Discuss
Is this a washer timer problem?
 in
Washer Repair
The washer will run up to the end of the wash cycle and then pump the water out but never
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Is this a washer timer problem?
  #1 (permalink)
Old 04-18-2013, 02:00 PM
Junior Member
hanketron is on a distinguished road
Default Is this a washer timer problem?
Model Number: 131436700 washer timer   Brand: Frigidaire   Age: 5 - 10 years
The washer will run up to the end of the wash cycle and then pump the water out but never stops pumping the water out. It will start, after a while, to fill the tub but can't because it is still pumping the water out. It stays in this position until someone notices and turns it off. It has cost us much on the water bill.
I thought it was the timer (131436700 washer timer) contact points fused together so I cleaned them(quite a job). But then today it did it again.
I need to know if this is definatly the timer or are there other reasons the machine might act this way. It is a very simple older washer without any of the bells and whistles. I am sorry I don't have the model number with me. I thought though this could be answered without it. I thank you for your time and any help offered.
Related Models
Roper 1315*0A Range (gas)*
Roper 1315*1A Range (gas)*
Roper 1315*2A Range (gas)*
Amana 1315.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1315.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1315.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 1315.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 1315W0A Range (gas)*
Roper 1315W1A Range (gas)*
Roper 1315W2A Range (gas)*
Amana 1325.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1325.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1325.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 1325.004 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1330
Amana 1330.001 MWAVE - FAMILY SIZE (60 HZ)
Roper 1333*0A GAS RANGE
Roper 1333*1A GAS RANGE
Roper 1333W0A GAS RANGE
Roper 1335*0A GAS RANGE
Roper 1335*1A GAS RANGE
Roper 1335*3A GAS RANGE
Amana 1335.000 MWAVE - FAMILY SIZE (60 HZ)
Roper 1335W3A GAS RANGE
Hoover 1340
Amana 1340.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1341.002 MWAVE - FAMILY SIZE (60 HZ)
Roper 1346*0A GAS RANGE
Roper 1346W0A GAS RANGE
Roper 1347*0A GAS RANGE
Roper 1347W0A GAS RANGE
Hoover 1348
Hoover 1348-002
Roper 1352W06 Range (gas)*
Roper 1353*0A GAS RANGE
Roper 1353*1A GAS RANGE
Roper 1353*2A GAS RANGE
Roper 1353*3A Range (gas)*
Roper 1353*4A Range (gas)*
Roper 1353W0A GAS RANGE
Roper 1353W1A GAS RANGE
Roper 1353W2A GAS RANGE
Roper 1353W4A Range (gas)*
Roper 1355*0A GAS RANGE
Roper 1355*1A GAS RANGE
Roper 1355*2A GAS RANGE
Roper 1355*3A Range (gas)*
Roper 1355W0A GAS RANGE
Roper 1355W1A GAS RANGE
Roper 1355W2A GAS RANGE
Roper 1355W3A Range (gas)*
Admiral 1365H-EZW WALLOVEN- S/C ELE
Admiral 1365HW-EZW WALLOVEN- S/C ELE
Admiral 1370H-KLZW WALLOVEN- CONT CLEAN GAS
Admiral 1375H-KLZW WALLOVEN- CONT CLEAN GAS
Admiral 1375HW-KLZW WALLOVEN- CONT CLEAN GAS
Admiral 1375HW-KZW WALLOVEN- STD GAS
Roper 1393*0A GAS RANGE
Roper 1393*1A GAS RANGE
Roper 1393*2A GAS RANGE
Roper 1393*3A GAS RANGE
Roper 1393*4A GAS RANGE
Roper 1393W0A GAS RANGE
Roper 1393W1A GAS RANGE
Roper 1393W2A GAS RANGE
Whirlpool 1393W3A
Whirlpool 1393W4A
Whirlpool 1393^3A
Whirlpool 1393^4A
Roper 1395*0A GAS RANGE
Roper 1395*1A GAS RANGE
Roper 1395*2A GAS RANGE
Roper 1395*3A GAS RANGE
Roper 1395W0A GAS RANGE
Roper 1395W1A GAS RANGE
Roper 1395W2A GAS RANGE
Roper 1395W3A GAS RANGE
Frigidaire 14-025A1
Frigidaire 14-025A2
Frigidaire 14-030A1
Frigidaire 14-030A2
Frigidaire 14-040A1
Frigidaire 14-040A2
Frigidaire 14-040A4
Frigidaire 14-050A1
Frigidaire 14-2589-00-01 Tap(v1) / Gas Modular Cooktop
Frigidaire 14-2589-32-01 Tap(v2) / Gas Modular Cooktop
Frigidaire 14-2629-00-0A Tap(v2) / Gas Cooktop
Frigidaire 14-2629-00-17 Tap(v2) / Cooktop
