Discuss
Noise at the Begining of the Spin Cycle
 in
Washer Repair
I was told that our washer was making a noise but I didn't get a chance to find out what
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Noise at the Begining of the Spin Cycle
  #1 (permalink)
Old 04-25-2013, 02:08 PM
Junior Member
kkaufman is on a distinguished road
Default Noise at the Begining of the Spin Cycle
Model Number: 100.26912691   Brand: Kenmore   Age: 1 - 5 years
I was told that our washer was making a noise but I didn't get a chance to find out what kind of noise and during what part of the wash cycle. (I had to dive in instead.)
I took the washer appart to see if the problem was obvious but all I found was a somewhat loose noise-dampening gasket (the thingy that goes over the brake housing and alot of dust and crud. So I cleaned out the dust and crud as best I could and generally inspected the unit. I wasn't able to loosen the spanner nut however, because I had no spanner but I managed to clean everything else and put the machine back together.
But... now the machine makes a noise at the begining of the spin cycle which goes away when the machine gets up to speed. Do you think it's worth getting a spanner to get at the inner and outer tubs of the machine? Perhaps some part(s) associated with this part of the washer have needed replacing all along.
Related Models
Frigidaire 1005 DISHWASHER
Frigidaire 1006 DISHWASHER
Amana 1008.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1009.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 100A-20 ROOM AIR CONDITIONER
Amana 100A-2M ROOM AIR CONDITIONER
Amana 100A-2N ROOM AIR CONDITIONER
Amana 100A-30 ROOM AIR CONDITIONER
Amana 100A-30H ROOM AIR CONDITIONER
Amana 100A-356 ROOM AIR CONDITIONER
Amana 100A-3A ROOM AIR CONDITIONER
Amana 100A-3HN ROOM AIR CONDITIONER
Amana 100A-3M ROOM AIR CONDITIONER
Amana 100A-3N ROOM AIR CONDITIONER
Amana 100A-3P ROOM AIR CONDITIONER
Amana 100A-3PH ROOM AIR CONDITIONER
Amana 100A-3R ROOM AIR CONDITIONER
Amana 100A-3RH ROOM AIR CONDITIONER
Amana 100A-556 ROOM AIR CONDITIONER
Amana 100A-8R ROOM AIR CONDITIONER
Amana 100B-3A ROOM AIR CONDITIONER
Amana 100C-2N ROOM AIR CONDITIONER
Amana 100C-2N1 ROOM AIR CONDITIONER
Amana 100C-2P ROOM AIR CONDITIONER
Amana 100C-2PH ROOM AIR CONDITIONER
Amana 100C-2R ROOM AIR CONDITIONER
Amana 100C-2RH ROOM AIR CONDITIONER
Amana 100C-2RHL ROOM AIR CONDITIONER
Amana 100C-2RL ROOM AIR CONDITIONER
Amana 100C-3N ROOM AIR CONDITIONER
Amana 100C-3N1 ROOM AIR CONDITIONER
Amana 100C-3P ROOM AIR CONDITIONER
Amana 100C-3PH ROOM AIR CONDITIONER
Amana 100C-3R ROOM AIR CONDITIONER
Amana 100C-3RH ROOM AIR CONDITIONER
Amana 100C-3RHL ROOM AIR CONDITIONER
Amana 100C-3RL ROOM AIR CONDITIONER
Amana 100C-8P ROOM AIR CONDITIONER
Amana 100C-8R ROOM AIR CONDITIONER
Amana 100C-8RH ROOM AIR CONDITIONER
Amana 100C-8RHL ROOM AIR CONDITIONER
Amana 100C-8RL ROOM AIR CONDITIONER
Amana 100D-356 ROOM AIR CONDITIONER
Amana 100D-556 ROOM AIR CONDITIONER
Amana 100LA-20 ROOM AIR CONDITIONER
Amana 100LA-2N ROOM AIR CONDITIONER
Amana 100LC-2N ROOM AIR CONDITIONER
Amana 100LC-2P ROOM AIR CONDITIONER
Amana 100LC-2R ROOM AIR CONDITIONER
Amana 100LC-2RH ROOM AIR CONDITIONER
Amana 100LCS-2N ROOM AIR CONDITIONER
Amana 100LCS-2P ROOM AIR CONDITIONER
Hoover 1010
Amana 1010.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1011.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1015.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1018.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 102.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 102.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 102.002 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1020
Amana 1020.0 MWAVE - FAMILY SIZE (60 HZ)
Amana 1020.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1021.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1022
Amana 1022.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 1026 DISHWASHER
Hoover 1030
Frigidaire 1031-005A DISHWASHER
Hoover 1032
Frigidaire 1032-005A DISHWASHER
Craftsman 10322161 TABLE MITRE SAW
Craftsman 10322180 CRAFTSMAN BENCH SAW
Craftsman 10322181 CRAFTSMAN BENCH SAW
Craftsman 10322420 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10322450 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10322451 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10323150 CRAFTSMAN JIG SAW
Craftsman 10323151 JIG SAW 18 INCH
Craftsman 10323390 CRAFTSMAN JIG SAW
Craftsman 10323420 BENCH SAW
Craftsman 10323440 JIG SAW
Craftsman 10323830 BENCH SAW (8 INCHES)
Craftsman 10323831 BENCH SAW 8 IN.
