Discuss
Washing machine motor buzzes depending on motor shaft position
 in
Washer Repair
After running a (potentially overloaded) load of heavy towels, I noticed that the tub hadn't drained and that the motor
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washing machine motor buzzes depending on motor shaft position
  #1 (permalink)
Old 04-26-2013, 02:59 PM
Junior Member
fixitboy is on a distinguished road
Default Washing machine motor buzzes depending on motor shaft position
Model Number: KAWE860W   Brand: Kitchen Aid   Age: 5 - 10 years
After running a (potentially overloaded) load of heavy towels, I noticed that the tub hadn't drained and that the motor was "humming" but the tub was not spinning (or pumping) in any cycle position.
I took the machine apart, expecting to see a broken motor coupler or transmission -- but the coupler and transmission were intact.
I measured the resistances on the 3-windings and they all measured ok (in the typical 1-5 ohm range).
I bypassed the lid safety switch to see if the motor spins and found that in one orientation of the motor shaft, the motor just hummed/buzzed loudly and wouldn't spin at all (or it would eventually start after the humming/buzzing caused it to rotate a bit to a new position). In the other shaft orientations, the motor started though it didn't seem to spin that smoothly (however the motor was loose on the ground with the coupler on so perhaps it is naturally a little unbalanced).
Are there any dirty/worn brushes that could be causing this problem?
Any ideas what might be wrong and how to fix it?
Or do I need to replace the motor? (or is it rebuildable)
Thanks!
Related Models
Whirlpool KAWE860WAL0
Whirlpool KAWE860WAL1
Whirlpool KAWE860WAL2
Whirlpool KAWE860WAL3
Whirlpool KAWE860WWH0
Whirlpool KAWE860WWH1
Whirlpool KAWE860WWH2
Whirlpool KAWE860WWH3
Whirlpool KAWE870BAL0
Whirlpool KAWE870BWH0
Whirlpool KAWE870BWH1
Whirlpool KAWE877BWH1
Whirlpool KAWE878BAL1
Whirlpool KAWE900SWH1
Whirlpool KAWE900SWH2
Whirlpool KAWE900TWH0
Whirlpool KAWE900TWH1
Whirlpool KAWE950VAL0
Whirlpool KAWE950VWH0
Whirlpool KAWE960WAL0
Whirlpool KAWE960WAL1
Whirlpool KAWE960WWH0
Whirlpool KAWE960WWH1
Whirlpool KAWE977BWH0
Whirlpool KAWE977DWH0
Whirlpool KAWL400WAL0
Whirlpool KAWL400WAL1
Whirlpool KAWL400WWH0
Whirlpool KAWL400WWH1
Whirlpool KAWL410BAL0
Whirlpool KAWL410BWH0
Whirlpool KAWL410BWH1
Whirlpool KAWL500WAL0
Whirlpool KAWL500WWH0
Whirlpool KAWL510BAL0
Whirlpool KAWL510BWH0
Whirlpool KAWL517BWH0
Whirlpool KAWL517BWH1
Whirlpool KAWS577EQ0 DIRECT-DRIVE WASHER
Whirlpool KAWS577EZ0 DIRECT-DRIVE WASHER
Whirlpool KAWS677EQ0 DIRECT-DRIVE WASHER
Whirlpool KAWS677EZ0 DIRECT-DRIVE WASHER
Whirlpool KAWS700EQ0 DIRECT-DRIVE HOME WASHERS
Whirlpool KAWS700EZ0 DIRECT-DRIVE HOME WASHERS
Whirlpool KAWS700GQ0 AUTOMATIC WASHER
Whirlpool KAWS700GT0 AUTOMATIC WASHER
Whirlpool KAWS700GZ0 AUTOMATIC WASHER
Whirlpool KAWS700JQ0 RESIDENTIAL WASHER
Whirlpool KAWS700JQ1 RESIDENTIAL WASHERS
Whirlpool KAWS700JQ2 RESIDENTIAL WASHERS
Whirlpool KAWS700JQ3 RESIDENTIAL WASHER
Whirlpool KAWS700JQ4 RESIDENTIAL WASHERS
Whirlpool KAWS700JT0 RESIDENTIAL WASHER
Whirlpool KAWS700JT1 RESIDENTIAL WASHERS
Whirlpool KAWS700JT2 RESIDENTIAL WASHERS
Whirlpool KAWS700JT3 RESIDENTIAL WASHER
Whirlpool KAWS700JT4 RESIDENTIAL WASHERS
Whirlpool KAWS700LQ0 RESIDENTIAL WASHERS
