Discuss
Washer
 in
Washer Repair
My washer will fill but won't agitate, or spin. The timer functions, and the pump drains, ... lid switch functions
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer
  #1 (permalink)
Old 04-20-2013, 11:29 AM
Junior Member
Polly147 is on a distinguished road
Default Washer
Brand: Whirlpool   Age: 5 - 10 years
My washer will fill but won't agitate, or spin. The timer functions, and the pump drains, ... lid switch functions fine. The agitator is firm, won't move by hand. I replaced the 'drive coupler' two years ago, along with the 'dogs'. I'm suspecting the 'drive-coupler' is shot as this washer is run every day. Anything I should consider before I pull it all apart?
Thanks for all you do
  #2 (permalink)
Old 04-20-2013, 12:39 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Assuming the motor is running when it should be agitating and spinning, then yes, I'd say the coupler is shot.
Eric
  #3 (permalink)
Old 04-20-2013, 12:47 PM
Junior Member
Default
Thanks Eric, ...I did pull the motor and coupler, ... the prongs are in ok shape but the center fitting (which fits the shaft) is striped, resulting in the flats being worn round. It's also cracked which I suppose enabled the coupler to begin slipping on the shaft. Trying to find a 'shim' solution until I get a new one. I guess the new ones are reinforced with steel. Thanks very much for the quick reply.
Best, ...Polly147
  #4 (permalink)
Old 04-25-2013, 04:30 PM
Junior Member
Default Coupler
Got the motor drive coupler, (needless to say any repair of the bad part failed) ... flipped the washer, dropped the pump and motor, ... replaced the coupler and re-assembled. Took about 15 minutes and we're back in business. Thanks for your help and all you do on a volunteer basis. You guys are the best.
Polly147
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
