Register | FAQ's | New Posts | Today's Posts | Extras |
» low voltage to water fill valve |
![]() Model Number: 11027222600 Brand: Kenmore Age: 1 - 5 years
![]() Washer won't fill installed new fill valve without succes checked voltage to fill valve only have 82 volts 120 volts to washer Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() While in fill mode, place one lead of meter in wall socket neutral (wide blade) and check voltage at pink wire of water level pressure switch behind control panel, left side. If low, check at violet wire. If voltage at pink wire is ok, check at yel/red wire on cold water solenoid. If good, you have fault in neutral feed to solenoid valves. If low, could be ATC (temp) switch or timer, would need to see photo of your wiring diagram for further help.
Eric |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
No Water Fill - Voltage & Ohm Readings. ??? | ForgivenAll | Dishwasher Repair | 1 | 08-06-2011 12:58 PM |
Voltage at water inlet valve solenoid | kenewto | Dishwasher Repair | 1 | 09-20-2010 01:01 PM |
ac voltage at water valve on fridg | richard66 | Oven Repair (including Ranges and Cooktops) | 2 | 06-27-2009 04:15 PM |
