Discuss
kenmore 80 series: COUPLER WON'T SPIN AFTER I PUT THE MOTOR BACK ON
 in
Washer Repair
I have purchased a new coupler, replaced the old one that fell apart, now I am mounting the motor again,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore 80 series: COUPLER WON'T SPIN AFTER I PUT THE MOTOR BACK ON
  #1 (permalink)
Old 04-19-2013, 08:06 AM
Junior Member
anthonybbrown is on a distinguished road
Default kenmore 80 series: COUPLER WON'T SPIN AFTER I PUT THE MOTOR BACK ON
Model Number: 11023832100   Brand: Kenmore   Age: 5 - 10 years
I have purchased a new coupler, replaced the old one that fell apart, now I am mounting the motor again, putting the two pieces of the coupler together. I get one strap on, and the coupler is still free to spin, I go and try to put the other strap on, and the coupler and gears stop spinning. I don't want to risk putting it back together and the motor going bad because its not free to spin. I have already taken out the coupler to see if it was in too tight, but that wasn't the case. It is a bit challenging putting the second strap back on to the motor. And when I go to put the 2nd one on, it freezes up even before its on due to the pressure. Any suggestions?
Related Models
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
Kenmore 11023904201 AUTOMATIC WASHER
Kenmore 11023912100 AUTOMATIC WASHER
Kenmore 11023912101 AUTOMATIC WASHER
Kenmore 11023912102 AUTOMATIC WASHER
Kenmore 11023922200 AUTOMATIC WASHER
Kenmore 11023922201 AUTOMATIC WASHER
Kenmore 11023924200 AUTOMATIC WASHER
Kenmore 11023924201 AUTOMATIC WASHER
Kenmore 11023932200 WASHER
Kenmore 11023934200 WASHER
Kenmore 11024032301 AUTOMATIC WASHER
Kenmore 11024036301 AUTOMATIC WASHER
Kenmore 11024042301 AUTOMATIC WASHER
Kenmore 11024052300 AUTOMATIC WASHER
Kenmore 11024054300 AUTOMATIC WASHER
Kenmore 11024056300 AUTOMATIC WASHER
Kenmore 11024082200 AUTOMATIC WASHER
Kenmore 11024084200 AUTOMATIC WASHER
Kenmore 11024086200 AUTOMATIC WASHER
Kenmore 11024292300 AUTOMATIC WASHER
Kenmore 11024294300 AUTOMATIC WASHER
Kenmore 11024422300 AUTOMATIC WASHER
Kenmore 11024432300 AUTOMATIC WASHER
Kenmore 11024442300 AUTOMATIC WASHER
Kenmore 11024622300 AUTOMATIC WASHER
Kenmore 11024632300 AUTOMATIC WASHER
Kenmore 11024642300 AUTOMATIC WASHER
Kenmore 11024652300 AUTOMATIC WASHER
Kenmore 11024662300 AUTOMATIC WASHER
Kenmore 11024692300 AUTOMATIC WASHER
Kenmore 11024712300 AUTOMATIC WASHER
Kenmore 11024722300 AUTOMATIC WASHER
Kenmore 11024732300 AUTOMATIC WASHER
Kenmore 11024812200 AUTOMATIC WASHER
Kenmore 11024812201 AUTOMATIC WASHER
Kenmore 11024822200 AUTOMATIC WASHER
Kenmore 11024822201 AUTOMATIC WASHER
Kenmore 11024832200 AUTOMATIC WASHER
Kenmore 11024832201 AUTOMATIC WASHER
Kenmore 11024852300 AUTOMATIC WASHER
Kenmore 11024862300 AUTOMATIC WASHER
Kenmore 11024872300 AUTOMATIC WASHER
Kenmore 11024892300 AUTOMATIC
Kenmore 11024894300 AUTOMATIC
Kenmore 11024902200 AUTOMATIC WASHER
Kenmore 11024902201 AUTOMATIC WASHER
Kenmore 11024902202 AUTOMATIC WASHER
Kenmore 11024904200 AUTOMATIC WASHER
Kenmore 11024904201 AUTOMATIC WASHER
Kenmore 11024904202 AUTOMATIC WASHER
Kenmore 11024922200 AUTOMATIC WASHER
Kenmore 11024922201 AUTOMATIC WASHER
Kenmore 11024922202 AUTOMATIC WASHER
Kenmore 11024924200 AUTOMATIC WASHER
Kenmore 11024924201 AUTOMATIC WASHER
Kenmore 11024924202 AUTOMATIC WASHER
Kenmore 11024932200 AUTOMATIC WASHER
Kenmore 11024932201 AUTOMATIC WASHER
Kenmore 11024932202 AUTOMATIC WASHER
Kenmore 11024934200 AUTOMATIC WASHER
Kenmore 11024934201 AUTOMATIC WASHER
Kenmore 11024934202 AUTOMATIC WASHER
Kenmore 11024942300 AUTOMATIC WASHER
Kenmore 11024942301 RESIDENTIAL WASHER
