jlz77
#1 Posted : Sunday, April 21, 2013 7:17:08 PM(UTC)
jlz77
Question... My GE washer WASE4220A0WW will not spin, the water pumps out and it "sounds" like it's spinning, but the clothes are there still wringing wet. Since it's older my first thought was the belt, but after looking at other brands with similar issues, it seems like there are a number of things it could be... any information and/or experience would be greatly appreciated prior to purchasing my parts.
fairbank56
#2 Posted : Monday, April 22, 2013 6:06:08 AM(UTC)
fairbank56
Groups: Expert
Open the front panel so you can observe things while its running. While in spin mode check the motor shaft and pulley. There is a clip on the bottom of the motor shaft. If the clip is spinning but the pulley is not, then the clutch is slipping. With washer off, rotate motor pulley CW (viewed from below) by hand. This should rotate the belt, main drive pulley, transmission and basket. It should rotate relatively easy but will stop quickly due to the brake. If it is very difficult to rotate, there may be clothing stuck between the tubs.
Eric
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 2/21/2019 4:21:02 AM(UTC)
Washer won't spin out. (Washer Repair)
by DJChad818 10/26/2017 9:47:20 AM(UTC)
Washer won't spin (Washer Repair)
by Fingers123 10/22/2017 1:43:41 PM(UTC)
Washer Won't Spin (Washer Repair)
by je00409 9/5/2017 11:00:04 AM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 3/21/2017 7:08:08 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
by lmhansgen 8/31/2016 10:19:23 AM(UTC)
