Discuss
Wrong water temp.
 in
Washer Repair
My mother has this washer that has worked find for many years but just lately started to give her problems.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Wrong water temp.
  #1 (permalink)
Old 04-23-2013, 09:35 AM
Junior Member
jimbbski is on a distinguished road
Exclamation Wrong water temp.
Model Number: fwsb5700dso   Brand: Frigidaire   Age: More than 10 years
My mother has this washer that has worked find for many years but just lately started to give her problems. The water hoses are correct.
I tested the wash temp. and found that if you set the dial to "Hot Wash" you get cold water and if you set for "Cold" you get hot. The warm setting works OK.
For rinsing you get only hot water when set to cold and warm if you set to warm.
I think the temp. switch is OK as it is a simple switch, it either sends power through it to the water valve or it doesn't. The water valve also works if sent power to open. My feeling is that the timer/wash cycle switch is bad. There are cams inside per what I found and if may be that they are just not switching incorrectly and not sending power to the correct terminal on the temp. switch resulting in the water valve not opening correctly as well.
Any comments?
Related Models
Frigidaire FWSB6600ES0 Frigidaire/washer
Frigidaire FWSB6600ES1 Frigidaire/washer
Frigidaire FWSB6600FS0 Frigidaire/washer
Frigidaire FWSB6600FS1 WASHER
Frigidaire FWSB67RGS0 Washer - Frigidaire - Best Buy
Frigidaire FWSB67RGS2 Washer - Frig/best Buy
Frigidaire FWSB7800DS0 Frigidaire/washer
Frigidaire FWSC235RFS3 Washer - Fwsc235rfs3
Frigidaire FWSC34RGS1 Washer - Fwsc34rgs1
Frigidaire FWT425RHS0 Frg(v0) / Front Load Washer
Frigidaire FWT445GC WASHER
Frigidaire FWT445GCS0 Frg(v0) / Washer
Frigidaire FWT445GE WASHER
Frigidaire FWT445GES0 Frg(v0) / Washer
Frigidaire FWT445GES1 Frg(v0) / Washer
Frigidaire FWT445GES2 Frg(v0) / Washer
Frigidaire FWT449GFS0 Frg(v0) / Washer
Frigidaire FWT449GFS1 Frg(v0) / Front Load Washer
Frigidaire FWT449GFS2 Frg(v0) / Free Standing Washer
Frigidaire FWT645RHS0 Frtld Wshr - Frigidaire
Frigidaire FWT645RHS1 Frg(v0) / Front Load Washer
Frigidaire FWT647GHS0 Frg(v0) / Front Load Washer
Frigidaire FWT647GHS1 Frtld Wshr - Frigidaire
Frigidaire FWT648GHS0 Frg/washer
Frigidaire FWT867GHQ0 Frg/washer
Frigidaire FWT867GHS0 Frg/washer
Frigidaire FWTB59RGS0 Frg(v0) / Front Load Washer
Frigidaire FWTB69RGS0 Frg(v0) / Front Load Washer
Frigidaire FWTB8200DS0 Frigidaire/washer
Frigidaire FWTBB30DS0 Frigidaire/washer
Frigidaire FWTR425RHS0 Frg(v0) / Front Load Washer
Frigidaire FWTR445RFS0 Frg(v0) / Washer
Frigidaire FWTR445RFS1 Frg/washer
Frigidaire FWTR445RFS2 Frg(v0) / Front Load Washer
Frigidaire FWTR549GG Frg(v0) / Free Standing Washer
Frigidaire FWTR549GGS0 Frg/washer
Frigidaire FWTR549GS0
Frigidaire FWTR645RHS0 Frtld Wshr - Frigidaire
Frigidaire FWTR645RHS1 Frg(v0) / Front Load Washer
Frigidaire FWTR647GHS0 Frg(v0) / Washer
Frigidaire FWTR647GHS1 Frtld Wshr - Frigidaire
Frigidaire FWTR865RHQ0 Frg(v1) / Front Load Washer
Frigidaire FWTR865RHS0 Frg(v2) / Front Load Washer
Frigidaire FWTR867GHQ0 Frg(v1) / Front Load Washer
Frigidaire FWTR867GHS0 Frg(v2) / Front Load Washer
Frigidaire FWX133RBS0 Frg(v2) / 27 " Washer
Frigidaire FWX133RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX133RBS2 Frg(v1) / Washer
Frigidaire FWX133RBS3 Frg(v1) / Washer
Frigidaire FWX221AS0 Washer - Frigidaire
Frigidaire FWX221AS1 Washer - Frigidaire
Frigidaire FWX221AS2 Frigidaire/washer
Frigidaire FWX223LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX223LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX223LBS2 Frg(v2) / Washer
Frigidaire FWX223LBS3 Frg(v2) / Washer
Frigidaire FWX223LBS4 Frg(v0) / Washer
Frigidaire FWX223LBS5 Frg(v0) / Washer
Frigidaire FWX223LBS6 Frg/washer
Frigidaire FWX223LBS7 Frg(v0) / Free Standing Washer
