Discuss
Amana Washer cylinder thrown off center
 in
Washer Repair
On spin cycle, after a thump, washer stopped, as if the load was unbalanced. I rearranged laundry and jiggled cylinder
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Amana Washer cylinder thrown off center
  #1 (permalink)
Old 04-27-2013, 04:40 PM
Junior Member
Jennifer Metzler is on a distinguished road
Default Amana Washer cylinder thrown off center
Model Number: LW4302W   Brand: Amana   Age: More than 10 years
On spin cycle, after a thump, washer stopped, as if the load was unbalanced. I rearranged laundry and jiggled cylinder back to center. This worked for a few seconds, but after another thump, washer stopped. I repeated process several times before taking clothes out to drip dry. The cycle continued as if normal with no clothes in cylinder.
A mechanically inclined friend suggested the bearing might be shot. To access the bearing, I took off the cap on top of agitator (where laundry softner goes), but can't seem to figure out what should come off next. He said the agitator would need come off, then I should see a nut that will let me get to the bearing. This looks accurate according to a web site that shows the succession of parts.
Any insight into if this might be a bearing issue? And how do I get the agitator off to access the nut to get to the bearing?
Related Models
Amana LW4302W WASHER-TOP LOADING
Amana LW4303L WASHER-TOP LOADING
Amana LW4303W WASHER-TOP LOADING
Amana LW4603L WASHER-TOP LOADING
Amana LW4603W WASHER-TOP LOADING
 LW5200ER Air Conditioner
Amana LW6001W2 WASHER-TOP LOADING
Amana LW6101WB WASHER-TOP LOADING
Amana LW6111LB WASHER-TOP LOADING
Amana LW6111WB WASHER-TOP LOADING
Amana LW6123LM WASHER-TOP LOADING
Amana LW6123WM WASHER-TOP LOADING
Amana LW6143LM WASHER-TOP LOADING
Amana LW6143WM WASHER-TOP LOADING
Amana LW6153LB WASHER-TOP LOADING
Amana LW6153LM WASHER-TOP LOADING
Amana LW6153WB WASHER-TOP LOADING
Amana LW6153WM WASHER-TOP LOADING
Amana LW6163LM WASHER-TOP LOADING
Amana LW6163WM WASHER-TOP LOADING
Amana LW6501W2 WASHER-TOP LOADING
Amana LW6501W2B WASHER-TOP LOADING
Amana LW6601W2 WASHER-TOP LOADING
Amana LW6661W2 WASHER-TOP LOADING
Amana LW7503L2 WASHER-TOP LOADING
Amana LW7503W2 WASHER-TOP LOADING
Amana LW7563W2 WASHER-TOP LOADING
 LW8000ER Air Conditioner
Amana LW8201L2 WASHER-TOP LOADING
Amana LW8201W2 WASHER-TOP LOADING
Amana LW8203L2 WASHER-TOP LOADING
Amana LW8203W WASHER-TOP LOADING
Amana LW8203W2 WASHER-TOP LOADING
Amana LW8203W2B WASHER-TOP LOADING
Amana LW8252L2 WASHER-TOP LOADING
Amana LW8252W2 WASHER-TOP LOADING
Amana LW8253W WASHER-TOP LOADING
Amana LW8263W2 WASHER-TOP LOADING
Amana LW8303L2 WASHER-TOP LOADING
Amana LW8303W2 WASHER-TOP LOADING
Amana LW8312L2 WASHER-TOP LOADING
Amana LW8312W2 WASHER-TOP LOADING
Amana LW8363L2 WASHER-TOP LOADING
Amana LW8363W2 WASHER-TOP LOADING
Amana LW8403W WASHER-TOP LOADING
Amana LW8413L2 WASHER-TOP LOADING
Amana LW8413W2 WASHER-TOP LOADING
Amana LW8413W2B WASHER-TOP LOADING
Amana LW8463L2 WASHER-TOP LOADING
Amana LW8463W2 WASHER-TOP LOADING
Amana LW9003 WASHER-TOP LOADING
Amana LW9103 WASHER-TOP LOADING
Amana LW9103W WASHER-TOP LOADING
Amana LW9203L2 WASHER-TOP LOADING
Amana LW9203W WASHER-TOP LOADING
Amana LW9203W2 WASHER-TOP LOADING
Amana LWA05AW WASHER-TOP LOADING
Amana LWA10AW WASHER-TOP LOADING
Amana LWA18AW WASHER-TOP LOADING
Amana LWA20AW WASHER-TOP LOADING
Amana LWA30AL WASHER-TOP LOADING
Amana LWA30AW WASHER-TOP LOADING
Amana LWA30BL WASHER-TOP LOADING
Amana LWA30BW WASHER-TOP LOADING
Amana LWA40AL WASHER-TOP LOADING
Amana LWA40AL2 WASHER-TOP LOADING
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Washer leaking from center digerdo2 Washer Repair 1 04-16-2013 01:21 PM
Amana Washer leaking from center digerdo2 Washer Repair 0 04-13-2013 07:15 PM
KENMORE not cooling-food thrown out johnny wen Refrigerator & Freezer Repair 4 03-07-2011 12:30 PM
replacing a rear cylinder seal on an Amana dryer David Freeman Dryer Repair 1 06-15-2010 03:20 AM
Washer leaks at the center of the tub presmique Washer Repair 9 12-27-2007 03:27 AM
