i have a kenmore series 80 washer that from day one has a loud banging noise when the spin cycle stops and the machine is in the brake slow down stop mode runs great in all other cycles just maks alot off jumping around and like off balance in the slow down stop of spin does this mean the cluch is bad or is there an ajustment and if so how thanks for any help
The machine has brakes which engage when the motor stops the spin cycle. I suspect the problem is there. Take a look at the Sticky on direct drive brakes at the top of the main washer page, and you can get a video on how to take the machine apart to see them if you go to the video library.