Kenmore 11024944300 AUTOMATIC WASHER
Kenmore 11024944301 RESIDENTIAL WASHER
Kenmore 11024946300 AUTOMATIC WASHER
Kenmore 11024946301 RESIDENTIAL WASHER
Kenmore 11024952300 AUTOMATIC WASHER
Kenmore 11024952301 RESIDENTIAL WASHER
Kenmore 11024954300 AUTOMATIC WASHER
Kenmore 11024954301 RESIDENTIAL WASHER
Kenmore 11024956300 AUTOMATIC WASHER
Kenmore 11024956301 RESIDENTIAL WASHER
Kenmore 11024962300 AUTOMATIC WASHER
Kenmore 11024962301 RESIDENTIAL WASHER
Kenmore 11024964300 AUTOMATIC WASHER
Kenmore 11024964301 RESIDENTIAL WASHER
Kenmore 11024966300 AUTOMATIC WASHER
Kenmore 11024966301 RESIDENTIAL WASHER
Kenmore 11024972300 AUTOMATIC WASHER
Kenmore 11024974300 AUTOMATIC WASHER
Kenmore 11024982300 AUTOMATIC WASHER
Kenmore 11024992300 AUTOMATIC WASHER
Kenmore 11024994300 AUTOMATIC WASHER
Kenmore 11024996300 AUTOMATIC WASHER
Kenmore 11025062500 WASHER
Kenmore 11025064500 WASHER
Kenmore 11025066500 WASHER
Kenmore 11025292500 WASHER
Kenmore 11025292501 WASHER
Kenmore 11025292502 RESIDENTIAL WASHER
Kenmore 11025292503 RESIDENTIAL WASHER
Kenmore 11025294500 WASHER
Kenmore 11025294501 WASHER
Kenmore 11025294502 RESIDENTIAL WASHER
Kenmore 11025294503 RESIDENTIAL WASHER
Kenmore 11025832400 RESIDENTIAL WASHER
Kenmore 11025842400 AUTOMATIC WASHER
Kenmore 11025844400 AUTOMATIC WASHER
Kenmore 11025852400 AUTOMATIC WASHER
Kenmore 11025854400 AUTOMATIC WASHER
Kenmore 11025862400 AUTOMATIC WASHER
Kenmore 11025864400 AUTOMATIC WASHER
Kenmore 11026002010 AUTOMATIC WASHER
Kenmore 11026002011 AUTOMATIC WASHER
Kenmore 11026012010 AUTOMATIC WASHER
Kenmore 11026012011 AUTOMATIC WASHER
Kenmore 11026051690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026058690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026071690 COMMERCIAL WASHER
Kenmore 11026071691 COMMERCIAL WASHER
Kenmore 11026152500 WASHER COMMERCIAL
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
  #2 (permalink)
Old 04-19-2013, 09:53 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
When you put the coupler piece on the gearcase input shaft, are you able to freely rotate it in each direction by hand? If the input shaft rotates ok, you may have not pushed the coupler pieces far enough onto the motor and gearcase shafts causing excessive force on the motor when you try to install it. Make sure you did not lose any of the four rubber isolators from the motor/mount.
Eric
  #3 (permalink)
Old 04-19-2013, 10:00 AM
Junior Member
Default
When I put the hook the motor on and combine the two coupler pieces, is does rotate freely by hand. Its when I put the straps on the 2nd side is when it locks up...Should it be tough to put the couplers all the way down the shafts before putting the motor back on?
  #4 (permalink)
Old 04-19-2013, 10:16 AM
Expert
APP Volunteer
Default
The plastic coupler pieces should be pressed on until the center part of it is flush with the end of the shaft. Sometimes you need to use a socket and hammer to tap it to this position. Make sure you line up the holes in the rubber piece so that the fingers of the plastic pieces go into the holes of the rubber piece.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 70 series won't agitate/spin but its not the motor coupling Min Washer Repair 0 05-08-2012 10:15 PM
fills, won't agitate or spin, motor runs, coupler ok Lee H Washer Repair 1 11-09-2011 06:37 PM
Kenmore 80 Series - Won't Spin - not coupler angelaperk Washer Repair 1 09-21-2011 05:10 PM
Washer, Kenmore 90Series Replaced motor coupler, now makes very loud noise/whistle Allen74 Washer Repair 1 10-23-2010 05:32 PM
kenmore wont spin after new coupler skypilots Washer Repair 14 06-21-2010 08:26 AM
