washer fills then stops and beeps with washer light blinking
Hi, Which light was blinking? If it was the Wash LED, then it represents the error code by the number of times the LED flashes. The first set of flashes represents the "F" and the second set of flashes represents the "E". There is a pause of 2 seconds between the flashes for "F" and "E". The error code sequence will repeat after a pause of 5 seconds. Watch them and post the results. Here are the breakdown diagrams and Parts for Whirlpool WFW9150WW01 Washer - AppliancePartsPros.comGene.
