Washer wont go past the rinse cycle it will fill but not agitate or spin.
The lid switch has already been replaced and other ideas?
Groups: Expert
Are you saying that it works in the wash cycle? Fills, agitates, drains, spins and then fills again for rinse cycle and stops?
Eric
Originally Posted by: fairbank56 Are you saying that it works in the wash cycle? Fills, agitates, drains, spins and then fills again for rinse cycle and stops?
Eric Yes Eric that is correct i was told it might be the timer
Groups: Expert
Yes, the timer is most likely the problem. Eric
Originally Posted by: Andrea0209 Yes Eric that is correct i was told it might be the timer Thanks eric