Frigidaire FWX223LBS8 Frg/washer
Frigidaire FWX225RHS0 Frg(v0) / Washer
Frigidaire FWX225RHS1 Frg/washer
Frigidaire FWX233MRES0 Frg(v0) / Refrigerator
Frigidaire FWX233NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX233NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX233NBS2 Frg(v1) / Washer
Frigidaire FWX233NBS3 Frg(v0) / Washer
Frigidaire FWX233RES0 Frg(v0) / Washer
Frigidaire FWX233RES1 Frg(v0) / Washer
Frigidaire FWX233RES2 Frg(v0) / Washer
Frigidaire FWX233RES3 Frg(v0) / Washer
Frigidaire FWX233RES4 Frg(v0) / Washer
Frigidaire FWX233RES5 Frg(v0) / Washer
Frigidaire FWX233RES6 Frg/washer
Frigidaire FWX233RES7 Washer - Frigidaire
Frigidaire FWX233RET0 Frg(v0) / Free Standing Washer
Frigidaire FWX233RET1 Frg/washer
Frigidaire FWX414RGS0 Frg(v0) / Free Standing Washer
Frigidaire FWX414RGS1 Washer - Frigidaire
Frigidaire FWX433RBS0 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS2 Frg(v3) / Washer
Frigidaire FWX433RBS3 Frg(v1) / Washer
Frigidaire FWX433RBS4 Frg(v1) / Washer
Frigidaire FWX433RBS5 Frg(v1) / Washer
Frigidaire FWX433RBT0 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT1 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT2 Frg(v4) / Washer
Frigidaire FWX433RBT4 Frg(v2) / Washer
Frigidaire FWX433RBT5 Frg(v2) / Washer
Frigidaire FWX435RHS0 Frg(v0) / Washer
Frigidaire FWX435RHS1 Washer - Frigidaire
Frigidaire FWX435RHT0 Frg(v0) / Washer
Frigidaire FWX435RHT1 Washer - Frigidaire
Frigidaire FWX445LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS1 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS2 Frg(v1) / Washer
Frigidaire FWX445LBS3 Frg(v2) / Washer
Frigidaire FWX445LBS4 Frg(v0) / Washer
Frigidaire FWX445NBS0 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS2 Frg(v3) / Washer
Frigidaire FWX445NBS3 Frg(v2) / Washer
Frigidaire FWX445NBS4 Frg(v0) / Washer
Frigidaire FWX445RFS0 Frg(v1) / Washer
Frigidaire FWX445RFS1 Frg(v1) / Washer
Frigidaire FWX445RFS2 Frg(v1) / Washer
Frigidaire FWX445RFS3 Frg(v1) / Washer
Frigidaire FWX445RFS4 Frg(v1) / Free Standing Washer
Frigidaire FWX445RFS5 Washer - Frigidaire
Frigidaire FWX445RFT0 Frg(v2) / Washer
Frigidaire FWX445RFT1 Frg(v2) / Washer
Frigidaire FWX445RFT2 Frg(v2) / Washer
Frigidaire FWX445RFT3 Frg(v2) / Washer
Frigidaire FWX445RFT4 Frg(v2) / Free Standing Washer
Frigidaire FWX645DBD0 Frg(v2) / 27 " Washer
Frigidaire FWX645DBD1 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW0 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW1 Frg(v2) / 27 " Washer
  #2 (permalink)
Old 04-23-2013, 10:30 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
I first suspect the part about the washer working fine for many years. I don't see how the timer could cause this problem but a really screwed up temp switch could. Pretty easy to troubleshoot though with meter and wiring diagram in hand.
Eric
  #3 (permalink)
Old 04-23-2013, 01:24 PM
Junior Member
Default
Well I did some further checking and I found that the water feed hoses were switched. Duh! I have removed them some time back and I know that I installed them correctly back then but forgot about the time after that that I have to remove them to drain the water out of the feed pipes. I had to sweat some connections (Copper pipe) and then must have installed then wrong.
All fixed!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
reading wrong temp crosspatch Refrigerator & Freezer Repair 1 04-16-2013 03:09 PM
temp on electric ceramic stovetop all wrong loubrooks Oven Repair (including Ranges and Cooktops) 1 01-03-2013 02:49 AM
Ge electric oven wrong temp mmzullo Oven Repair (including Ranges and Cooktops) 4 12-22-2012 08:13 PM
A/c Window Unit Temp Reading Wrong Chris311L Heating, Ventilation, and Air Conditioning (HVAC) 1 04-29-2011 06:48 PM
temp in oven is wrong smpmagic Oven Repair (including Ranges and Cooktops) 5 12-02-2007 03:21 PM
