Discuss
Stops Draining - Air pocket at pump
 in
Washer Repair
Picked up an almost new machine form someone who was having problems with it for free, yay me (once I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Stops Draining - Air pocket at pump
  #1 (permalink)
Old 04-17-2013, 09:04 AM
Junior Member
cantada is on a distinguished road
Default Stops Draining - Air pocket at pump
Model Number: EIFLS55IRRO   Brand: Electrolux   Age: 1 - 5 years
Picked up an almost new machine form someone who was having problems with it for free, yay me (once I fix this issue) ... Washer will stop every couple of cycles with a E21 error (water not pumping fast enough). Took apart and checked for obstruction in , trap, pump, ect and found none. Put back together and it still get an E21 error. Next I replaced the pump and checked for obstructions again and found none but I still get the occasional E21 every couple of loads. Every time I get the E21, if I blow down the drain tube with medium pressure and force the water still in the tube back down (and presumably overpower the rubber flapper back flow) into the pump impeller, I can then restart the machine, it will pump out all of the water super quick and complete its cycle. So, based on that, is there something in or attached to the main drain pipe between the tub and the pump that is supposed to vent air out of the pump area and prevent an air lock of the pump?
Thanks in advance
Related Models
 EIFLS60JIW0 WASHER
 EIFLS60JMB0 WASHER
 EIFLS60JRR0 WASHER
 EIFLW55HIW0 WASHER
 EIFLW55HMB0 WASHER
 EIFLW55IKG0 WASHER
 EIFLW55IRR0 WASHER
 EIGD55HIW0 GAS DRYER
 EIGD55HIW1 GAS DRYER
 EIGD55HIW2 GAS DRYER
 EIGD55HMB0 GAS DRYER
 EIGD55HMB2 GAS DRYER
 EIGD55IKG0 GAS DRYER
 EIGD55IKG1 GAS DRYER
 EIGD55IKG2 GAS DRYER
 EIGD55IRR0 GAS DRYER
 EIGD55IRR1 GAS DRYER
 EIGD55IRR2 GAS DRYER
Thermador EIICV30 COOKTOP
Thermador EIIGG30 COOKTOPS
Thermador EIIGG36 COOKTOPS
Thermador EIIGGCV30 COOKTOPS
Thermador EIIGGCV36 COOKTOPS
Thermador EIIWD24 WARMING DRAWER
 EILFU17GS0 FREEZER
 EILFU17GS1 FREEZER
 EILFU17GS2 FREEZER
 EILFU21GS0 FREEZER
 EILFU21GS2 FREEZER
Amana EIM5-H MISC / ACCESSORY
 EIMED55IIW0 ELECTRIC DRYER
 EIMED55IMB0 ELECTRIC DRYER
 EIMED55IRR0 ELECTRIC DRYER
 EIMED60JIW0 DRYER
 EIMED60JMB0 DRYER
 EIMED60JRR0 DRYER
 EIMGD55IIW2 DRYER
 EIMGD55IMB2 DRYER
 EIMGD55IRR2 DRYER
 EIMGD60JIW0 DRYER
 EIMGD60JMB0 DRYER
 EIMGD60JRR0 DRYER
Amana EJA214 RANGE- S/C S/I DDRAFT GAS
Amana EJA312 RANGE- S/C S/I DDRAFT GAS
Amana EJA314 RANGE- S/C S/I DDRAFT GAS
Amana EJA315 RANGE- S/C S/I DDRAFT ELE
Amana EJA335 RANGE- S/C S/I DDRAFT ELE
Amana EJA367 RANGE- S/C S/I DDRAFT GAS
Amana EJA394 RANGE- S/C S/I DDRAFT GAS
Amana EJA395 RANGE- S/C S/I DDRAFT ELE
Amana EJA397 RANGE- S/C S/I DDRAFT GAS
Amana EJC312 RANGE- S/C S/I DDRAFT GAS
