Joshua
#1 Posted : Wednesday, February 6, 2008 1:45:58 PM(UTC)
Joshua
Hello,
my Speed Queen is a Heavy duty model around 5-10 years. 2 days ago washer went through cycle but didn't drain, water was dark and alot of lint in it as if some piece of clothes had come apart. I tried running spin cycle several times. It spins and did drain alittle but not much. Is it something I can fix?:confused:
jc
#2 Posted : Wednesday, February 6, 2008 5:30:50 PM(UTC)
Most likely the drain pump and/or the drain hoses are clogged.
Remove the front panel, remove the hoses from the pump and check everything.
For more accurate advise I need the complete model number of the washer. The model number you posted is incorrect or incomplete.
