Discuss
Washer won't agitate
 in
Washer Repair
The machine fills with water but won't agitate. It drains and spins fine. Motor start switch tested ok. Lid switch
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't agitate
  #1 (permalink)
Old 04-25-2013, 06:33 PM
Junior Member
Reddhush is on a distinguished road
Default Washer won't agitate
Model Number: RAX4232KQ1   Brand: Roper   Age: 5 - 10 years
The machine fills with water but won't agitate. It drains and spins fine. Motor start switch tested ok. Lid switch tested ok. Coupler is good. It will agitate when turning motor by hand, so transmission is ok. Found a burned white wire from motor winding to what I'm assuming is the thermal cutoff switch. there is continuity from lid switch to this white wire when all is connected. Please help.
Related Models
Roper RAX4232KQ1 AUTOMATIC WASHER
Roper RAX4232PQ0 AUTOMATIC WASHER
Roper RAX4232PQ1 AUTOMATIC WASHER
Roper RAX4232RQ0 AUTOMATIC WASHER
Roper RAX4232RQ1 AUTOMATIC WASHER
Roper RAX4232RQ3 AUTOMATIC WASHER
Roper RAX4232RQ4 AUTOMATIC WASHER
Roper RAX4233PQ0 AUTOMATIC WASHER
Maytag RAX5000AXB MISC / ACCESSORY
Maytag RAX5000CXB MISC / ACCESSORY
Maytag RAX5100AXB MISC / ACCESSORY
Whirlpool RAX5133AG0
Whirlpool RAX5133AL0
Roper RAX5133AL1 AUTOMATIC WASHER
Roper RAX5133AW0 Washers*
Maytag RAX5200AXB MISC / ACCESSORY
Maytag RAX5200CXB MISC / ACCESSORY
Maytag RAX5300AXB MISC / ACCESSORY
Maytag RAX5400AXB MISC / ACCESSORY
Maytag RAX5500AXB MISC / ACCESSORY
Maytag RAX5500CXB MISC / ACCESSORY
Maytag RAX5600AXB MISC / ACCESSORY
Maytag RAX5700AXB MISC / ACCESSORY
Maytag RAX5700CXB MISC / ACCESSORY
Whirlpool RAX6144EN0
Whirlpool RAX6144EN1
Whirlpool RAX6144EQ0
Whirlpool RAX6144EQ1
Whirlpool RAX6144EW0
Whirlpool RAX6144EW1
Roper RAX7244EN0 WASHER
Roper RAX7244EN1 WASHER
Roper RAX7244EQ0 WASHER
Roper RAX7244EQ1 WASHER
Roper RAX7244EW0 WASHER
Roper RAX7244EW1 WASHER
Roper RAX7244JQ0 WASHER
Roper RAX7244KQ0 WASHER
Roper RAX7244KQ1 AUTOMATIC WASHER
Roper RAX7244KQ2 AUTOMATIC WASHER
Roper RAX7244PQ0 AUTOMATIC WASHER
Roper RAX7244PQ1 AUTOMATIC WASHER
Whirlpool RAX7245AG0
Whirlpool RAX7245AL0
Roper RAX7245AW0 Washers*
Roper RAX7245BL1 AUTOMATIC WASHER
Roper RAX7245BQ1 AUTOMATIC WASHER
Roper RAX7245BW0 DIRECT-DRIVE AUTOMATIC WASHER
Roper RAX7245BW1 AUTOMATIC WASHER
Roper RAX7245JQ0 WASHER
Roper RAX7245KQ0 WASHER
Roper RAX7245KQ1 AUTOMATIC WASHER
Whirlpool RB1000XKW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XKW1 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XKW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYN2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1005XYN3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYN5 24" ELECTRIC OVEN
Whirlpool RB1005XYW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYW2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1005XYW3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYW5 24" ELECTRIC OVEN
Whirlpool RB100PXK-0 24" ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXK0
Whirlpool RB100PXK1 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXK2 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV0 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV2 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV3 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB0 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB100PXYB3 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB5 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1200XKW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XKW1 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XKW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XVW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XVW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXK1 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXK2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV0 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV1 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV3 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXYB0 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXYB2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB120PXYB3 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB120PXYB5 24" ELECTRIC OVEN
Whirlpool RB1300XKW1 COOKTOP
Frigidaire RB130FA0 Frg(v5) / Electric Range
Frigidaire RB130FF0 Frg(v4) / Electric Range
Frigidaire RB130FH0 Frg(v6) / Electric Range
Frigidaire RB130FL0 Frg(v3) / Electric Range
Frigidaire RB130FM0 Frg(v2) / Electric Range
Frigidaire RB130FW0 Frg(v1) / Electric Range
