Discuss
Kenmore electrical issue
 in
Washer Repair
After replacing a clutch, because I was told that spin was very slow (and determined the clutch slipped), I put
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore electrical issue
  #1 (permalink)
Old 04-20-2013, 06:22 PM
Junior Member
spaldini101 is on a distinguished road
Default Kenmore electrical issue
Model Number: 110.82781800   Brand: Kenmore   Age: More than 10 years
After replacing a clutch, because I was told that spin was very slow (and determined the clutch slipped), I put the whole thing back together and got total silence when I went to test it. No noise, no hum... nada. Immediately suspecting I forgot to make an electrical connection, I checked the wiring harness connection, it looked good. I tested the control by seeing if it created a hot wire at the motor when I turned it to start... a wire did get hot... so I figured the control was working.
I never personally tested the machine prior to the clutch replacement to see if everything else was normal, I just assumed the slow spin was the only issue. Any ideas what I might have done... if anything? Like a fuse?
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 04-24-2013, 01:24 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
You need to determine if the machine will spin by moving the timer to the spin secton and (after making sure the lid switch works) engaging the machine.
If it does not spin it would likely mean the timer has a problem. If it does spin it may mean the water level switch is the issue, or that possibly the connections to the water valve assembly came off while you were working on it.
__________________
  #3 (permalink)
Old 05-28-2013, 12:41 PM
Junior Member
Default
I will check that out, I don't think I advanced the timer. Thank you
  #4 (permalink)
Old 05-31-2013, 08:07 AM
Junior Member
Default
The machine does not spin. It does nothing, total silence, no hum, no buzz. The timer is getting power... and as far as I know the timer worked perfectly prior to the clutch replacement
  #5 (permalink)
Old 05-31-2013, 08:08 AM
Junior Member
Default
The water valve connections are good.
  #6 (permalink)
Old 05-31-2013, 03:33 PM
Senior Expert
APP Volunteer
Default
Check the lid switch, it may have been damaged during the repair.
__________________
  #7 (permalink)
Old 06-01-2013, 07:54 AM
Junior Member
Default
I thought the lid switch only prevented the spin cycle. You can always fill the machine with the lid open, right?
  #8 (permalink)
Old 06-02-2013, 04:14 PM
Senior Expert
APP Volunteer
Default
A bad lid switch will stop it from draining after the wash cycle, but if you move the timer to the rinse cycle it will fill and agitate, then stop again.
I am not sure exactly what is happening with your machine, but a simple test with a meter for continuity will tell you if the lid switch is ok.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electrical issue tektamk Oven Repair (including Ranges and Cooktops) 0 03-18-2011 09:32 AM
Kenmore Dryer Electrical Issue rhemshot Dryer Repair 1 01-05-2011 06:27 PM
Kenmore Dryer Electrical Issue rhemshot Refrigerator & Freezer Repair 0 01-03-2011 10:34 AM
Electrical Issue? byoungmadison Refrigerator & Freezer Repair 3 05-13-2010 03:23 PM
electrical issue? jillserdo Oven Repair (including Ranges and Cooktops) 0 10-03-2009 07:32 AM