Whirlpool KAWS700LT0 RESIDENTIAL WASHERS
Whirlpool KAWS750GQ0 AUTOMATIC WASHER
Whirlpool KAWS750GQ1 AUTOMATIC WASHER
Whirlpool KAWS750GT1 AUTOMATIC WASHER
Whirlpool KAWS750GZ0 AUTOMATIC WASHER
Whirlpool KAWS750GZ1 AUTOMATIC WASHER
Whirlpool KAWS750JQ0 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ1 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ2 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ3 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ4 RESIDENTIAL WASHERS
Whirlpool KAWS750JT0 RESIDENTIAL WASHERS
Whirlpool KAWS750JT1 RESIDENTIAL WASHERS
Whirlpool KAWS750JT2 RESIDENTIAL WASHERS
Whirlpool KAWS750JT3 RESIDENTIAL WASHERS
Whirlpool KAWS750JT4 RESIDENTIAL WASHERS
Whirlpool KAWS750LQ0 AUTOMATIC WASHER
Whirlpool KAWS750LQ1 AUTOMATIC WASHER
Whirlpool KAWS750LQ2 AUTOMATIC WASHER
Whirlpool KAWS750LQ3 AUTOMATIC WASHER
Whirlpool KAWS750LQ4 AUTOMATIC WASHER
Whirlpool KAWS750LT0 AUTOMATIC WASHER
Whirlpool KAWS750LT1 AUTOMATIC WASHER
Whirlpool KAWS750LT2 AUTOMATIC WASHER
Whirlpool KAWS750LT3 AUTOMATIC WASHER
Whirlpool KAWS750LT4 AUTOMATIC WASHER
Whirlpool KAWS777EQ0 DIRECT-DRIVE WASHER
Whirlpool KAWS777EZ0 DIRECT-DRIVE WASHER
Whirlpool KAWS800GQ0 AUTOMATIC WASHER
Whirlpool KAWS800GQ1 AUTOMATIC WASHER
Whirlpool KAWS800GZ0 AUTOMATIC WASHER
Whirlpool KAWS800GZ1 AUTOMATIC WASHER
Whirlpool KAWS850GQ0 AUTOMATIC WASHER
Whirlpool KAWS850GQ1 AUTOMATIC WASHER
Whirlpool KAWS850GT0 AUTOMATIC WASHER
Whirlpool KAWS850GT1 AUTOMATIC WASHER
Whirlpool KAWS850GZ0 AUTOMATIC WASHER
Whirlpool KAWS850GZ1 AUTOMATIC WASHER
Whirlpool KAWS850JQ0 AUTOMATIC WASHER
Whirlpool KAWS850JQ1 AUTOMATIC WASHER
Whirlpool KAWS850JQ2 AUTOMATIC WASHER
Whirlpool KAWS850JQ3 AUTOMATIC WASHER
Whirlpool KAWS850JQ4 AUTOMATIC WASHER
Whirlpool KAWS850JT0 AUTOMATIC WASHER
Whirlpool KAWS850JT1 AUTOMATIC WASHER
Whirlpool KAWS850JT2 AUTOMATIC WASHER
Whirlpool KAWS850JT3 AUTOMATIC WASHER
Whirlpool KAWS850JT4 AUTOMATIC WASHER
Whirlpool KAWS850LE0 AUTOMATIC WASHER
Whirlpool KAWS850LE1 AUTOMATIC WASHER
Whirlpool KAWS850LE2 AUTOMATIC WASHER
Whirlpool KAWS850LQ0 AUTOMATIC WASHER
Whirlpool KAWS850LQ1 AUTOMATIC WASHER
Whirlpool KAWS850LQ2 AUTOMATIC WASHER
Whirlpool KAWS850LT0 AUTOMATIC WASHER
Whirlpool KAWS850LT1 AUTOMATIC WASHER
Whirlpool KAWS850LT2 AUTOMATIC WASHER
Whirlpool KAWS855JE0 WASHER
Whirlpool KAWS855JE1 WASHER
Whirlpool KAWS855JE2 WASHER
Whirlpool KAWS855JE3 WASHER
Whirlpool KAWS855JE4 WASHER
  #2 (permalink)
Old 04-26-2013, 08:15 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
These are induction motors, no brushes nor are they rebuildable. This is a 3 speed motor so there are 4 windings. Need to check the motor while sitting on the floor in agitate mode. If it works ok in agitate but not in drain/spin, you may have a bad lid switch, timer or motor. You would need to take some live line voltage measurements to pinpoint the problem.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker motor-shaft stuck in the motor Carlabal Refrigerator & Freezer Repair 1 09-17-2015 09:02 AM
Dryer Motor pully loose on motor shaft mfritsch Dryer Repair 3 01-07-2013 11:52 AM
Dryer Buzzes - Motor Switch or Motor? CDG20T8W Dryer Repair 0 03-17-2012 12:23 PM
washing motor buzzes, won't start ortbalso Washer Repair 2 03-14-2012 01:34 PM
Washing machine Motor LinRH Washer Repair 2 08-27-2009 01:20 PM
