Discuss
Rinse cycle
 in
Washer Repair
I have a coin operated commercial washer. The wash cycle works fine (all water temperature operable), drains and spins, but
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Rinse cycle
  #1 (permalink)
Old 04-23-2013, 11:44 AM
Junior Member
hhtkong is on a distinguished road
Default Rinse cycle
Model Number: RAK2751KQO   Brand: Roper   Age: 5 - 10 years
I have a coin operated commercial washer. The wash cycle works fine (all water temperature operable), drains and spins, but when it comes to the rinse cycle the timer stops working and the tub wont fill with water. When manually moving timer rinse cycle will not fill with water but will spin and complete. Is this a timer problem or a motherboard (circuit board problem). Was told to check the water valve operation but if valve is bad would it also affect the wash cycle?
Related Models
Whirlpool RAL5144AG0
Whirlpool RAL5144AL0
Whirlpool RAL5144AW0
Whirlpool RAL5144BG0
Whirlpool RAL5144BG1
Whirlpool RAL5144BL0
Whirlpool RAL5144BL1
Whirlpool RAL5144BQ0
Whirlpool RAL5144BQ1
Whirlpool RAL5144BW0
Whirlpool RAL5144BW1
Whirlpool RAL6245AG0
Whirlpool RAL6245AL0
Whirlpool RAL6245AW0
Whirlpool RAL6245BL0
Whirlpool RAL6245BL1
Whirlpool RAL6245BW0
Whirlpool RAL6245BW1
Whirlpool RAM4131AL0
Whirlpool RAM4131AW0
Whirlpool RAM4132BW0
Whirlpool RAM4143AL0
Whirlpool RAM4143AL2
Whirlpool RAM4143AW0
Whirlpool RAM4143AW2
Whirlpool RAM5243AL0
Whirlpool RAM5243AL2
Whirlpool RAM5243AW0
Whirlpool RAM5243AW2
Whirlpool RAP5244AL0
Whirlpool RAP5244AW0
Whirlpool RAP7244DW0
Whirlpool RAR81K0 AIR CONDITIONER
Roper RAS1121EW0 AUTOMATIC WASHER DIRECT-DRIVE
Roper RAS5133EQ0 WASHER
Roper RAS6233JQ0 WASHER
Roper RAS6233KQ0 WASHER
Roper RAS6233KQ1 AUTOMATIC WASHER
Roper RAS6233KQ2 AUTOMATIC WASHER
Roper RAS6233PQ0 AUTOMATIC WASHER
Roper RAS6233PQ1 AUTOMATIC WASHER
Roper RAS6233PQ3 AUTOMATIC WASHER
Roper RAS6233RQ0 AUTOMATIC WASHER
Roper RAS7133KQ0 WASHER
Roper RAS7133KQ1 AUTOMATIC WASHER
Roper RAS7133PQ0 AUTOMATIC WASHER
Roper RAS7133PQ1 AUTOMATIC WASHER
Roper RAS7133RQ0 AUTOMATIC WASHER
Roper RAS7133RQ1 AUTOMATIC WASHER
Roper RAS7133RQ3 AUTOMATIC WASHER
Roper RAS7133RQ4 AUTOMATIC WASHER
Roper RAS7233JQ0 WASHER
Roper RAS7233KQ0 WASHER
Roper RAS8244KQ0 WASHER
Roper RAS8244KQ1 AUTOMATIC WASHER
Roper RAS8244KQ2 AUTOMATIC WASHER
Roper RAS8244LQ0 AUTOMATIC WASHER
Roper RAS8244LQ1 AUTOMATIC WASHER
Roper RAS8245EN0 DIRECT DRIVE WASHER
Roper RAS8245EN1 DIRECT-DRIVE WASHER
Roper RAS8245EQ0 DIRECT DRIVE WASHER
Roper RAS8245EQ1 DIRECT-DRIVE WASHER
Roper RAS8245EW0 DIRECT DRIVE WASHER
Roper RAS8245EW1 DIRECT-DRIVE WASHER
Roper RAS8333PQ0 AUTOMATIC WASHER