Amana EJC314 RANGE- S/C S/I DDRAFT GAS
Amana EJC335 RANGE- S/C S/I DDRAFT ELE
Amana EJC394 RANGE- S/C S/I DDRAFT ELE
Amana EJD335 RANGE - ELECTRIC STD DELAWARE
Amana EJD344 RANGE- S/C S/I DDRAFT GAS
Amana EJD345 RANGE- S/C S/I DDRAFT GAS
Amana EJD346 RANGE- STD MWAVE ELE
Amana EJD395 RANGE - ELECTRIC STD DELAWARE
Amana EJN3892W,L RANGE- S/C S/I DDRAFT GAS
Amana EJR304-2F/N RANGE- S/C S/I DDRAFT GAS
Amana EJS306 RANGE - ELECTRIC STD DELAWARE
Amana EJS335 RANGE - ELECTRIC STD DELAWARE
Amana EJT-346 RANGE- S/C S/I DDRAFT GAS
Whirlpool EJT142XKWR0 Refrigerators*
Whirlpool EJT144XKWR0 Refrigerators*
Whirlpool EJT161XKWR1 Refrigerators*
Whirlpool EJT161XKWR2 Refrigerators*
Whirlpool EJT181XKWR2 Refrigerators*
Amana EJT334 RANGE - ELECTRIC STD DELAWARE
Amana EKD289 WALLOVEN- STD MWAVE ELE
Amana EKD395 WALLOVEN- STD MWAVE ELE
Hardwick EKD9-51A439 RANGE- F/S STD ELE
Hardwick EKD9-51W439 RANGE- F/S STD ELE
Hardwick EKD9-52A439 RANGE- F/S CONT CLEAN ELE
Hardwick EKD9-52W439 RANGE- F/S CONT CLEAN ELE
 EKDR14XAKW0 DRYER
Hardwick EKF9-71A-569W ELECTRIC RANGE
Hardwick EKF9-71W-569W ELECTRIC RANGE
Hardwick EKG971A549 RANGE- F/S STD ELE
Hardwick EKG971W549 RANGE- F/S STD ELE
Amana EKS289 WALLOVEN- STD MWAVE ELE
Amana EKS395 WALLOVEN- STD MWAVE ELE
Amana EKS396 WALLOVEN- STD MWAVE ELE
Amana EKT-396 RANGE- S/C S/I DDRAFT GAS
Whirlpool EL02CCXHW00 COMPACT REFRIGERATOR
Whirlpool EL02CCXHW1 COMPACT REFRIGERATOR
Whirlpool EL02CCXJW COMPACT REFRIGERATOR
Whirlpool EL02CCXLB
Whirlpool EL02CCXMB00 REFRIGERATOR
Whirlpool EL02CCXMQ00 REFRIGERATOR
Whirlpool EL02CCXPB00 COMPACT REFRIGERATOR
Whirlpool EL02CCXPQ00 COMPACT REFRIGERATOR
Whirlpool EL02CCXWW0 Refrigerators*
Whirlpool EL02PPXMB00 REFRIGERATOR
Whirlpool EL02PPXMQ00 REFRIGERATOR
Whirlpool EL03CCXDW00 REFRIGERATOR
Whirlpool EL03CCXFW00 COMPACT REFRIGERATOR
Whirlpool EL03CCXHW00 COMPACT REFRIGERATOR
Whirlpool EL03CCXJW COMPACT REFRIGERATOR
Whirlpool EL03CCXLB
Whirlpool EL03CCXMB00 REFRIGERATOR
Whirlpool EL03CCXMQ00 REFRIGERATOR
Whirlpool EL03CCXMS00 REFRIGERATOR
Whirlpool EL03CCXRB00 REFRIGERATOR
Whirlpool EL03CCXRQ00 REFRIGERATOR
Whirlpool EL03CCXWW0 Refrigerators*
Whirlpool EL03PPXMB00 REFRIGERATOR
Whirlpool EL03PPXML00 REFRIGERATOR
Whirlpool EL03PPXMQ00 REFRIGERATOR
Whirlpool EL05CCXAW0 REFRIGERATOR
Whirlpool EL05CCXDW00 REFRIGERATOR
Whirlpool EL05CCXFW00 COMPACT REFRIGERATOR
Whirlpool EL05CCXHW00 COMPACT REFRIGERATOR
Whirlpool EL05CCXJW COMPACT REFRIGERATOR
Whirlpool EL05CCXLB
Whirlpool EL05CCXLS
Whirlpool EL05CCXMB00 REFRIGERATOR
  #2 (permalink)
Old 04-17-2013, 02:52 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Here is the drain pump Part number: AP4510671
As you can see there is the flapper or check valve at the discharge. Check if its intact. If it's nowhere to find get a new pump.
