Register | FAQ's | New Posts | Today's Posts | Extras |
» Won't spin |
![]() Model Number: wbse3120b1ww Brand: GE Age: 1 - 5 years
![]() The washer will fill with water, agitate the clothes, drain, but will not spin. I can spin the tub by hand but it won't spin on its own. I removed the front of the washer and started the process over. The clutch spins clockwise while the clothes are agitating but barely moves and seems to catch when it tries to spin counterclockwise. I was able to get it to spin a little bit and it shook BAD and made a loud whirling noise. The clip under the clutch is spinning so that tells me that the motor is turning. I think the clutch may be bad, but I don't want to start randomly buying parts. Since then.... I removed the agitator and found that the hub (inner tub base) underneath is breaking apart. So I may just need to replace the hub "Part Number AP2047612 MFG Part Number WH45X10027". What else besides the hub should I order? Related Models Last edited by Nate_T : 04-18-2013 at 06:34 AM. Reason: Additional info |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Hi.
Most likely you have more then one broken parts there. Because of our unique return policy I recommend you to get all the parts and replace the hub first. You also may need tub bearing WH2x1197, and some other parts: WH02X10032, WH2X1199, WH02X1065, WH345X10027. If you wouldn't need the clutch - just return it. Here are the breakdown diagrams and Tub, Basket & Agitator parts for GE WBSE3120B1WW - AppliancePartsPros.com Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
my kenmore washer makes a grinding noise during spin cycle and does not spin | bronco48 | Washer Repair | 2 | 10-28-2012 02:42 AM |
Front load washer won't spin water out of clothes on last spin cycle | Tracey Finley | Washer Repair | 1 | 06-28-2011 05:10 PM |
loud noise on spin cycle,the faster the spin gets the louder the winnig gets | Edward Loeb | Washer Repair | 3 | 02-02-2011 07:30 AM |
Replaced clutch (fixed wet clothes after spin) makes a noise when it starts spin??? | mikeal21 | Washer Repair | 1 | 03-01-2010 06:21 PM |
Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