Craftsman 10323833 BENCH SAW (8 INCHES)
Craftsman 10324250 CRAFTSMAN 12 INCH BAND SAW
Craftsman 10324260 CRAFTSMAN 12 INCH BAND SAW
Craftsman 10324441 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10324680 FLOOR SAW 10 INCH
Craftsman 10324681 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10325400 BENCH SAW
Craftsman 10329301 CRAFTSMAN 9" RADIAL SAWS
Craftsman 10329310 CRAFTSMAN 9" RADIAL SAWS
Jenn-Air 1035 WALLOVEN- STD ELE
Amana 1035.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 1035B DISHWASHER
Frigidaire 1036 DISHWASHER
Jenn-Air 1037 WALLOVEN- STD ELE
Frigidaire 1037B DISHWASHER
Frigidaire 1041-002A DISHWASHER
Amana 1041.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 1046 DISHWASHER
Amana 1050.0 MWAVE - FAMILY SIZE (60 HZ)
Amana 1050.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1051.000 MWAVE - FAMILY SIZE (60 HZ)
Roper 1053B0A BUILT-IN GAS OVEN
Roper 1053B1A BUILT-IN GAS OVEN
Roper 1053B2A BUILT-IN GAS OVEN
Admiral 1058AF-CW RANGE- S/I STD ELE
Admiral 1058AF-CZ RANGE- S/I STD ELE
Admiral 1058AH-W RANGE- S/I STD ELE
Admiral 1058AH-Z RANGE- S/I STD ELE
Admiral 1058WF-CW RANGE- S/I STD ELE
Admiral 1058WF-CZ RANGE- S/I STD ELE
Admiral 1058WH-W RANGE- S/I STD ELE
Amana 106-2G ROOM AIR CONDITIONER
Amana 106-2GH ROOM AIR CONDITIONER
Amana 106-2GM ROOM AIR CONDITIONER
  #2 (permalink)
Old 04-27-2013, 05:05 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
I am thinking the problem is that the brakes are not releasing entirely at the begnning and that is the noise you hear. It could also be a problem in the transmission.
You may want to try replacing the clutch and brake cam, that may fix things.
__________________
  #3 (permalink)
Old 05-01-2013, 03:02 PM
Junior Member
Default
Okay, I'll try those suggestions but first I need to get a spanner nut wrench. Thanks!
  #4 (permalink)
Old 05-01-2013, 03:48 PM
Senior Expert
APP Volunteer
Default
Sounds good. You can replace the clutch and brake cam without the special wrench.
__________________
  #5 (permalink)
Old 05-01-2013, 04:20 PM
Junior Member
Default
Okay, thanks.
  #6 (permalink)
Old 05-06-2013, 09:26 AM
Junior Member
Default
I did actually wind up buying the wrench which turned out to be a good thing given the overall dirt and crud lodged in the machine in general. When I accessed the basket and out tub, they both had to be cleaned and there was corrosion at the base of the underside of the basket that had to be dealt with.
Along with all of that, the lock ring was corroded and tub washer wasn't looking so hot either. (I ordered replacements for those.)
Next, I accessed the Basket Drive and Brake Assembly and found that there was such a build up of crud on the shaft of the Basket Drive... that I had to use a rubber mallet just to get it out of the Tub Support tube. Once I did, I was able to really see the ring of hardened crud on the shaft. (I have ordered a new Basket Drive... unit because I could not remove the crud.)
So... basically the machine needed a good cleaning and replacement of some inexpensive parts with the exception of the Basket Drive. Once the part come in and I put every thing back together, I'll post an update as to whether all this solved the original problem.
  #7 (permalink)
Old 05-06-2013, 09:35 AM
Senior Expert
APP Volunteer
Default
Wow, thanks for the update. I have taken apart washers a lot older than this one and have not had this kind of problem with crud buildup
Hope the cleaning solves your problem. Good luck and let us know.
__________________
  #8 (permalink)
Old 05-06-2013, 09:40 AM
Junior Member
Default
Oops, I forgot to mention that the four lint catching thingys had been removed! And I'm guessing that that may have played a roll in the excessive build up of crud. I've only been at this residence for 1.5 years and do not know the history of the machine or why anyone would remove those four lint catchers. (Needless to say, I've ordered those as well.)
  #9 (permalink)
Old 05-06-2013, 10:51 AM
Senior Expert
APP Volunteer
Default
Okay, that explains a lot. Also this machine probably a lot older than you think, and being in the residence before you means it probably did get lots of crud.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
my kenmore washer makes a grinding noise during spin cycle and does not spin bronco48 Washer Repair 2 10-28-2012 02:42 AM
Agitator starts at very begining of each cycle deputydan Washer Repair 1 04-13-2011 07:56 AM
loud noise on spin cycle,the faster the spin gets the louder the winnig gets Edward Loeb Washer Repair 3 02-02-2011 07:30 AM
washer makes grinding noise and won't spin on spin cycle marine1969 Washer Repair 1 08-30-2010 07:19 PM
Quits at begining of spin, buzzes, and eventually starts again oFUNGUSo Washer Repair 3 06-06-2010 11:25 AM