Whirlpool RB130PXK0 BUILT IN DOUBLE OVEN
Whirlpool RB130PXK1 BUILT IN DOUBLE OVEN
Whirlpool RB130PXK2 BUILT IN DOUBLE OVEN
Whirlpool RB130PXK3 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV0 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV1 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV3 BUILT IN DOUBLE OVEN
Whirlpool RB130PXV4 BUILT IN DOUBLE OVEN
Frigidaire RB131CA0 Frg(v1) / Electric Cooktop
Frigidaire RB131CA1 Frg(v1) / Built - in Electric Cooktop
Frigidaire RB131CF0 Frg(v2) / Electric Cooktop
Frigidaire RB131CF1 Frg(v2) / Built - in Electric Cooktop
Frigidaire RB131CH0 Frg(v3) / Electric Cooktop
Frigidaire RB131CH1 Frg(v3) / Built - in Electric Cooktop
Frigidaire RB131CL0 Frg(v4) / Electric Cooktop
Frigidaire RB131CL1 Frg(v4) / Built - in Electric Cooktop
Frigidaire RB131CM0 Frg(v5) / Electric Cooktop
Frigidaire RB131CM1 Frg(v5) / Built - in Electric Cooktop
Frigidaire RB131CW0 Frg(v6) / Electric Cooktop
Frigidaire RB131CW1 Frg(v6) / Built - in Electric Cooktop
Frigidaire RB131NL1 Frg(v2) / Electric Range
Frigidaire RB131NL2 Frg(v3) / Electric Cooktop Range
  #2 (permalink)
Old 04-25-2013, 07:45 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Could be a faulty water level pressure switch. Switch is behind control panel. With washer full of water check continuity on pressure switch where violet and tan wires connect. Should read 0 ohms (short), if open, jump together violet and tan wires and see if it will agitate.
Eric
  #3 (permalink)
Old 04-26-2013, 09:19 AM
Junior Member
Default
Thank you. The water level pressure switch tested ok. What of this burned white wire from the motor wiinding to the motor starter? Could the forward (agitate) windings be bad?
  #4 (permalink)
Old 04-26-2013, 09:32 AM
Expert
APP Volunteer
Default
There are no "agitate" windings. The same windings are used for both agitate and drain/spin. The only difference is that the polarity to the start winding is reversed to get the motor going in the opposite direction of rotation. After the washer stops filling, does the motor hum or is it silent? If silent, does the timer advance on it's own? The white wire on the thermal overload switch is the neutral line feed. If it was faulty, the motor wouldn't work in drain/spin mode.
Eric
  #5 (permalink)
Old 04-26-2013, 12:03 PM
Junior Member
Default
I hear the timer buzzing, for a few seconds (maybe 10 sec). Then I hear click from the motor area and the buzzing stops. I then push in the timer and a few seconds later it clicks again, as if resetting an overload.
  #6 (permalink)
Old 04-26-2013, 01:27 PM
Expert
APP Volunteer
Default
Then I'd say you have a bad timer but I would first check continuity on the tan wire from the pressure switch to the timer connector. The motor is either not getting power to the start winding or the run winding in agitate mode. This means the motor won't start and therefore drawing excess current through the one winding that is getting power, causing the overload to trip and the neutral wire to the overload getting hot. When the overload trips you also lose neutral to the timer.
Eric
  #7 (permalink)
Old 04-26-2013, 04:49 PM
Junior Member
Default
Is there a way for me to test this timer with a digital VOM?
  #8 (permalink)
Old 04-26-2013, 07:20 PM
Expert
APP Volunteer
Default
For you, no. I say that because you don't know how to read/interpret the wiring diagram, timer chart and the timer terminal chart. If you did, you wouldn't be asking. If you purchase the timer from APP and it doesn't fix the problem, you can return it. We can rarely be 100% sure when trying to troubleshoot your washer over an Internet forum.
Eric
  #9 (permalink)
Old 04-27-2013, 02:41 PM
Junior Member
Default
I can read wiring diagrams and charts, I just do not have them and could not find them online. Maybe you could help me with this. Can you tell me where to find them?
  #10 (permalink)
Old 04-27-2013, 06:12 PM
Expert
APP Volunteer
Default
They should be somewhere in the washer, usually either behind the control panel or attached to the inside of the back panel at the top.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer does not agitate jvd819 Washer Repair 1 12-13-2011 06:48 PM
stackable washer dryer: washer will not agitate jennypatterson Dryer Repair 0 03-04-2009 11:08 AM
GE washer won't agitate cantseemtoplaceit Washer Repair 10 03-02-2009 02:17 AM
washer hum/will not agitate sv grant Washer Repair 2 10-27-2008 05:32 AM
GE washer won't agitate lisav31 Washer Repair 8 07-29-2008 01:40 PM