Roper RAS8333PQ1 AUTOMATIC WASHER
Roper RAS8333RQ0 AUTOMATIC WASHER
Roper RAS8333RQ1 AUTOMATIC WASHER
Roper RAS8333RQ3 AUTOMATIC WASHER
Roper RAS8333RQ4 AUTOMATIC WASHER
Roper RAS8445JQ0 WASHER
Roper RAS8445KQ0 WASHER
Maytag RAX1000AXW MISC / ACCESSORY
Maytag RAX1000CXB MISC / ACCESSORY
Maytag RAX2000AXW MISC / ACCESSORY
Maytag RAX2000CXB MISC / ACCESSORY
Maytag RAX3000DXX MISC / ACCESSORY
Maytag RAX33 MISC / ACCESSORY
Maytag RAX3300CXX MISC / ACCESSORY
Maytag RAX34 MISC / ACCESSORY
Maytag RAX36 MISC / ACCESSORY
Maytag RAX3600CXX MISC / ACCESSORY
Roper RAX4232JQ0 WASHER
Roper RAX4232KQ0 WASHER
Roper RAX4232KQ1 AUTOMATIC WASHER
Roper RAX4232PQ0 AUTOMATIC WASHER
Roper RAX4232PQ1 AUTOMATIC WASHER
Roper RAX4232RQ0 AUTOMATIC WASHER
Roper RAX4232RQ1 AUTOMATIC WASHER
Roper RAX4232RQ3 AUTOMATIC WASHER
Roper RAX4232RQ4 AUTOMATIC WASHER
Roper RAX4233PQ0 AUTOMATIC WASHER
Maytag RAX5000AXB MISC / ACCESSORY
Maytag RAX5000CXB MISC / ACCESSORY
Maytag RAX5100AXB MISC / ACCESSORY
Whirlpool RAX5133AG0
Whirlpool RAX5133AL0
Roper RAX5133AL1 AUTOMATIC WASHER
Roper RAX5133AW0 Washers*
Maytag RAX5200AXB MISC / ACCESSORY
Maytag RAX5200CXB MISC / ACCESSORY
Maytag RAX5300AXB MISC / ACCESSORY
Maytag RAX5400AXB MISC / ACCESSORY
Maytag RAX5500AXB MISC / ACCESSORY
Maytag RAX5500CXB MISC / ACCESSORY
Maytag RAX5600AXB MISC / ACCESSORY
Maytag RAX5700AXB MISC / ACCESSORY
Maytag RAX5700CXB MISC / ACCESSORY
Whirlpool RAX6144EN0
Whirlpool RAX6144EN1
Whirlpool RAX6144EQ0
Whirlpool RAX6144EQ1
Whirlpool RAX6144EW0
Whirlpool RAX6144EW1
Roper RAX7244EN0 WASHER
Roper RAX7244EN1 WASHER
Roper RAX7244EQ0 WASHER
Roper RAX7244EQ1 WASHER
Roper RAX7244EW0 WASHER
Roper RAX7244EW1 WASHER
  #2 (permalink)
Old 04-23-2013, 02:50 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Could be the timer or the water level pressure switch. When it gets to rinse cycle and won't fill, disconnect the hose on the pressure switch to see if it will then start filling. If not, check continuity on the pressure switch. If it checks out ok and won't fill with hose disconnected, I would suspect the timer. There is no motherboard on this model.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer won't automatically switch from wash cycle to rinse cycle WEED Washer Repair 2 07-21-2010 08:49 AM
dishwasher only hums on rinse cycle, does'nt rinse chris67 Dishwasher Repair 1 10-25-2009 05:01 AM
Washer humms at rinse cycle won't rinse xirwinite Washer Repair 2 10-13-2009 08:33 PM
Washer goes to rinse cycle then spin back to rinse, stuck in this mod Pat66 Washer Repair 1 05-08-2009 07:44 AM
Washer fills on wash cycle and rinse cycle and won't stop filling! riphinney Washer Repair 15 03-12-2008 05:30 PM