Here are the breakdown diagrams and Motor / Tub parts for Electrolux EIFLS55IRR0 - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 04-17-2013, 03:22 PM
Junior Member
Default
The back flow flapper is intact on the pump now and was also good on the pump I replaced. The reason I mentioned the flapper was because of what I have to do to get the washer to pump again I have to blow back down the discharge hose into the machine to force the flapper back in (overriding it) and allowing water from the discharge tube back into the pump impeller. I can hear bubbles come back up into the tub, I assume its air trapped down by the pump itself. Once I blow back down the discharge tube and turn the washer back on it pumps like crazy and drains the washer in seconds and will complete it cycle it does this every two to four loads. What I can't figure out is why air is getting trapped down there and how it is supposed to get out (is there a vent)? Appreciate your help!
  #4 (permalink)
Old 04-17-2013, 05:24 PM
Expert
Default
Hi.
Check couple of things:
The drain hose should not be inserted in to the standpipe more then 6".
The standpipe diameter is 1 1/4" min.
The standpipe hight is 24 - 96" max.
The drain hose should not tightly fit in to the standpipe.
There is no need for the venting of any kind because the trapped air from the pump area will escape into the tumbler.
Simon.
__________________
  #5 (permalink)
Old 04-17-2013, 05:45 PM
Junior Member
Default
All of that is good and no issues with the drain. This is the same thing the person who had it previously complained about but was not able to resolve. My drain hose is 1 1/4 tube, it is about 4 foot in length, the drain standpipe is 2 1/2 PVC about 4 1/2 foot above floor and the drain is loosely in the PVC maybe a 1/2 inch gap between the tune and the pipe. Once the air pocket is gone it drains very quickly. Definately got me scratching my head. The washer is like brand new otherwise.
  #6 (permalink)
Old 04-17-2013, 06:28 PM
Expert
Default
The only thing I can think of is that there is some kind of foreign object inside the outer tub wich periodically clogging the opening at the bottom.
May sound crazy, but have seen that before.
Simon.
__________________
  #7 (permalink)
Old 05-05-2013, 10:48 AM
Junior Member
Muriel is on a distinguished road
Default Air pocket at pump
I have a Frigidaire Affinity LAFW8000LW0. I have had nothing but problems with this brand new machine my boyfriend bought me. The E21 error being the most recent one. Pump is working flap is in place as in you Electrolux. I blow into tube and it drains. I think and will find out soon it is the drain pipe itself, it may be clogged or damaged in some way allowing air back into tube. I am going to add tubing to existing end to reach my slop tub and see if that works. If so I will call the plumber to fix my drain pipe.
  #8 (permalink)
Old 05-06-2013, 12:58 PM
Expert
Default
Hi.
Check the diameter and the hight if the drain standpipe. Reffer to the owner's manual.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water not draining after new pump was installed lloyd520 Dishwasher Repair 1 12-30-2010 01:16 PM
new pump but ge washer still not draining wishiknew Washer Repair 0 12-04-2010 01:18 PM
Bosch SHX pump stuck draining MJHeil Dishwasher Repair 1 01-06-2010 04:13 PM
Draining issue - don't think it's the pump paddle6 Dishwasher Repair 0 06-09-2009 01:44 PM
draining tub before I check pump kaahurley Washer Repair 1 03-19-2008 04:09 PM
