-TOP LOADING
Maytag LA8520 WASHER-TOP LOADING
Whirlpool LA8580XWF0
Whirlpool LA8580XWF1
Whirlpool LA8580XWF2
Whirlpool LA8580XWG0
Whirlpool LA8580XWG1
Whirlpool LA8580XWG2
Whirlpool LA8580XWM0
Whirlpool LA8580XWM1
Whirlpool LA8580XWM2
Whirlpool LA8580XWN0
Whirlpool LA8580XWN1
Whirlpool LA8580XWN2
Whirlpool LA8580XWW0
Whirlpool LA8580XWW1
Whirlpool LA8580XWW2
Maytag LA8600 WASHER-TOP LOADING
Maytag LA8640 WASHER-TOP LOADING
Maytag LA8650 WASHER-TOP LOADING
Maytag LA8700 WASHER-TOP LOADING
Maytag LA8740 WASHER-TOP LOADING
Maytag LA8800 WASHER-TOP LOADING
Whirlpool LA8800XSW0
Whirlpool LA8800XSW1
Whirlpool LA8800XSW2
Whirlpool LA8800XTF0
Whirlpool LA8800XTF1
Whirlpool LA8800XTG0
Whirlpool LA8800XTG1
Whirlpool LA8800XTM0
Whirlpool LA8800XTM1
Whirlpool LA8800XTN0
  #2 (permalink)
Old 05-02-2013, 01:20 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Check the lid switch. Won't spin with faulty lid switch nor will the timer advance.
Eric
  #3 (permalink)
Old 05-03-2013, 11:21 PM
Junior Member
Default Found part of the problem, maybe?
Okay, the timer does advance. So, can it still be the lid switch?
Here's the likely culprit, however. I took the casing off, with plans to check the lid switch. Before I started messing with wires, however, I thought I should perhaps see if the tub can turn by hand (I read this somewhere else).
Well, the tub could not be turned by hand. Also, the base of the agitator would not turn either. The top of the agitator did, and would operate on the agitate cycle (but the base stayed stationary).
So, I jiggled the tub around a bit, trying to turn it with a little pressure, and voila... one of my wife's metal barrettes/hair clips popped out. And then, the tub and agitator base would freely move by hand.
So, I'm thinking... hey, that's it! So, I put everything back together, and still, no spin cycle. The base of the agitator now works with the top part, on the agitate cycle--and the timer works too. When it gets around to the spin cycle, it just times through and the machine does nothing. The timer just keeps on turning until it gets to off.
Ideas? Help? Please?
  #4 (permalink)
Old 05-04-2013, 01:33 AM
Junior Member
Default Fixed it
It was the lid switch, thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool won't spin gloriacross Washer Repair 1 08-08-2011 08:07 PM
Whirlpool washer won't spin on rinse cycle or high spin bry21317 Washer Repair 10 05-24-2011 12:25 PM
whirlpool will not spin mechanix247 Washer Repair 1 03-02-2010 08:31 PM
Whirlpool Tries to Spin ddoering Washer Repair 10 06-13-2009 10:15 PM
whirlpool washer won't spin manually or spin boniam Washer Repair 15 06-29-2008 07:19 AM