Frigidaire 14-2629-00-19 Tap(v1) / Cooktop
Frigidaire 14-2629-08-17 Tap(v1) / Cooktop
Frigidaire 14-2629-08-19 Tap(v3) / Cooktop
Frigidaire 14-2629-23-0A Tap(v3) / Gas Cooktop
Frigidaire 14-2629-23-17 Tap(v3) / Cooktop
Frigidaire 14-2629-23-19 Tap(v2) / Cooktop
Frigidaire 14-2629-32-0A Tap(v1) / Gas Cooktop
Frigidaire 14-2639-00-0A Tap(v2) / Gas Cooktop
Frigidaire 14-2639-00-10 Tap(v2) / Gas Cooktop
Frigidaire 14-2639-08-0A Tap(v1) / Gas Cooktop
Frigidaire 14-2639-08-10 Tap(v1) / Gas Cooktop
Frigidaire 14-2639-23-0A Tap(v3) / Gas Cooktop
Frigidaire 14-2639-23-10 Tap(v3) / Gas Cooktop
Frigidaire 14-3028-00-01 Tap(v1) / Gas Range
Frigidaire 14-3028-00-02 Tap(v1) / Cooktop
Frigidaire 14-3028-00-03 Tap(v1) / Cooktop
Frigidaire 14-3028-08-01 Tap(v6) / Gas Range
Frigidaire 14-3028-08-02 Tap(v4) / Cooktop
Frigidaire 14-3028-08-03 Tap(v3) / Cooktop
Frigidaire 14-3028-23-01 Tap(v2) / Gas Range
Frigidaire 14-3028-23-02 Tap(v2) / Cooktop
Frigidaire 14-3028-23-03 Tap(v2) / Cooktop
Frigidaire 14-3028-45-01 Tap(v4) / Gas Range
Frigidaire 14-3028-57-01 Tap(v5) / Gas Range
Frigidaire 14-3028-66-01 Tap(v3) / Gas Range
Frigidaire 14-3028-66-02 Tap(v3) / Cooktop
Frigidaire 14-3038-00-01 Tap(v1) / Cooktop
Frigidaire 14-3038-00-02 Tap(v1) / Cooktop
Frigidaire 14-3038-00-03 Tap(v2) / Cooktop
Frigidaire 14-3038-08-01 Tap(v6) / Cooktop
Frigidaire 14-3038-08-02 Tap(v4) / Cooktop
  #2 (permalink)
Old 04-18-2013, 03:46 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Hanketron, A couple of other things to check. Make sure the drain hose is at the proper height and the drain hose is not sealed or taped shut to the stand pipe. This could cause a syphon effect, and "suck the water out the tub. Also check the water level switch and air tube. If the switch does not reset to the empty level after the drain cycle, the timer will stall in that position. If all's OK, then replace the timer.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 04-19-2013, 07:33 AM
Junior Member
Default
I thank you so very much for the quick answer, I am heading over to check what that it is not siphoning. I think I did change the drain before the problem started. It will be great if that is all that is wrong, I will return and let you all know how it went. Again I thank you and I will share this forum and your website with all I can.
  #4 (permalink)
Old 04-19-2013, 08:04 AM
Senior Expert
Default
Thanks, Please remember to let us know what you found, and the remedy.
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 05-14-2013, 12:02 PM
Junior Member
Default
I am sorry I did not get back sooner but I wanted to make sure i was right and it took this long to confirm. Your advice on siphoning was correct, I added air intake at fall of the discarded water and it stopped siphoning and works great. Just for others refrence, I never changed the dicharge hose from the washer, I changed how the water moved after the discharge and that caused the siphon effect. The old route for discharge from the washer was long and awkward with many ups and downs, I changed it so it dumped easily into a close drain, this caused my problem. I simple added a 1/4" pipe to the discharge at the highest point and that stopped all siphoning. Thanks again you guys at AppliancePartsPro. You saved me money and time. May God Bless You : )
  #6 (permalink)
Old 05-14-2013, 12:38 PM
Senior Expert
Default
Hanketron,
You're Very Welcome !!
We're glad it was that simple and easy a repair for you.
God Bless,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer timer problem cgaump Washer Repair 3 02-10-2012 03:05 AM
washer timer or sequencer problem stina88 Washer Repair 1 05-17-2011 08:40 PM
Washer timer moyor problem Gene Ziobro Washer Repair 1 04-07-2011 10:10 AM
Kenmore washer problem. Timer? PC Gator Washer Repair 7 07-16-2009 09:05 AM
Washer problem in LARGE load setting- timer problem? jagtianis Washer Repair 9 08-04-2008 03:49 AM
